Old 08-02-05, 08:50 AM   #1 (permalink)
xkazman's Avatar
Car 1: 1993 Legend L Coupe
Send a message via MSN to xkazman
Does Your Tranny Slip? Read This
For the past year and a half my auto tranny has been slipping at 3rd gear. When it started to happen I did the 4x Fluid change with no prevail. At this point I figured it would get worse, everytime I would get service I would mention it but my mechanic said it must be a selenoid that went bad.
After reading a few threads on our forum I became obsessed with changing my Transmission strainer/filter. So I finally did it the past weekend. 14 bolts later I found sludge and a few metal shavings in the pan, the sludge was metal too just smaller. I cleaned the 2 magnets and the pan, replaced the strainer and put Honda ATF and the results...
Slip is gone! For now anyways. This is a testimony if you havent changed your strainer...IMO DO IT!
Just wanted to share
-Peace
Mods:
Custom Ported Box
Two 12" Alpine-S
Infinity Kappa Components (front)
Alpine MRV-F340 4-Channel Amp
Alpine IVA-W200 Headunit
Alpine 6X9's (Rear)
Autotek 750.1 Class-D Mono Amp
Brembo Rear Bradi Front X/Slotted Rotors
H&R Springs Koni Shocks suspension
Python 4600HP Security System
17" TL Type-S on 225/45/17
Tint: 28% in the front 15% in the rear
Ranger Joe Short Shifter
SR5GUY Chipped ECU
xkazman is offline
Old 08-02-05, 10:08 AM   #2 (permalink)
Car 1: 05 Pilot EXL-RES, 03 TL-S nav
ill keep that in mind.
have u ever changed out ur tranny mounts?
stick is offline
Old 08-02-05, 10:09 AM   #3 (permalink)
xkazman's Avatar
Yep the rear mount
Mods:
Custom Ported Box
Two 12" Alpine-S
Alpine 6X9's (Rear)
SR5GUY Chipped ECU
xkazman is offline
Old 08-02-05, 10:31 AM   #4 (permalink)
B+O
The Mac vs. The Mack
B+O's Avatar
Car 1: why?
Send a message via AIM to B+O
yea...i found out through trial and error that Acura Parts department is full of chit.
"your strainer doesn't have to be replaced" is a true falsehood. it's a really fine screen and can get clogged pretty easy.
wild...thanks for post
B+O is offline
Old 08-02-05, 10:43 AM   #5 (permalink)
Originally Posted by xkazman
Yep the rear mount
did u notice a difference after doing that?
i think mine needs to be changed asap.
stick is offline
Old 08-02-05, 10:45 AM   #6 (permalink)
xkazman's Avatar
It would jerk really hard from Park to drive/reverse. I change my tranny (rear) and fixed the problem. I didn't notice it while I was driving.
Mods:
Custom Ported Box
Two 12" Alpine-S
Alpine 6X9's (Rear)
SR5GUY Chipped ECU
xkazman is offline
Old 08-02-05, 10:49 AM   #7 (permalink)
Yup i have the same problem too.
also when it shifts from 1st to 2nd i get that jerking feeling.
mine is an auto.
stick is offline
Old 08-02-05, 01:29 PM   #8 (permalink)
Car 1: 1992 Seden L Seattle Silver
Changed my strainer
Amen to that. I thought my tranny was toast a few months back because it would slip out of gear and just revved. Replacing the strainer fixed it. Do a search for specifics...
MikeTn is offline
Old 08-02-05, 01:38 PM   #9 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
Amen--the only people who claim the strainer doesn't have to be replaced are Honda technicians and lazy forum members.
Check out my DIY:
DIY Transmission Service (Filter + Drain)
k.
P.S.
Don't listen to the morons who spread false rumors that the aftermarket filters are paper.
mrkeith is offline
Old 08-02-05, 02:27 PM   #10 (permalink)
Car 1: 1995 Acura Legend GS
i replaced mine but dident nodice any smoother shifting but mine wasent slipping so who knows
144,000
My ride
Roger is offline
Old 08-02-05, 02:32 PM   #11 (permalink)
xkazman's Avatar
Yeah I didn't notice smoother shifting, but at least now all my gears shift propperly. It's pretty embarrassing when it your speeding up and seems like your driving in neutral.
Mods:
Custom Ported Box
Two 12" Alpine-S
Alpine 6X9's (Rear)
SR5GUY Chipped ECU
xkazman is offline
Old 08-02-05, 03:07 PM   #12 (permalink)
Faster than yo Legend son
DrWho's Avatar
Car 1: 91 acura legend 4dr blck on blck
Car 2: 96 Chevy Tahoe 4x4
mean to tell me I put a anoter trans in for nothing.. mine was doing that off and on for over a year well now at least I don't have to worry about it. Didn't want to spend any more money on that if it wasn't the problem so I just got another JDM trans..
black on black 4 door LS
rareessence.com
mad races and stupid stuff
allhiphop.com
I endorse: when I endorse its like ceritified gold!
Nanowax - bring out the luster in your paint.
Duralube fuel injector cleaner - one of the best for under $20
DrWho is offline
Old 08-02-05, 03:16 PM   #13 (permalink)
xkazman's Avatar
It's a great $35 fix
Mods:
Custom Ported Box
Two 12" Alpine-S
Alpine 6X9's (Rear)
SR5GUY Chipped ECU
xkazman is offline
Old 08-02-05, 10:18 PM   #14 (permalink)
About to pass you again!
C-Dog 91LS's Avatar
Car 1: 1991 Vineyard Gray LS KA7
Car 2: 1997 Chevy 1500 WT
Did you do it ypurself or pay someone?
Check me out at:
http://www.cardomain.com/ride/833911
C-Dog 91LS is offline
Old 08-02-05, 11:35 PM   #15 (permalink)
Car 1: 1992 LS Sedan - 3.5
how would you know if you just needed to replace the strainer or if its your flexplate?
FallenAngel is offline
OK.. Tranny Problems 101 gumby_smiles First Generation Legend (1986-1990) 61 06-19-07 11:11 PM
Tranny just starting to slip biyonic First Generation Legend (1986-1990) 7 12-16-04 10:47 AM
Need help with auto tranny please read. Kai First Generation Legend (1986-1990) 11 03-20-04 09:34 PM
6-speed tranny being rebuilt theGodfather Engine & Performance Modifications 29 02-27-04 04:01 PM
Japanese Tranny and US differential (gear oil leak) dap0901 Second Generation Legend (1991-1995) 5 01-13-04 02:25 PM
