Old 05-09-08, 09:10 AM   #1 (permalink)
PuREBrEEDLegenDFiEND's Avatar
Car 1: 94 Acura Legend GS
Car 2: 03 Cadillac CTS
Does anyone know what a blinking "D4" light means...
Does anyone know what a blinking D4 light means, I was driving this morning when mine started to blink and the speedometer started going all over the place then rested on zero.
PuREBrEEDLegenDFiEND is offline
Old 05-09-08, 09:14 AM   #2 (permalink)
ptan1968's Avatar
Car 1: 94 Black on Black Legend GS Sedan
Car 2: 02 Toyota Camry XLE
Read this: It's already sticky on the first page in the DIY section.
Erratic Speedometer? D4 Light Flashing? Check Engine Light? HOW TO FIX! DIY
MOD's done so far:
  • TLs wheels bored (Yokohama YK520 215/50/17) (12-27-06)
    Sunroof tilted (12-27-06)
    HID 6000K installed (01-25-07)
    Gentex mirror installed (02-04-07)
    Hella Micro DE fog lights (03-10-07)
    BMW X5 smoke side markers (05-10-07)
    Remus specific exhaust (07-04-07)
    JDM 1 piece head lights w / DRL (07-04-07)
    Burlwood MDX shift knob (10-27-07)
    Pioneer Avic Z1 Navigation (10-27-07)
    Addco front and rear sway bars (01-04-08)
ptan1968 is offline
Old 05-09-08, 10:01 AM   #3 (permalink)
CAN U SAY FUGLY?
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
The real question is, "Do you know what 'search' means"?
d4 light flashing
94 legend did the weirdest thing today
D4 Flashing/No Speedo Are they connected
Unusual D4 Problem has me stumped, Need help!
Check engine and D4 + code help
This has been asked a time or two before...............
TO BLEED AIR FROM COOLANT, CLICK HERE:
http://www.acura-legend.com/vbulletin/883766-post7.html
91 with type II engine, 6 speed tranny, EDM headlights, EDM spoiler, carbon fiber interior trim, type II cluster, OBX headers, 2 1/2" Catback to Remus Rev 3, CAI.
blkonblkcpe is offline
Old 05-26-08, 01:43 AM   #4 (permalink)
Car 1: 94 4 door legend
Car 2: 93 2 door legend
Car 3: 93 lexus gs
to be striaght without the unwanted commentary, a blinking d4 light could be a couple different things. your sypmtoms sound like the more common,( a bad vss) type it in the search box and you should find some more info there. good luck
coup'd up is offline
Old 05-26-08, 10:11 AM   #5 (permalink)
CAN U SAY FUGLY?
Maybe an unwanted comment, but, I did list FIVElinks to D4 threads!
Old 05-26-08, 06:12 PM   #6 (permalink)
Swollen Member
stevieray's Avatar
Car 1: '95 LS Coupe
Car 2: '91 LS Coupe
Car 3: '89 Prelude Si
Way to enable the OP, noob. The way it works around here is that we prefer for people to use the SEARCH function instead of posting useless threads about subjects that have been previously discussed countless times before.
Good intentions, bad execution. Lurk & search before you make wiseass comments to the OGs.
"King of Kleen"
stevieray is offline
Old 05-26-08, 06:15 PM   #7 (permalink)
Bushido95Legend's Avatar
Car 1: 1995 Acura Legend LS
i got a question. what if none of the light is showing?? no blinking or nothing. i will post video soon. but when ever i change all the gear in my automatic shifter, there is not even light. no green one or red one.
Projects completed =
may 12 ,08 - timing belt , altenator belt, steering belt, serpantine belt, Cam Gear. new radiator cap = $800
may 13 , 08 - . 4 Michelin tires = $300...may 18. 08 fuel filter = $18.34...may 23,08 new drive axel and steering boot = $220. 05-24-08 sparkplug, atf drain & fill.
next projects = , water pump, dent repair, paint job, new front bumper, new rims, new carpet, altenator.
Bushido95Legend is offline
Old 05-26-08, 08:13 PM   #8 (permalink)
Car 1: 92 Stock Legend
Car 2: 87 T-Bird 302 MAF
Car 3: 71 T-Bird 429 TJet
@bushido most likely it is something burnt out in the dash..
reboticon is offline
Old 05-27-08, 11:27 AM   #9 (permalink)
You might want to search that before blkonblkcpe drills you a new asshole...
Old 05-27-08, 11:40 AM   #10 (permalink)
Swollen Member
stevieray's Avatar
Car 1: '95 LS Coupe
Car 2: '91 LS Coupe
Burned out bulb. Now search on how to remove the instrument cluster and/or buy a HELM factory service manual. Everything you could possibly want to know about this car is in here, you just have to look for it.
blkonblkcoupe won't be the one to drill a new asshole. It'll be me if ppl don't figure out how to use the search function. Quickly.
"King of Kleen"
Old 05-27-08, 03:22 PM   #11 (permalink)
Yo pedo en su dirección.
kotetu's Avatar
Car 1: 95 LS Coupe 6spd
Car 2: 94 L Cpe 6spd - sold
Car 3: 98 Prelude - sold
No no no! You guys are all wrong.
Blinking D4 means the ejector seat is about to fire.
1995 Acura Legend LS Coupe 6 speed
NSX seats - JDM Headlights - OEM Fogs - MLS Copy strut bar - Legend specific Tie bars - Addco F&R Sways - KSport suspension - Sr5Guy Stage 2 Chip - RangerJoe Short shifter - Aluminum Pulleys - Injen intake - Stromung 2.5 inch cat-back - S2000 Battery
Coming soon to a theater near you...
2005 RL BBK - Upgraded Final drive and LSD - Custom header - Cams - adjustable ball joints - adjustable end links
kotetu is offline
Old 05-27-08, 03:24 PM   #12 (permalink)
Swollen Member
stevieray's Avatar
Car 1: '95 LS Coupe
Car 2: '91 LS Coupe
I thought it meant the missle launchers were armed.
"King of Kleen"
Old 05-27-08, 03:26 PM   #13 (permalink)
Mr. Couper
KEYZER SOZE's Avatar
Car 1: 95 Pearl White COUPE LS (SOLD)
Car 2: 94 Black COUPE LS
...blown fuse for oil slick activation button
KEYZER SOZE is offline
Old 05-27-08, 03:51 PM   #14 (permalink)
kotetu's Avatar
VTEC fluid low. Refill with Premium. Remember - NSX VTEC fluid gives you +25 HP and +10 XP. When you Level up, remember to distribute your stat points evenly to all 4 wheels to improve your cornering.
kotetu is offline
