Old 09-27-07, 07:13 PM   #1 (permalink)
Cranberry_Legend's Avatar
Car 1: 1991 Legend
Question engine damper
Iam not a big performance mod type of person..Ill go as far as an intake or a chip...but I like my car to run smooth and quiet...I hear a lot of ppl talking bout engine damper and I have no clue wat that is..if someone can xplain some details on that i would apreciate it..thanks...
Cranberry_Legend is offline
Old 09-27-07, 07:26 PM   #2 (permalink)
Blackend Motorsports
Blackend's Avatar
Car 1: Blackend Motorsports
Car 2: 1995 LS Coupe
Let me take a stab at this one
When the engine rocks under load (like when you mash the gas to the floor) you're loosing that torque because it's absorbed in the rubber engine/transmission mounts. That creates a lag between the time you smash the gas, and the car reacts...not much, but about a second from what I can remember on my car.
The engine damper works like a standard shock absorber, but a VERY stiff one. It bolts to the engine, and then to the firewall and it keeps the engine in it's place, and doesn't allow it to rock in its mounts.
What you gain, is much improved throttle response which means quicker acceleration (especially from a stop or coming out of a turn under throttle.) It should also improve the life of the rubber engine mounts, and transmission mounts because the movement is limited. That hasn't been confirmed yet because these damper kits are fairly new and I don't think anybody has driven the 30K miles or so that it usually takes to break a rear tranny mount.
Let me know if you have anymore questions. I'm kinda like an expert on them now!
NALM NAZI
Originally Posted by Searchin4acoupe View Post
I'll be sure and tell my daughter tomorrow morning after she finishes breakfast that she has coffee piss breath. She's 6. She's gunna be like WTF dad, that's effed up.
Blackend is offline
Old 09-27-07, 07:32 PM   #3 (permalink)
Car 1: 1991 Legend
thanks blackend..i have a few more...how big of a difference does it give? how hard is it to install? (u have to take the engine out?)..thanks i apreciate it..
Old 09-27-07, 07:44 PM   #4 (permalink)
Blackend's Avatar
I'll let some others comment about the difference since I don't want to sound like I'm hyping up my product too much!
Fairly easy install as well. You need some bigger wrenches like a 17mm and a 19mm but there are detailed instructions with every kit that include pictures. And no, you don't have to take the entire engine out. In fact, there is only the OEM strut bar and one bracket that have to be removed, everything else just bolts in.
NALM NAZI
Blackend is offline
Old 09-28-07, 01:04 AM   #5 (permalink)
Car 1: 1991 Legend
thanx...very helpfull...how much they go for?
Old 09-28-07, 01:07 AM   #6 (permalink)
4 ALL UR TESTIN SUPPLIEZ
Double Glow's Avatar
Car 1: 94 Legend L Sedan
Car 2: 94 Honda Civic Dx
Car 3: 1986 Toyota Van
Send a message via AIM to Double Glow
Group Buy in the marketplace...Ends Oct. 2nd. get in quick!
PM Me About Custom Red/Clear/Red Sedan Taillights $500, or $425 with Deposit.
Parting Out 1993 L Sedan, Black - PM Me
Double Glow is offline
Old 09-28-07, 01:20 AM   #7 (permalink)
Of the Telion Chip
Telion's Avatar
Car 2: White 91 KA8 JDM TII
And being that you mentioned chip I will be ready when you are
Telion is offline
Old 09-28-07, 04:59 AM   #8 (permalink)
MAD DOG!
dgandul's Avatar
Car 2: 92 LEGEND LS
lol... shameless thread... hey if it works you guys have the right to
dgandul is offline
Old 09-28-07, 06:15 AM   #9 (permalink)
Yuka.Blue.
FF Drifter's Avatar
I've a few questions:
-does installing the engine damper require any drilling or any equipment beyond simple tools?
-does the engine damper put extra strain on the firewall that may cause problems in the long run?
More info please =)
FF Drifter is offline
Old 09-28-07, 09:29 AM   #10 (permalink)
Car 1: 1991 Legend
Lightbulb
lol....pm sent...
Old 09-28-07, 10:19 AM   #11 (permalink)
Blackend's Avatar
More info please =)
No drilling required, and no special tools required. The damper comes set up at the suggested settings, but if more or less dampening is desired, there are some bigger wrenches you'll need to get it adjusted.
Essentially, my wrench set now includes the following that are needed to install, or modify the engine damper kit that I sell:
10mm
17mm (x2)
19mm (x2)
21mm
1/2"
15/16"
1 1/16"
In desiging this kit, I was concerned that the firewall mounting points wouldn't be strong enough, and would bend over time, but I was assured that they would work. I've measured the gap between the firewall and the engine no less than 5 times since I've had the first prototype on (over 5 months) and it hasn't moved - even with me beating the crap out of it when testing the prototype, and then a track day at the NALM in Vegas and another Autox event. I think that unless you're making close to 400 at the wheels, it shouldn't be a problem.........but when I get there, I'll let you know!
NALM NAZI
Blackend is offline
G2 Engine Damper Group Buy 9.4.2007 Blackend Group Buys 266 05-18-08 04:33 PM
G2 Acura Legend Engine Damper Group Buy Blackend Group Buys 389 09-29-07 12:48 PM
Interest In A 2nd Engine Damper Group Buy? Blackend Engine & Performance Modifications 76 09-04-07 02:43 PM
Engine Damper Color Poll Blackend Engine & Performance Modifications 41 05-08-07 05:18 PM
Legend Spec Engine Damper... Blackend Engine & Performance Modifications 252 05-08-07 05:17 PM
