ECU CODES 92 Legend - The Acura Legend & Acura RL Forum
Old 07-19-05, 02:53 PM   #1 (permalink)
Car 1: co
ECU CODES 92 Legend
OK I am an idiot. I cannot find the connector under the dash on the passanger side. Any suggestions?
papaaj is offline   Reply With Quote
Old 07-19-05, 04:51 PM   #2 (permalink)
Car 1: co
Mike,
Thanks a million, I found it. Now when I jump the connecter my check engine light just stays on and does not blink. Any suggestions?
John
Old 07-19-05, 05:04 PM   #3 (permalink)
Car 1: co
No I did not get the codes, the engine light just stays on.
Old 07-20-05, 01:24 PM   #4 (permalink)
Car 1: co
Mike,
It seems I reset my ECU when I disconneted the battery. I have restarted the car but the CEL has not come back on. The problem I am having is engine ping, lack of power and most scary oil in air cleaner. Also, it started smoking (white) out the exaust and air cleaner.
Thanks
John
Old 07-21-05, 02:10 PM   #5 (permalink)
Car 1: co
The reason I needed to access the error codes was in hopes to solve the problem of lack of power, valve pinging, stalling and now the smoke. When I jump the ECU connector my CEL does not blink. I am assuming the ECU was reset when I disconnect the battery. The CEL has not come on since disconnecting the battery, but my lack of power, stalling is still happening. My Legend has 160k miles and I have not replaced the 02 sensors.
Old 07-21-05, 02:37 PM   #6 (permalink)
Car 1: 93 acura legend l series
Send a message via AIM to LEGEND718 Send a message via MSN to LEGEND718
good
i needed that post to check my own engin light
LEGEND718 is offline   Reply With Quote
Old 11-09-05, 10:26 AM   #7 (permalink)
Does Anyone Has The Codes For The Check Light Reading On The Ecu, Or Alink Or Something
Old 11-09-05, 12:43 PM   #8 (permalink)
EDM Honda Legend Coupe
Car 1: '95 EDM Legend Coupe
Post ECU Codes & Their Meanings
Code / Explanation
1 => Oxygen Sensor, Left
2 => Oxygen Sensor, Right
3 => Manifold Absolute Pressure Sensor (MAP)
4 => Crank Angle Sensor No 1
5 => Manifold Absolute Pressure Sensor (MAP)
6 => Coolant Temperature Sensor (TW)
7 => Throttle Angle Sensor (TAS)
9 => Cylinder No 1 Position (1st Sensor)
10 => Intake Temperature Sensor (TA)
11 => Idle Mixture Adjustment Sensor (IMA) (w/o CATA)
12 => EGR Sensor
13 => Atmospheric Pressure Sensor (PA)
14 => Electronic Idle Control Module (ICM)
15 => Ignition Output Signal
16 => Fuel Injector
17 => Vehicle Speed Sensor (VSS)
18 => Ignition Timing Adjustment
23 => Knock Sensor, Left
41 => Oxygen Sensor Heater, Left
42 => Oxygen Sensor Heater, Right
43 => Fuel Supply System, Left
44 => Fuel Supply System, Right
45 => Fuel Metering, Left
46 => Fuel Metering, Right
53 => Knock Sensor, Right
54 => Crank Angle Sensor No 2
59 => Cylinder No 2 Position (2nd Sensor)
More explanations of sensors, locations and its functions coming soon in the DIY forum -Mike
Old 11-09-05, 02:21 PM   #9 (permalink)
Thanks Mike D Your A Life Saver As Usual
You know you own a legend when.... Cole Austin The Lounge 115 01-12-07 01:56 PM
ECU Codes - blinks 3, mechanic says 30 90LS90 First Generation Legend (1986-1990) 12 07-14-05 01:00 AM
Found ECU upgrade..Tell me what you think.... Gunrman Engine & Performance Modifications 7 04-11-04 11:31 PM
G2 Legend ECU on ebay KNLNGUS OEM Parts 2 10-05-03 01:12 PM
