werd.....
Dyno Results.....CAI tested vs Stock Airbox
Alright, well I went to the dyno today, mostly to check the difference between the stock airbox and the CAI that I make. The stock air box did NOT have the resonator attached, so the ratings would have been a little bit worse for the stock one.
My CAI peak power is 167.3 @ 5300rpm My CAI peak torque is 177.1 @ 4300rpm Stock airbox peak power is 166.6 @ 5300rpm Stock airbox peak torque is 173.2 @ 4500rpm That is top end. On both sides, the power/torque drop off VERY rapidly after the peaks. Horsepower stays up all the way, but tq is basically dead at redline for type 1s. We have about 70tq at that time. For you type 1 manual people, you need to shift at around 5700 rpm to stay in your max power. I am going to test my car again at the track, with this meathod to see what kind of difference I get. The LOW end of this, the differences are ASTONISHING. at 3200rpm, the difference is 21.4tq, and 13hp. at 4000rpm the difference is 13tq and 8hp. This makes sense though, because of the VIS. The stock airbox had some very bad drops on power however. It had a 20tq drop at 3000rpm, and between 3600 and 4000, it goes down again. Horsepower also drops at 3000rpm. With the CAI. There really isnt a major drop in tq, at 3700, it goes down 3-4tq, and then keeps going up. Horsepower is VERY linear throughout the entire test. Also, I had the A/F ratio checked, and the CAI did not make the car run rich at all. The two graphed lines for CAI and stock airbox are intertwined throughout the tests. I am going to get a spreadsheet tomorrow of the differences in each space, but I will try to scan the graph this evening. I will let you all know very soon, I am going to get a Y pipe made within a few weeks, and will update to say the gains for it. GALLERY AT TULSA DYNO SITE Alright, you might be able to see behind the MAX POWER part, it says 172.8 or something like that. ![]() CLICK HERE IF YOU WANT TO SEE THE FULL SIZED PIC Last edited by RangerJoe : 12-06-03 at 03:03 PM. |
Legend Lover
Car 1: 1992 Cashmere Silver L (My 1st Love) Car 2: 2000 RL Midnight Blu Car 3: 1995 Range Rover LWB iTrader: (0)
Thats great. Thanks for the info.
Do you have photos of your cai? I would to see how you made it. Thanks again.
Exterior mods; 18 in Erotica wheels, Falken Tires, Koni Shocks, Intrax Springs, Power Slot front and rear rotors, Axxis Brake pad (all four corners), OEM Moonroof visor, 5300K hid's, Ingalls 35550, Moonroof Tilt Mod Engine mods; Custom grounding wires, Denzo Platinum plugs, Dv8 Short Ram Intake (Thanks Nupe07) I.C.E. Sony head unit and 10 disc changer, 3 Precision Power Amplifiers, MB Quarts Coaxial, Audio Control EQX and ESP 2, Pyle 3 farad stiffening capacitor, 100 sq ft. of Fat Mat, Stinger Expert Series battery terminals With built-in voltage meter, 200 amp circuit breaker 3 10 in Hifonics woofers FOR SALE All protected by Code Alarm and a Beretta 9mm Future Mods; Remus cat back, Optima Yellow battery, Custom Battery tie down, Shaved trunk and grill, Leather, Stainless Steel brake lines |
werd.....
Pictures can be found on my webiste. http://g2legend.com
Picture page with cai is http://g2legend.com/index2.htm The picture at the bottom of the index2 page is a semi gloss powdercoated intake. That was the 2nd version of the kit, which had a better design on the piping. |
Honda 4 L*fe
finally some cold hard numbers.
thanks for sharing dude. btw, is that really your Busa?
SOLD 8/04 http://www.imagestation.com/picture/...9/f845a19c.jpg For: 2005 RSX Type S http://www.imagestation.com/picture/...5/f0e39493.jpg |
Ranger
what other mods you have done? 167hp is pretty low for a TYPE I with CAI, Although your TQ is high. Tru Hybrid
Re: Dyno Results.....CAI tested vs Stock Airbox
My CAI peak power is 167.3 @ 4500rpm
My CAI peak torque is 177.1 @ 5400rpm Stock airbox peak power is 166.6 @ 4500rpm Stock airbox peak torque is 173.2 @ 5300rpm arent those numbers really close? it seams like you gained (by looking at those numbers) a total .7 horse in power and 3.9 in torque? whats up with that?
"True Legend Enthusiast In PHX" ziver@affordablekiosks.com |
werd.....
that is top end ONLY remember. Ill post up the graph pretty soon. Top end is really not very important, esp the peak horsepower. because you are shifting at the peak, or right after peak. the largest gains are at the lower RPMS where the car upshifts to.
there is only a 1hp gain at 5500rpm, but theres a 15hp gain at 3500rpm, or 4000rpm. which is where your car will start at with the next gear. |
RangerJoe I'm very interested in your CAI, do you have a picture of what it would look like in red, or maybe silver if possible? Also does it turn your check engine light on? I'm not sure if having all the lines disconnected will affect my car, because it has TCS. I can't wait to see your dyno graph. Some more lowend would be nice!
Looking to Buy: Legend-Specific Remus http://home.wideopenwest.com/~lcorte...signature5.jpg » Latest pictures of my Coupe -- Leon's G2 FAQ -- G2 Stereo FAQ -- Forum Rules « |
K L E A N M O D™
Wow if it was an increase of 15 hp in the low end on a Type I w/ just CAI & Exhaust I wonder what my
Type II w/ CAI Y Pipe B Pipe Exhaust Stage II Chip will do.... Good info Joe... ![]()
-1995 KA8 MODIFIED-R.I.P -1997 S14a-SOLD -2000 Millenia S -1995.8 S14a -Holy Rollerz CCC Member- -Inspiration™- My KA8's totaled and still greater than.... Imitatated. Never duplicated.™ |
#14 (permalink) |
werd.....
No. My check engine light has NEVER come on. As you will see in the graph, it will not change your A/F ratio at all. I do not have a pic of what it would look like in red, all of my orders thus far have been for black ones. You can however choose between what kind of coating you would have. You can do high gloss powdercoating, semi gloss, or a flat color. Flat still is shiny, just not very much. On my website, on the parts page, the black one at the bottom in the pics is a semi gloss, and if you AIM me, or email me, I can send you a pic of what the high gloss looks like. Changing those hoses really dont make any difference, You are still getting air through those breathers, and the air is still going to be clean, so it doesnt really matter if you have the hoses on the intake, or the separate tubes.
#15 (permalink) |
Sexy Member
Phillip
MAD PROPS BRO great work!!! everyone his name is not JOE lol -hass
RIP ZAK ![]() <----master of the unibrow Im carrying Darriths baby -da hass man http://www.acura-legend.com/gallery/file.php?n=169&w=l 91 L sedan- few mods 94 Gs- sold 97 Sc300-stock for now |
