Old 03-04-06, 02:52 PM   #1 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
Angry Dashboard replacement-wiring reuse (Proress report)
I obtained a used LS dashboard to relace my cracked LS dash. Can I move
the "cracked dash" wiring to the "new" used dash? I ask because the used dash wiring was snipped between its origin and dash entry point. ( I have the online service manual CD and also searched unsucessfully for the Stevieray and dethred threads on their dash replacements.)
If one purchased a dash from the dealer($800.00,) is the wiring included or is it a seperate purchase? Any help/references will be greatly appreciated.
Edit: I attempted the dash replacement and was stymied by the passenger airbag disconnection (not the disarm.) Ballistic and Stevieray have the only remaining photos of the DIY. I felt too unfamiliar with the work area and
ressembled all my components. All the other steps were simple to tedious.
Call it a dress rehearsal; I will try again after learning more about SRS.
Thanks for the help. Dashboard 1; Boru 0. (first round.)
Boru is offline
Old 03-04-06, 07:31 PM   #2 (permalink)
Kenso's Avatar
Car 1: 91 L Coupe 6 spd
Car 2: 95 FZJ 80
Car 3: ITR 00-106
Even with a brand new dash, you have to switch over all the old components. Just swap the harness over.
ITR 00-106
91 6spd coupe
95 FZJ-80
Kenso is offline
Old 03-04-06, 10:26 PM   #3 (permalink)
Thank you, Kenso; I was hoping that was the case.
Boru is offline
Old 04-09-06, 04:41 PM   #4 (permalink)
I have another dash wiring question. When I remove the dash (after all the
other steps,) do I #1.disconnect the wiring by cutting the plastic ties, thus freeing the dash? Or do I #2. disconnect the wiring at the kick pad/fuse box
area, thus freeing the dash (with wiring still tied to dash?)
I have the replacement dash and a few of the plastic ties will be
a challenge if I have to work upside down up under the dash. The manuals
make no specific reference other than "disconnect the connectors" which I
assume means the electrical connectors, not the plastic ties.
I hope to complete this project over Easter weekend (symbolism noted.)
Thanks for any suggestions.
Boru is offline
Old 04-09-06, 05:13 PM   #5 (permalink)
Kenso's Avatar
Car 2: 95 FZJ 80
Car 3: ITR 00-106
Unplug all the connectors from the fusebox and other harnesses as necessary. Remove the dash with the harness still attached, then swap the harness.
ITR 00-106
91 6spd coupe
95 FZJ-80
Kenso is offline
Old 04-09-06, 06:01 PM   #6 (permalink)
Thanks again Kenso, especially for the pics. Sometimes I overthink a problem
rather than do the obvious. You have been a great help.
Boru is offline
Alpine CDM-7861 Stereo With Mounting Kit / Legend Wiring Harness / RCA Cables Nick Gorski Aftermarket Parts 0 12-10-05 06:01 PM
Need expert help with driver's door panel Wiring! Dethred Second Generation Legend (1991-1995) 2 08-05-04 02:20 PM
Replacement EGR for code 12 FJHeumann Second Generation Legend (1991-1995) 9 06-28-04 08:29 PM
Lighting Problems (suspect wiring) Melissa First Generation Legend (1986-1990) 4 11-09-03 12:40 AM
Cam Seal replacement AND Keyless Wiring Diagram Citka First Generation Legend (1986-1990) 2 11-08-02 02:07 PM
