extension shaft puller - The Acura Legend & Acura RL Forum
Old 01-21-09, 11:40 PM   #1 (permalink)
Question extension shaft puller
Can this tool be purchased anywhere other than the dealer? What doe this tool do?Almost done with the removal of the transmission and i need some tips(this job looked easy on paper so any tips would be helpful).
tinojr is offline   Reply With Quote
Old 01-22-09, 01:00 AM   #2 (permalink)
ari_one's Avatar
Car 1: 1993 Legend 6-spd
Car 2: 2004 Tahoe
iTrader Score: 63 reviews
In the DIY section believe there is a diy on differential replacement and shows what was used instead of the extension shaft removal tool. Don't have any other inputs as all the tranny's I've removed I've done after removing the engine and tranny from the car (and in those cases I never remove that but it may cause a clearance problem for you).
Old 03-20-09, 11:45 AM   #3 (permalink)
Car 1: 91 Acura Legend Coupe
I need to know this as well. Searched and nothing. Posted a thread and nothing so far.
ekguy is offline   Reply With Quote
Old 03-20-09, 02:57 PM   #4 (permalink)
ari_one's Avatar
Car 2: 2004 Tahoe
I went to the DIY section and typed "differential" into the search box and this is one of the links that was found: Differential Pinion Seal Replacement DIY - Done! DL it here! In the first post is a link to down load the full DIY document including how to get around not using the special tool!
