Old 10-30-07, 10:39 AM   #1 (permalink)
Car 1: 1993 Cashmere Legend L Sedan (bone stock)
Send a message via Yahoo to PA_Legend
"Door open" or "key in" chime stays on after key is out
I'm having a strange problem with my '93 Legend Sedan. After I take the key out of the ignition and open the door, the "door open" or "key in the ignition" chime/bell stays on until I close the door. Anyone seen this before and know what I should check? Thanks!
PA_Legend is offline
Old 10-30-07, 12:14 PM   #2 (permalink)
AKA Smartjay28
Johnny Kim's Avatar
Car 1: JDM KA7
Car 2: w203
tap on the key cylinder (where you put ure key in to start the car) your key sense might be stuck.
Johnny Kim is offline
Old 10-30-07, 12:17 PM   #3 (permalink)
Thanks. I've tried putting the key in and out a few times but that seemed to have no effect. Did you say the "key sensor"? Is that part of the ignition switch module- i.e. would I have to replace that whole module for the key sensor, or is it something I can take apart and fix?
Old 10-30-07, 03:05 PM   #4 (permalink)
Bump/\ Anyone else?
Old 10-30-07, 03:11 PM   #5 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
I would shoot myself if that thing were to never shut up hahaha...
Yeah the little pin inside the cylinder must be stuck....have you tried some graphite lube?
sam o nela is offline
Old 10-30-07, 05:14 PM   #6 (permalink)
I haven't yet. Do I just shoot it in there, or do I have to take the ignition lock cylinder apart? Anyone know how I get access to it?
Old 10-30-07, 11:07 PM   #7 (permalink)
So I sprayed a bit of lubricant into the ignition lock cylinder, and turned the key a bunch of times, and that seemed to unstick the sensor. No more bell, at least for now...
Thanks folks!
Old 10-31-07, 02:06 AM   #8 (permalink)
AKA Nicco Bellic
Car 2: 1966 Mustang
Car 3: 06 GTI 2.0 turbo
I had this problem forever. The graphite spray worked for a while, eventually of course it came back. I'm cheap, so I just cut the blue/white wire (keysense) from the ignition switch. Door dinger gone!
DevanTheDude is offline
Old 10-31-07, 02:08 AM   #9 (permalink)
9-1
93LegendSedan's Avatar
Car 1: 1993 Legend Sedan
Car 2: 2002 LS430
Car 3: 2008 Highlander
I too had this problem at a time. I just went to a local shop and payed the $25 to have it fixed.
Well worth it because of how annoying it was. And it never came back.
93LegendSedan is offline
Old 10-31-07, 08:32 AM   #10 (permalink)
What did the shop fix exactly?
Old 11-09-07, 05:41 PM   #11 (permalink)
RALPHS HANDS ARE CLEAN!
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
I'm bumping this thread up, cause I've had this problem forever. I looked at the wires coming off my ignition switch, cause DEVANTHE DUDE said in post #8 to cut the blue/white wire. Well, I don't have a blue/white wire coming off the ign switch.
my question is this:
If I cut the blue/white in this diagram, is this the same wire?
Anyone, help, this beeper is making me insane, (as if I wasn't before).
blkonblkcpe is offline
Old 11-10-07, 04:50 AM   #12 (permalink)
2002 3.5 w/ TII cams!
BlackAc92's Avatar
Car 1: 1992 Legend L Ka8
Car 2: 95 Intrepid..fam car
Car 3: 1992 Legend LS Ka7
Yeah i have this same problem too and it drives me fuckin nuts. I tried powder graphite to no avail. I will try some silicone spray next.
Will this possibly solve my cars problem of not being able to lock the doors with the doors open? Or am i gonna hafta dig into the lock actuators?
http://i175.photobucket.com/albums/w...P1010015-1.jpg
-The 3.5 is in and puuuurrin!!!
-Now to the body work ...sigh
Found and welded in a BEAutiful quarter panel... The whip is gettin therr
F.S.:
1) TCS Unit from my 2002 RL engine,
2) 1999 and 2002 RL wiring harnesses and 12 coil packs.
3) 99 RL Differential
BlackAc92 is offline
Old 11-10-07, 09:55 AM   #13 (permalink)
C'mon, someone must know. Can I cut the blue/white, or not!
Old 11-10-07, 10:43 AM   #14 (permalink)
I actually used WD-40 and then turned the key a bunch of times.
The utimate fix would be to get a new ignition lock cylinder and have it re-keyed by a locksmith I suppose.
driver side door lock paddle switch won't lock with door open FiveSpeed Second Generation Legend (1991-1995) 9 01-31-07 01:29 PM
Door Open Chime ladelberg First Generation Legend (1986-1990) 8 11-19-04 01:10 PM
Electrical,no Front Parking Lights,nointermitent Wipres,no Door Chime,no Dash Clock,n MIJERZACK-U-RAW Second Generation Legend (1991-1995) 1 07-29-04 03:33 PM
Where is that damn door chime!?! I want to disconnect it... slugman First Generation Legend (1986-1990) 7 08-05-03 11:50 AM
Door stays lock, even after closes door?? Volk Racing Second Generation Legend (1991-1995) 19 07-11-03 12:18 AM
