DIY: G2 Oil change - The Acura Legend & Acura RL Forum
Old 12-21-04, 09:35 AM   #1 (permalink)
Car 1: 1993 White Sedan
DIY: G2 Oil change
Hi Guys,
I couldnt see an oil change DIY anywhere and I guess most people may know how to do this, but it may still be useful.
Tools needed: 17m socket wrench, Engine Oil, Oil filter wrench, Oil filter, Drain plug crush washer from your local dealer, Jack, Jackstands, Oil Drain tray and Lots of rags.
Firstly remove your oil filler cap:
Then get the car off the ground:
Locate the Oil Sump Drain plug:
And undo the plug to get:
Once the once you get that going, attack the oil filter:
Have a break now...and wait for all the oil to stop dripping.
Once all the oil has stopped dripping, put the drain plug back in with new washers which you can get at your local dealership. You have an aluminum sump, so tighten it by hand and then tighten using the socket wrench you used to take it off. Don't overtighten. I use 2 fingers to pull on the wrench for the final tightening and that should be enough. Officially you should tighten to 45Nm (4.5kg-m, 33lb-ft), so ideally use a torque wrench if you have one. Now start looking at your new filter:
Don't forget to remove the oil drain tray/can from under the car.
So now your car is back on the ground:
Sleeper Legend adds:
"I also add 4.5qts and then run the engine until it is fully hot. Let it sit 5 minutes and then check the dip stick. It should still need .5qts. Add what it needs and let it run until warm again and sit off for 5 minutes. Check the dip stick again and it should be right on the line. This cycles the oil through the engine and gives it a chance to settle before getting a reading. This gives you a more accurate oil level reading. "
So your new oil is all back in. You engine is feeling better. Put everything back as it was, i.e put on the oil filer cap, put the dipstick back, close the bonnet/hood.
Hope this helps people. Of course you will need to make sure you get the best oil you can. Fully synth is best.
Cheers,
S
Shapps
http://www.shapps.8k.com/images/sig.jpg
Shapps is offline   Reply With Quote
Old 12-21-04, 10:38 AM   #2 (permalink)
Car 1: 1991 Gold Acura Legend LS
Car 2: 2006 Toyota Sienna
thanks for taking the time to do this...DIY
robbanks111 is offline   Reply With Quote
Old 12-21-04, 10:49 AM   #3 (permalink)
Car 1: .
Originally Posted by Shapps
You have the directions and the arrow colors backwards in this one. I also add 4.5qts and then run the engine until it is fully hot. Let it sit 5 minutes and then check the dip stick. It should still need .5qts. Add what it needs and let it run until warm again and sit off for 5 minutes. Check the dip stick again and it should be right on the line. This cycles the oil through the engine and gives it a chance to settle before getting a reading. This gives you a more accurate oil level reading. Good job on the DIY, this should be in the G2 FAQ.
Later!
Lee
Old 12-21-04, 11:53 AM   #4 (permalink)
Car 1: 1992 Cobalt Blue 5-speed Sedan
Thanks for a great DIY. I need to do a first oil change on my new Legend sometime soon... now I know how.
92CobaltBlue is offline   Reply With Quote
Old 12-21-04, 12:35 PM   #5 (permalink)
Car 1: 93 Legend LS 4 DR Auto Geneva Green Metalic
Send a message via MSN to smth_hckr
Nice DIY!
you should also add the part about replacing the crush washer on the drain plug, then torquing the plug to spec.
Old 12-21-04, 06:14 PM   #6 (permalink)
Car 1: 1988 944 Turbo
iTrader Score: 7 reviews
sweet DIY. will be very handy tool. Thanks!
Old 12-21-04, 07:53 PM   #7 (permalink)
Thanks guys. Sleeper & smth hcker, I've updated as per your comments.
Cheers,
Shapps
Shapps
Old 12-22-04, 03:02 AM   #8 (permalink)
Car 1: 95' LS Desert Mist Sedan
I like the socket filter tool that fits on the bottom of the filter, works pretty nice. Also, there's a newer design square funnel that a standard quartl bottle locks directly in, real convenient Walmart sells it.
ZiggyB is offline   Reply With Quote
Oil change for both sexes 1truluv First Generation Legend (1986-1990) 25 05-28-04 08:03 AM
Newbie question about engine oil change mocca Second Generation Legend (1991-1995) 5 09-09-02 05:57 PM
how do you change your oil? gAmEs0n Second Generation Legend (1991-1995) 8 07-24-02 12:27 AM
Oil Pressure drop big time flashdragoon First Generation Legend (1986-1990) 7 05-11-02 01:38 PM
Oil Change ??'s Second Generation Legend (1991-1995) 8 01-20-02 04:11 PM
