Old 07-09-02, 11:36 PM   #1 (permalink)
SID
!'m Overhea7!ns' b!7*h
SID's Avatar
Car 1: 1992 Desert Ice Sedan
Send a message via ICQ to SID Send a message via AIM to SID Send a message via Yahoo to SID
Question Electrical Wiz's LED help plz
Ok, i've taken apart my stock, driverside door security light in hopes to install an bright white blinker instead of the dim red. In doing so I've seem to run into a problem. First and simplest, I lost the little part that actually says security in-which the led is held to. Second, I think I have to remake the wiring harness for it which included a resistor to lower the voltage I assume since the red LED is a 3 volt.
So if electrical wiz out there can help answer, please do. Basically I need to know is what resistor should I use in rebuilding it if my new LED is a 6 volt. I kind of assume that the power passing through the wire before the resistor is 12v but using a volt meter and got screwed up. I think I recall it bliping from about 0 to 0.3v...which I think i wrong.
If someone can help me with my other problem of missing the security plate which is brown. Help as in maybe you have one on hand and I could buy it from you, I'd madly appreciate it.
I know we all come from different backgrounds, and jobs....so, in hopes this will help me and any and all who wanna do the same.
SID :cool:
SID is offline
