Driver side window?? - The Acura Legend & Acura RL Forum
Old 11-27-12, 11:42 AM   #1 (permalink)
DGR
DGR's Avatar
Car 1: 94 Acura Legend blk/blk
My driver side window leaves a gap when rolled all the way up its kind of annoy😤😤!!.. Any tips for fixes anyone
Thanks in advance..
Sent from my iPhone using AutoGuide.com Free App
DGR is offline   Reply With Quote
Old 11-27-12, 02:37 PM   #2 (permalink)
AZpartsGuy
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1998 Civic EX
Car 3: 95 ZX-7
iTrader Score: 63 reviews
My guess is that the regulator has bent or missing teeth at the end, only way to know for sure would be to take a look.
Old 11-28-12, 06:17 PM   #3 (permalink)
Car 1: Acura Legend LS 1994
I would say its the regulator. This happened to me as well. Went to junk yard to get a used regulator.
sd168 is offline   Reply With Quote
Old 11-30-12, 09:38 PM   #4 (permalink)
Car 1: 91 Legend Coupe
This is a common issue with these doors. Roll the window all the way down, take the door panel out and tighten the two screws in the center. I think it might be a #8 or #10. Once they are tighten put it back together and check. I can't honestly tell you exactly where but I would start tightening some bolts.
Vampire is offline   Reply With Quote
Old 11-30-12, 09:52 PM   #5 (permalink)
The_Best's Avatar
Car 1: 91 Acura Legend
Before you do anything spray some silicone in the run channel. Its the rubber piece that goes along the window. Just spray the bottom portion and go from there
Proud Acuraholiks Member
8000k Hid/ Smoked Taillights/ Led Corners & Drls
20'' EB Street rims/Tuner Locks
Kenwood Head Unit-Kenwood&Pioneer Highs/Q Tweets
Custom Interior Lights
Painted Valve Covers & Intake Mani <<<
The_Best is offline   Reply With Quote
Old 12-01-12, 01:40 PM   #6 (permalink)
Car 1: '92 Acura Legend LS
After you lube, and it still leaves a gap, there is an adjustment screw for the regulator. It's a 10mm bolt with hash marks in either side of it, about an inch long, in approximately the center of the door. (Sorry, no pic). This adjustment will tilt the window, slightly, forward and backward so that the window can slide straight up and down.
Sent from my iPhone using AutoGuide.com App
My "free" 92 LS
Old 12-03-12, 05:34 PM   #7 (permalink)
DGR
DGR's Avatar
Thanks I had to clean the windows forgot I had rip the tints off kept getting stop by the cops lol tints where 31% cops said on it which was bs windows are still sticky it's fixed now
Old 02-09-13, 11:43 PM   #8 (permalink)
DGR
DGR's Avatar
Fixed it just sprayed some silicone on the rubber guides of the window
Sent from AutoGuide.com Free App
