differential fluid - The Acura Legend & Acura RL Forum
Old 03-06-04, 12:57 PM   #1 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
Car 3: 95 LS 6 spd coupe
iTrader Score: 7 reviews
differential fluid
how important is it to change the differential fluid? i ahve enever done it on my car
Old 03-06-04, 01:16 PM   #2 (permalink)
Car 1: .
It is very important. You are suppose to do it every 30k miles, if I am not correct. I used Redline MT-90. I have also used Mobil1 Gear oil. The Redline is a true 90w, which our cars call for. The Mobil1, and most other differential fluids you will find are, 75w-90. The Mobil1 still worked fine for me though.
Later!
Lee
Old 03-06-04, 01:37 PM   #3 (permalink)
Car 1: 12sec E36 M3
Send a message via AIM to 92coupeon18s
yep its important. Do them all as often as you can or want to
92coupeon18s is offline   Reply With Quote
Old 03-06-04, 03:51 PM   #4 (permalink)
Sho Ga Nai's Avatar
Car 1: A pied and hitchhiking
Car 2: Subaru (Hibernating)
Car 3: Legend (Hibernating)
Send a message via AIM to Sho Ga Nai
I use Castrol Hypoi C 80/90 weight MT-1...don't use the LSD HIPO one, it really messes with your gears unless your car is accustomed to high temps (AZ, hot desert weather).
Pray for jury duty
Sho Ga Nai is offline   Reply With Quote
Old 03-07-04, 01:17 AM   #5 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
As important as changing your underwear before the big date. Or, as important as going to the dentist regularly before your teeth fall out. The manual change interval is every 30k miles or 24 months.
All kidding aside, the diff only holds 1.1 qt of fluid. Can get very nasty after a couple of yrs. It also is infamous for seeping seals. You need to check the seal everytime you change your engine oil.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
Old 03-07-04, 01:45 AM   #6 (permalink)
Car 1: 1992 Coupe LS
I think that fluid changes are so cheap compared to fixing trouble later. I'm sure that clean fluid helps to prevent seal problems, gear wear, corrosion, and all sorts of other crap.
My question is: How tough is it to re-fill the diff once you've drained it?
92 LS Coupe
83,000 Miles & Counting
Stock except
-GS RIMS
-Clear Bumpers
Tinkindling is offline   Reply With Quote
Old 03-07-04, 02:44 AM   #7 (permalink)
Type I King
Car 1: 92 LS Sedan
the differential has two bolts the bottom when i used to drain, then there is a bolt right on top from where you fill it back up. the question i have is how do you fill it back up, do you need some kind of pump to do this? I cant imagine just dumping in straight from the bottle
Old 03-07-04, 03:00 AM   #8 (permalink)
Pedobear is watching you
tnelson's Avatar
Car 1: 2002 TL-S, white
Car 2: 1992 Corvette
yeah, you use a hand pump, and the top bolt on the diff is the fill. think its simply a 3/8s square, so you can fit a ratchet in it, but maybe thats the drain, dont remember. anyway, should take a little over a quart, and you should be able to stick your finger in the whole and down and touch diff fluid when it is full.
tnelson is offline   Reply With Quote
Old 03-07-04, 06:07 AM   #9 (permalink)
tormenta's Avatar
Car 1: legend coupe 1995 L
Diff
You should always check diff seals when you change your oil. I just recently had to do a diff seal , the cost at the dealer was 650.00 . Part was 15.00 and the rest was labor. Lesson learned!!!!!
tormenta is offline   Reply With Quote
Old 03-07-04, 07:29 AM   #10 (permalink)
*he K*ng
Car 1: 1991 Legend Coupe LS
Do a search, there have been many threads on this topic. Even a few on how to change your diff seal....
Extrovertz is offline   Reply With Quote
Old 03-07-04, 07:32 AM   #11 (permalink)
tnelson's Avatar
Re: Diff
i did it myself, that diff seal and rear main seal. trust me, 650 is not that much for as big a job as it is.
Old 03-07-04, 07:42 AM   #12 (permalink)
*he K*ng
Hey, I got either diff oil or engine oil dripping off the bottom of the engine. HOw many hours did it take you to replace the two seals? I have a full shop but want to know if I can tackle it in one day. TY. Got any pics?
Old 03-07-04, 09:09 AM   #13 (permalink)
Car 1: '93 black on black 5 speed sedan
Re: Diff
You should always check diff seals when you change your oil. Lesson learned!
What lesson was learned? How could have you prevented this seal from degrading?
Mike
Minnesota51 is offline   Reply With Quote
Old 03-07-04, 09:50 AM   #14 (permalink)
Type I King
Car 1: 92 LS Sedan
can changing the fluid cause any wear on the seal?
Old 03-07-04, 10:06 AM   #15 (permalink)
tnelson's Avatar
yes, i do have pictures, here they are
thats the back of the engine. if you want directions on how to do it, hit me up on aim.....i can give good instructions.
thats my diff seal. if you wanna see any more pics. check www.speedingtexan.com
ATF bong!!!!! and yes, thats me bonging.
