Door panel removal - The Acura Legend & Acura RL Forum
Old 08-05-08, 12:43 AM   #1 (permalink)
Door panel removal
well my passenger door has some problems from one of my friends constantly slamming it shut. she seems to think that a push-off to a running start is necessary to shut the doors...
either way the window is jacked and makes horrible sounds when rolling down and i now have custom door suckers (door won't stay open on it's own, it shuts no matter what even though it will open 100%)
i've searched around and i found this
DIY - Door Lock Actuator Fix
DIY for the door lock actuator, which shows somewhat how to take the door panels off. i have to fix that as well, while i'm at it but i was wondering if there is anything else i should know or tips when i take the panels off so that i don't ruin anything.
231k is offline   Reply With Quote
Old 08-05-08, 12:52 AM   #2 (permalink)
blackbird69's Avatar
Car 1: 1991 acura legend coupe
Car 2: 2009 acura tsx
Send a message via AIM to blackbird69 Send a message via MSN to blackbird69 Send a message via Yahoo to blackbird69
just take the screws off, pull off where all the clips come off, pull up over the lock now, very simple thing
Yea... Money comes, money goes, its the life of a guy who loves his car so much that he puts all money into it, even risking being single
blackbird69 is offline   Reply With Quote
Old 03-18-10, 06:39 PM   #3 (permalink)
Car 1: 2000 Acura RL
hi guys, i also now need to replace my passenger side door and bought the same color door shell on ebay. I need to put the panel of the original door to this one. I am wondering how to start this. would appreciate any suggestions
acurarl2000 is offline   Reply With Quote
Old 03-19-10, 04:49 PM   #4 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
Car 3: 93LS 6spdgraycpe 3.5
acural2000; on March 8 AFKMONE asked a similar question on org site. A reply
provided the wiki DIY. If you care to search for that post; I think you will find it
very helpful.
Old 03-19-10, 07:52 PM   #5 (permalink)
ari_one's Avatar
Car 1: 1993 Legend 6-spd
Car 2: 2004 Tahoe
iTrader Score: 63 reviews
Just be careful when you remove the handle that opens the door, there is a screw on the back side and if you are not careful you will break the handle. There are two screws behind the plastic plate on door handle and two screws on the bottom of the arm rest (on sedans). I'm assuming here that you are doing this on a G2 Legend and not on an RL.
Old 03-23-10, 06:10 PM   #6 (permalink)
hi guys, thank you for your help. i have replaced fr. pass. door and moved all inside stuffs into newly bought door shell. and now i am having really hard time - the glass not rolling at all. the regulator's motor is working i suppose as it is giving a noise when i switch to roll up or down. any suggestions would be appreciated
Old 03-24-10, 12:57 AM   #7 (permalink)
ari_one's Avatar
Car 2: 2004 Tahoe
Not much we can help without seeing it. When I install a window I always first move the window up and down to make sure it moves easily before attaching it to the regulator. Then before putting the panel on I use a battery to run the window up and down a few times to make sure everything also works. If it is having a hard time then to me that would point to it not being in the tracks correctly or not aligned right (I also always mark the position of the bolts with a marker before removing the regulator).
