coolant flush?
to flush all the coolant out of your car what must you do? i looked in the DIY section....only flushings is for transmissions. i know about the drain thing under the car....but i want ZERO coolant in it so i can try bar's leaks head gasket repair. i searched for that too....and found mixed reviews so i might as well try it. i just wanna be sure i flush everything correctly.
ill go through what i THINK is the proper procedure then you all can correct me....ok. open drain plug, let crap come out. close drain plug. fill radiator with water, run car til warm, let cool down, open drain, close drain, refill with water (repeat like 3 times?) or until all clear water comes out of drain. is this a proper coolant flush? then, just so yall know, you add the stuff, fill rest with water, run til warm, top off with water, run at higher rpm 1500, let sit, top off with water, let sit for 1 hour. drain. leave plug open and cap off for 12 hours. flush like above, and then refill with proper coolant. tada! no more bhg!! ![]()
http://www.mustangmods.com/data/11289/grundle.jpg |
Yes all that and also there's also a good 1/2 gal of coolant when I removed the differential cooler line. Best bet is if you can drain from the engine block...the brass plug next to the starter is very inaccessible unless you had the driver side axle out of the way. All the flushing with water will get trapped in the block no matter what. Now that Honda offers only the diluted type 2 blue, it gets even more diluted with the left over water from all that flushing.
what i was planning on doing after all that flushing is drive around for a day after refilling with the blue coolant, then draining that, and refilling again with the blue stuff. that way less water will be in there. you know. try to get as much water out as possible.
Dont Catch
i used bars head gasket repair last weekend...
make sure you get absolutely all the coolant out... i had a pretty bad experience with it since i think it clogged something in the coolant system. i was driving on the expressway to queens to get a type II motor put in but on the way something burst. I never found out what the source was but it was probably the heater hose that burst... not sure since I had it towed to the garage after that little incident. i guess it mixed with the anti-freeze and it clogged up somewhere. |
#5 (permalink) | |
#6 (permalink) | |
Hey Grundle sexxy car.
There is a short cut to flushing your cooling system completely. I will write the steps for you. 1. Remove your radiator cap and drain your radiator: ![]() 2. Remove your upper radiator hose: ![]() 3. Underneath the car, next to the oil filter, there a coolant line which will allow you to remove 95% of your coolant. When you remove the clamp, coolant will flood out. (in the picture, it's the bottom middle(ish) ![]() 4. Now, get your favorite water hose and spray water into where the upper radiator hose goes. This will flush out the remaining coolant out of the clamp you just removed from underneath the car. ![]() 5. Keep in mind, your cooling system will now hold a small amount of water. Now, pour coolant down the same hole you sprayed water down until the hose underneath the car is flushing out coolant. 6. Connect the hose underneath the car. Screw back in your radiator drain plug, reconnect the upper radiator hose and BLEED your system.
http://img.photobucket.com/albums/v3...44/avatar2.jpg |
wow...thanks a ton man. this is gonna save hours of waiting like a Bit Ch. it will also basically guarantee that i get everything out. much appreciated!!
i agree... that little step by step will save us 3 or 4 flush.. thanks a lot Ballistic.
This should be a sticky, cuz a lot of us can't seem to find the draining plug on the block cuz no one want to take a picture of it to show us. this also would help newbies like myself that only knows how to flush the radiator by the radiator drain plug. |
#12 (permalink) | |
im not a dickhead and wont try to sell it as if it doesnt have a BHG. i have come to terms with it and will do all in my power to keep it from getting worse.
this would be a good DIY in that section. hint hint
jk
#14 (permalink) | |
Hi
#15 (permalink) | |
| How many miles on your *original* headgasket? Protecting headgaskets? | 92Legendsedan | Second Generation Legend (1991-1995) | 80 | 05-21-07 08:31 AM |
| Headgasket -- permanent fix? | SLICK40 | Second Generation Legend (1991-1995) | 30 | 10-14-04 02:06 PM |
| Coolant Importance | Danny | Second Generation Legend (1991-1995) | 0 | 12-24-03 02:36 PM |
| Honda Coolant!!!! | Phireant | Second Generation Legend (1991-1995) | 3 | 09-30-03 02:48 PM |
| Why you should use Honda Brand Antifreeze | Avarice | DIYs | 3 | 02-28-03 08:36 AM |
