Daytime Running Lights (DRL) stays on - The Acura Legend & Acura RL Forum
Old 07-30-05, 06:52 PM   #1 (permalink)
Car 1: 1991 Legend
Hello again,
I have a Canadian model Legend and there is a problem with DRL control.
The DRL lights don't light and the control stays on. When flicking high-beams on/off I noticed that the passenger side High-Beam does not work. I thought it was a bad bulb, but after switching right with left, the same passenger side didn't work, so the bad bulb is taken out of equation. All the cable connectors seem to be clean and free of any dirt.
Any other ideas for the source of this problem and solution?
Thank you.
chrispik is offline   Reply With Quote
Old 07-31-05, 12:55 AM   #2 (permalink)
Car 1: 1993 Legend LS sedan, 2002 3.2TL
Send a message via AIM to PerzianKabob
fuse? relay? i don't know what i'm saying, but i've heard these words before.
PerzianKabob is offline   Reply With Quote
Old 02-08-06, 08:32 PM   #3 (permalink)
aclegend
oMaiR's Avatar
Car 1: 2000 3.5 RL
Car 2: 95 Legend LS
same problem here..
u have to change the module for DRL but i cant figure out where it is?...help...
oMaiR is offline   Reply With Quote
Old 02-08-06, 09:10 PM   #4 (permalink)
Car 1: '91 L Sedan
good to see another Vancouver Legend owner. welcome
amplified is offline   Reply With Quote
Old 02-09-06, 03:52 AM   #5 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
Car 3: 95 LS 6 spd coupe
iTrader Score: 7 reviews
its easy get a voltmeter have someone turn the highs on, and test the power. if no power is coming then check fuse
if u need help pm me maybe we can meet up.
Old 07-07-07, 10:37 PM   #6 (permalink)
amon's Avatar
Car 1: 95 acura legend coupe
Thumbs down DayTime Running Lights
Originally Posted by chrispik View Post
Hello again,
Thank you.
I have the exact same problem does anyone know where the module for DRL is ?? My car looks dead during the daytime now and i really wanna get my DRLs working again.
amon is offline   Reply With Quote
Old 07-07-07, 10:47 PM   #7 (permalink)
amon's Avatar
NVM i found it by doing a search he he heres the link for anyone else that needs it http://www.arnach.net/service/index....&z=1371&r=0934
Old 07-08-07, 11:56 AM   #8 (permalink)
The Great White North
tw1st's Avatar
Car 1: 95 Black on Black LS 6-speed
Before i purchased my car, the previous owner mentioned that he needed to replace the DRL module.
When i got the car, in the service records there was a reciept for the purchase and install of the DRL module.
You may have to buy a new one of those.
Installed:
JDM Headlights with HID Retrofit,
Weapon-R Secret Weapon, Remus Exhaust,
Metal Substrate High Flow Cat,
MLS Copy Bar, Addco Rear Sway Bar,
Eibach Springs on Koni Reds,
Blackend Engine Damper, 17" RSX A-spec Rims
tw1st is offline   Reply With Quote
Old 07-08-07, 01:08 PM   #9 (permalink)
amon's Avatar
How much did he get it for did it say on the reciept??????????????
Old 07-09-07, 07:43 AM   #10 (permalink)
contact148's Avatar
Car 1: 1993 legend
Car 2: 1995 neon
Car 3: 1946 willys CJ2A
find and pull the relay for the daytime lights
open it up the solder will be cracked on 3- 6 points (i used a magnifiying glass to see) re-solder those cracked points and it will be good as new
check all points i fixed 4 then tried it no work took it back out checked them all found 2 more
contact148 is offline   Reply With Quote
Old 07-09-07, 12:59 PM   #11 (permalink)
amon's Avatar
Can you tell me where the relay is? I called the dealer asked them for the price they told me 182$. I will definitely try to fix it like you said before getting a new one.
Old 07-09-07, 05:52 PM   #12 (permalink)
contact148's Avatar
Car 1: 1993 legend
Car 2: 1995 neon
its up under driver side dash I can remember the colour...maybe blue? it was held on by 1 10mm bolt
you need to remove the bottom dash panel on driver side
put the seat all the way back and get under the dash head goes where the pedals are im 5'8 185lbs and there was enough room for me!
the relay may even be marked i think it was
mine is a 1993 sedan
Old 07-09-07, 08:16 PM   #13 (permalink)
amon's Avatar
Thanks alot for the help i will go right now and check it out hopefully i can find it.
Old 07-09-07, 10:16 PM   #14 (permalink)
amon's Avatar
Unhappy
I dont think i saw the the relay for the drl. I got some pictures u could look at tell me if u see it. Is it that black box? The one that says relay.
Daytime Running Lights (DRL) stays on-picture-023.jpg   Daytime Running Lights (DRL) stays on-picture-024.jpg   Daytime Running Lights (DRL) stays on-picture-026.jpg   Daytime Running Lights (DRL) stays on-picture-025.jpg
Old 07-10-07, 07:51 AM   #15 (permalink)
contact148's Avatar
Car 1: 1993 legend
Car 2: 1995 neon
see the security system "brain" sitting in the drivers seat mine was to the left of it futher towards the firewall and UP higer inside the dash
its been raining here if it stops ill try and get a pic in the next day or 2
Running your OEM foglights during the day (without needing to turn on your lights) theGodfather DIYs 20 08-15-10 07:36 PM
Speedometer Acting Crazy When Lights Are Turned On thusu Second Generation Legend (1991-1995) 12 12-01-04 10:07 PM
Daytime running lights fastlegend Second Generation Legend (1991-1995) 7 02-12-03 06:40 PM
legend stops running at lights fokiohero First Generation Legend (1986-1990) 6 08-12-02 01:26 AM
daytime running lights alienclay Engine & Performance Modifications 0 04-03-02 03:24 PM
