Old 05-16-07, 09:37 PM   #1 (permalink)
contact148's Avatar
Car 1: 1993 legend
Car 2: 1995 neon
Car 3: 1946 willys CJ2A
door locks not working right??
Just got a 93 legend and noticed that when useing the key to unlock the drivers door it unlocks ONLY that door BUT when useing key to unlock/lock the pass door it unlocks/locks ALL doors
IS the drivers door supposed to do all doors?
the alarm is disconected
Oh and were there supposed to be remotes for unlocking this car? (i dont have any)
contact148 is offline
Old 05-16-07, 10:03 PM   #2 (permalink)
9-1
93LegendSedan's Avatar
Car 1: 1993 Legend Sedan
Car 2: 2002 LS430
Car 3: 2008 Highlander
I was under the impression that the drivers door using the key would unlock all the other doors, I would assume also the passenger door also would only open the passenger door.
But I haven't used the keys to unlock or lock in a while, sorry man.
The keyless entry doesn't usually come with the car no, but you can have it installed for the keyless entry.
There is a keyless entry that was OEM, but it is hard to find and if found, all the pieces together often are also hard. I'd reccomend going the other rout and just getting a generic one somewhere else.
93LegendSedan is offline
Old 05-28-07, 01:26 AM   #3 (permalink)
blklgnd21's Avatar
Car 1: 1993 Acura Legend coupe
Send a message via Yahoo to blklgnd21
mine does that as well
blklgnd21
blklgnd21 is offline
Old 05-28-07, 01:34 AM   #4 (permalink)
i paid 500 for my 95 gs
jjazzy016's Avatar
Car 1: 1989 chrysler lebaron turbo
Car 2: 1995 acura legend gs
Send a message via AIM to jjazzy016 Send a message via Yahoo to jjazzy016
well this is for safetey, so that you dont get hi jacked trying to goto work in morning, school at night, they figur that if you open from the drivers side then you will not let any unwanted people in like say if your running to the car from a ugly vigor driver, that wants to kill you, you can just hop in with no worrie, but if it unlocked all the doors you would be jumping in with the ugly vigor driver. the passenger opens like that because they figure, your not the driver so your not about to drive away, so they say unlock all, so its just to protect the driver.
two things i love, ha ha my girl and car
jjazzy016 is offline
Old 05-28-07, 01:35 AM   #5 (permalink)
On a Mission.
Philendrick's Avatar
Car 1: 2001 Acura CL-S
Car 2: 94 Legend L Coupe
Send a message via ICQ to Philendrick Send a message via AIM to Philendrick Send a message via Yahoo to Philendrick
Perfectly Normal. It seems like there is a way to unlock the passenger door as well?? I can't recall. Does anyone have a manual they can check?
Philip
2001 CL-S
94 Legend L Coupe (To Be Restored)
94 Legend LS Coupe (Sold & Missed)
"Remain respectable in everything that you do, to earn the respect of others, and to learn to respect yourself."
Philendrick is offline
Old 05-28-07, 01:35 AM   #6 (permalink)
jjazzy016's Avatar
and if you want to unlock all doors from the drivers side just hold the key after you turn, it will open up like magic,
Old 05-28-07, 01:41 AM   #7 (permalink)
jjazzy016's Avatar
that should solve all the door lock problems for this thread, and ahh,philendrick read my last post dont worry i got ya.
Old 03-05-08, 05:11 PM   #8 (permalink)
Car 1: 1991 Acura Legend LS sedan
Car 2: 1987 Acura Legend Cp
Car 3: 2003 Acura TL
I have a 91 LS sedan and I have the same problem/question.
I have no problems with locks cycling and no problems with the factory alarm.
When I use the key to unlock the driver side door it will unlock only that door. Holding the key will not unlock all the doors. The key will lock all the doors.
On the passenger side the key will unlock and lock all the doors.
On my 03 TL, the key in the driver side door will unlock just the one door and all the doors if I hold the key for about 1 second longer.
Since I bought the 91 LS used I do not know if the unlock all door (usually called central locking) feature is supposed to work as it does on the 03 TL and many other cars that have central locking.
Anybody know?
Thanks.
ronrhodes is offline
Old 03-06-08, 06:26 PM   #9 (permalink)
Anybody? Nobody?
The service manual is not clear. As it appears in the wiring diagram, it seems that this feature is not available on US cars.
Please will somebody stick their key in the driver side door and try to unlock all the doors using the key.
Thanks
Old 03-06-08, 06:34 PM   #10 (permalink)
dasficktauf's Avatar
Car 1: 1992 ka7 auto with 250k miles
Car 2: 1985 nissan sentra
hey ronrhodes, i tried the holding the key trick on my 92 ls sedan and it didn't work. i can unlock all 4 from passenger door, or unlock only drivers side from drivers door.
must just be the safety issue
1992 Frost White Honda Legend LS
262k
Re-badged (including jdm grill),ebay clear corners,DIY Black interior swap ( 40% ),Painted valve covers and stock strut bar,Pioneer deh-p5900ib,Elemental Designs edi6000s v.2 components,Elemental designs 11kv.2 sub,Eclipse 38hz tuned reverse bandpass,Home rebuilt 4channel runnin on 2,Home rebuilt 2channel bridged to 1,Super cool woodgrain autoshift knob,2 Piece nosemask customized to show grill,LED type 2 (160mph) gauge cluster
dasficktauf is offline
Old 03-06-08, 06:44 PM   #11 (permalink)
Thanks dasficktauf, I truly appreciate it. I guess that explains why I couldn't find anything out of the ordinary when I was troubleshooting (procedures in the service manual). I am in there now replacing the window motor.
As far as a safety feature, I guess so. But, many cars do this. As I mentioned before my 03 TL does this by holding the key (driver side).
Any rate, thanks again.
Old 03-06-08, 08:46 PM   #12 (permalink)
contact148's Avatar
Car 1: 1993 legend
Car 2: 1995 neon
this was My old thread
but since winter hit here, my door does work properly if I hold the key in the unlock position for about 3 secs it unlocks all doors works about 99% of the time now....
Old 03-07-08, 05:57 PM   #13 (permalink)
Thanks contact148, sorry about jacking your thread. I was adding that I too have the same problem/question and it seemed that we didn't have enough input on how the central locking system was actually supposed to perform. Now that your car seems to be working as well, I guess I gotta go digging for my problem.
Unless anybody else out there also has this problem with the key on the driver side door not opening all the doors.
New Premier Pioneer Headunit isn't working....Electrical problem? tkim87 Audio, Video, & Electronics 6 05-25-06 12:05 AM
New Preimer Pioneer Headunit not working...whole electrical system blown? tkim87 Second Generation Legend (1991-1995) 28 05-18-06 08:15 PM
Radio and clock not working. manxdr21 Second Generation Legend (1991-1995) 3 04-19-06 09:39 PM
Speedo and Tach Not Working! n6xr2000 Second Generation Legend (1991-1995) 9 12-07-03 12:59 AM
Help me! the steering wheel volume control stop working mocca Audio, Video, & Electronics 9 10-01-02 01:54 PM
