Differential leak - The Acura Legend & Acura RL Forum
Old 10-15-03, 03:13 PM   #1 (permalink)
Awaiting Email Confirmation
Car 1: 1995 Legend LS Coupe
Differential leak
I think my differential has a slow leak. It doesn't seem to be leaking from either axle shaft seal so I'm assuming that the leak is coming from the shaft seal where it connects to the transmission. Is this a common problem? Is it difficult (or expensive) to fix?
oldacura is offline   Reply With Quote
Old 10-15-03, 08:30 PM   #2 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
Leaking differential seal is a very common problem. Price through Acura is $550. Need to remove the unit in order to replace seal.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
Old 10-18-03, 11:21 AM   #3 (permalink)
Car 1: 94 Legend GS Blk/Blk
Car 2: 98 Lexus GS400 Blk
I don't know how bad it is, may be u should try to refill the differential fluid first to see that will solve your problem, b4 u spend $500.
For more info, please see this link:http://www.legend-forum.com/vbulleti...477#post299477
VegasGS is offline   Reply With Quote
Old 10-18-03, 11:59 AM   #4 (permalink)
Car 1: 93 acura legend 6spd blk on blk coupe
Send a message via AIM to cbr900bikes
putting more fluid in, is not going to solve a leaking differential seal problem.
cbr900bikes is offline   Reply With Quote
Old 10-20-03, 01:58 PM   #5 (permalink)
Car 1: 91 Legend L Sedan
There's three or four other people here on another thread that changed the fluid and the leak stopped. Mine slowed considerably but didn't stop. The differential isn't an area most people think to maintain. On many cars the differential fluid is the same fluid circulating through the trannie, but it is a separate resevoir on the Acura. Once the fluid gets old it starts to break down and the seals start to shrink slightly with age as well. Sometimes just putting new fluid can slightly recondition the seals for a while. Just as adding a transmission fluid with seal conditioner can stop many fluid leaks there too. It is the first thing to try before busting loose for a 600.00 repair
Josh is offline   Reply With Quote
Old 10-20-03, 02:44 PM   #6 (permalink)
just like they sell stop smoke at autoparts stores that suppose to stop your engine from smokeing and to soften up your valve seals
well i can't really say nothing about the 3 or 4 people that it worked for, but if we was to do a poll i would bet that
1 out of every 10 people will say that method actually works
go ahead and try, you might be that lucky 1
you did make a good point though
$20 worth of gear oil and a pump to put the oil in, is way better than coughing up $500 or so. Thats if you are one of them lucky people.
Old 10-20-03, 02:55 PM   #7 (permalink)
I don't know about stop smoke, but I've used power steering fluid with stop leak, that reconditioned the seals and never had another problem again. I've used transmission stop leak that stopped a fairly regular leak on a van I had, and I never had another problem for five years and still going, etc. So it is always worth it to try a seal conditioner first. The one thing that I've never had any luck with is the radiator stop leak. Usually there is a problem brewing that is worse than what that can stop.
Old 10-20-03, 03:07 PM   #8 (permalink)
well i cant talk about my luck because i've never tried those things but i have had some success with the radiator stop leak in my 87 legend coupe back in the days. The only problem is that it clogged up the radiator and my fans would come on to often which led to me eventually buying a new radiator and a set of fans
so to sum it up/a $100 radiator whined up costing me roughly $350
new rad,new thermostat,new fans(got burnt out due to continuasly running non-stop),radiator flush(flush all the stop leak stuff out the engine block) and my play time.
but what the hell
if it's been working for you for all these years then why stop.
Old 10-22-03, 06:44 AM   #9 (permalink)
Car 1: 1991 LS Legend Sedan
91 Sedan with 122k miles, no leak yet. I change the oil every 30k per manual recommendations.
Scott Yoder
Vineyard Grey 91LS Sedan
Bought 6/98 w/47k
evrq2000 is offline   Reply With Quote
