Could use some help - The Acura Legend & Acura RL Forum
Old 12-10-12, 10:01 PM   #1 (permalink)
Car 1: 1993 Acura Legend LS
Could use some help
Hey there everyone, I changed the fuses recently in my Legend because whenever I use the signal lights you hear the blinking sound but NONE of the lights blink. My horn doesn't go off, and for some reason my Alarm, and remote for the doors doesn't work either. I changed the batteries and checked the normal fuses and they all seem fine. I'm new to the Acura and Legend period. Could use some help and feedback
-1993 Acura Legend
Tank is offline   Reply With Quote
Old 12-11-12, 12:32 AM   #2 (permalink)
BUMP, please.. anyone?
Old 12-11-12, 01:25 AM   #3 (permalink)
Car 1: 1993 Legend Coupe
Car 2: 1993 Legend Sedan
Car 3: 2003 Volvo S60 2.4T
Battery
You didn't mention if the car actually starts.
Did you disconnect the battery cables or cables to the fuse box when you replaced fuses?
The battery cables are REALLY sensitive. You have to make sure your battery connection is really clean and tight. You can even get one of those round post terminal inserts from Autozone.
That's where I would start.
scorchingeng is offline   Reply With Quote
Old 12-11-12, 03:40 AM   #4 (permalink)
Car starts and runs perfectly fine, I had a little bit of water up to the middle of the tire 18" if that would've did it? because everything else works fine.
Old 12-11-12, 09:58 AM   #5 (permalink)
BUMP!!
Old 12-11-12, 01:33 PM   #6 (permalink)
do you have an aftermarket alarm?
1992 Legend LS Sedan, Granada Black on Black
2005 CR-V EX AWD AT (Japan build), Nighthawk Black on Black
2013 ILX Premium, Brownstone Metallic on Ivory
SemiAuto is offline   Reply With Quote
Old 12-11-12, 01:44 PM   #7 (permalink)
no, stock alarm
Old 12-11-12, 02:30 PM   #8 (permalink)
AZpartsGuy
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1998 Civic EX
Car 3: 95 ZX-7
iTrader Score: 63 reviews
Could be the ICU (on back of the inside fuse panel) but not sure. Have you looked through the online manual and gone through the things to check there in the electrical portion?
Old 12-11-12, 03:38 PM   #9 (permalink)
check the back of the under dash fuse box. apparently, the sunroof drain on the a-pillar can back up causing massive corrosion and shorts across unrelated systems (info from a dealer friend of mine based in NY).
Old 12-11-12, 04:23 PM   #10 (permalink)
BIGBOY's Avatar
Car 1: 94 acura legend ls
As mentioned check the fuse box for moisture and corrosion. I would also get some contact cleaner/lubricant to dissolve any built up corrosion.
Old 12-11-12, 08:49 PM   #11 (permalink)
I checked both fuse boxes under the dash by the door, I checked the fuse under the hood everything is fine, Nothing is wet. So could it be the relay? or the flasher?
Old 12-12-12, 12:29 PM   #12 (permalink)
you have problems across 3 seemingly unrelated systems. something else is going on. if the car was partially submerged, it could be bad grounds or corroded wiring harnesses.
