WHAAAAAH!
DIY Fuel Door shaving *pics*
*This will be moved to the DIY section in 3 days*
As some of you know, I'm doing a lot of custom body work to my 91 Coupe. This is the general idea behind moving your gas cap to the trunk, and shaving the fuel door. 1. Remove the fuel door. Two 10mm bolts. Grind down to bare metal around the fuel door. ![]() 2. Remove the fuel cap and the tubes that runs down to the fuel tank. You have to remove part of the inner fender well to get to it. To remove the tube, there are 2 hose clamps holding the tube to a rubber hose leading to the fuel tank. 3. cut a piece of stainless sheet metal to fit in the hole where the fuel door used to be. ![]() 4. Tack weld that piece of metal into the hole, grind the tack welds down smooth and then use Duraglass for a primary filler. ![]() 5. Sand the Duraglass to a smooth surface, then use a lightweight body filler for the finishing filler. Block sand the body filler until you create a smooth surface. Apply primer to the area. 6. Take the fuel tube and wash the fuel residue out of it (to prevent fire). Cut the big and small tube in half. turn the top part of the tube 180 degrees and tack weld the larger tube back together until it is sealed. It's a good idea to use JB weld or another type of Epoxy sealer on the outside of the tube to prevent leakage. (pics coming) 7. Cut the smaller vent tube so that each end is about 2 inches long, then buy a foot of 5/8 fuel hose and 2 good hose clamps, cut the hose to fit, then fit the hose between the two ends and clamp it down. (pics coming) 8. Fit the fuel tank end of the tube into the fuel tank fitting and find out where you need to cut the wheel well. Mark a square, plug the fuel tank with a damp rag, and cut your hole. ![]() 9. Once you have the hole cut, feed the upper part of the fuel tube into the trunk and make sure that the trunk lid bars don't hit the cap or tube. 10. Once your fuel tubes are mounted, you need to cut 2 pieces of sheet metal to fit on each side of the fuel tube to cover up the rest of the hole. slide each piece of sheet metal around the fuel tank tube and tack weld the 1st piece of sheet metal to the inner part of the fender well. Then do the other side of the tube. The fuel tube should still be plugged. It's basically to cover up the space around the fuel tube, this part is really hard for me to explain, I'll get more pics on Sunday. 11. Unplug the fuel tube, twist your cap on. 12. Reinstall the inner fenderwell. You're done! I'll be updating this thread in a few days, then moving it to the DIY section. Mike Diaz
502MotorSports.com
shweet
that is pretty cool Mike Are you coming back to ATL next year?
The Hotness! Elevate Your Standards.... Legend Mod Money! Jasmyn | Final e39 Pics | 502MotorSports MySpace |
WHAAAAAH!
I think Nopi will have to wait until 2k5. My wife just found out she's prego
![]() she's about 1 month right now. She's due in August, and I don't think she'll be up for a road trip.
Sexy Member
wow mike thats tight
and congrats on the baby
RIP ZAK ![]() <----master of the unibrow Im carrying Darriths baby -da hass man http://www.acura-legend.com/gallery/file.php?n=169&w=l 91 L sedan- few mods 94 Gs- sold 97 Sc300-stock for now |
#7 (permalink) | |
WHAAAAAH!
WHAAAAAH!
wanna come out Sunday? I'll be heading out to his house at about 9:00 AM.
![]() Mort
ON ORDER Ranger Joe CAI Stromung Exhaust Bayou Stage II Chip 6000k HIDs 18" Racing Harts Pioneer 9815 HU And more to come... "Yeah actually I get paranoid ~ the stock Legend front looks so good I'm afraid someone will rip it off my car and put it on their Integra or something "
K L E A N M O D™
Congrats on the new addition.... Shaved..
-1995 KA8 MODIFIED-R.I.P -1997 S14a-SOLD -2000 Millenia S -1995.8 S14a -Holy Rollerz CCC Member- -Inspiration™- My KA8's totaled and still greater than.... Imitatated. Never duplicated.™ |
#14 (permalink) | |
WHAAAAAH!
#15 (permalink) |
So now you have to open your trunk to fill up your gas tank? That is going to stink your car up...
1992 Acura Legend LS Sedan Car name: AL<---figure it out http://www.imagestation.com/picture/...4/fd44ef6e.jpg Modifications GS Rims Acura Gold Emblem Kit OEM CD Changer EDM Corners BMW X5 Xenon Projector headlights Xenarc Xenon driving lights Custom Red/Clear/Red taillamps & JDM Red/orange/Red Taillights 6 color Indiglos Black Mesh Upper Grill |
