Old 04-25-03, 12:02 AM   #61 (permalink)
*has*ng w*nd
Car 1: zenki=funner
Did you mean it stumbled while you're actually DRIVING the car or while you were revving the motor in Neutral?
Nathan_Rd is offline
Old 04-25-03, 12:28 AM   #62 (permalink)
"the Don"
theGodfather's Avatar
It stumbled on IDLE when I applied vacuum to OPEN the EGR valve. Sometimes it stumbled, sometimes it completely stalled which is perfectly normal behaviour for an operational EGR system.
G
1995 Legend Coupe 6-speed
208 WHP @ 6250 RPM
189 FT/LB @ 5250 RPM
MUSTANG Dyno
260,000mi and counting
theGodfather is offline
Old 04-25-03, 03:53 AM   #63 (permalink)
*has*ng w*nd
Car 1: zenki=funner
Well see if you can get a reading on the vac gauge while driving the car. T in that gauge and go for a drive with the gauge duct-taped to the windshield. If it shows 0" of vacuum while you doing 15-25mph then that explains the NOx problem.
Old 04-25-03, 07:14 PM   #64 (permalink)
"the Don"
Nathan, you are pretty much on the right track.
Today I ran the car on the dyno again and cleaning the fuel injectors made absolutely no difference to emissions.
We took the cover off the EGR controlling components and started checking vacuum levels and making the car stall. Everything seemed to work fine except when having the vacuum gauge atatched to the hose that controls the EGR valve, on reving the engine we get 8-9 in of vacuum for 2 seconds and then it drops. I always thought this was fine that the valve will open adn close depending on load and RPM.
My mechanic put the car on the dyno to do a 26mph run and he put a T-connector to get a gauge in there. Under load the EGR system will apply 9in of vacuum to the vavle for 2 seconds and then drop to no vacuum. Only way to get it back is to put it into neutral and rev it back into gear and it will repeat the same thing.
The system is not holding the vacuum. He said the EGR valve should be open during the entire time the car is running 26mph in 3rd gear (about 2600RPM).
He ran a test with the EGR valve about 40% open the entire time (using hte vacuum pump bypassing hte control system) and NOx levels dropped to 28 PPM!!!! However both CO and HC were way over the limit! (car was running too rich.. probably because the ECU had no idea the EGR valve was open like that so it wasn't able to compensate with fuel).
Checked the voltage on the EGR valve position sensor and the voltage is within spec (1.2V when closed... around 4.6V when open).
Shop had to close up by this point so the mechanic will continue to work on this on Monday. He has no clue exactly what is causing it to drop vacuum. There are no leaks with the hoses.
BTW.. how do you test whether a knock sensor is working properly? He took the resistance reading of the two knock sensors and found two different readings. If no ECU light is on, is it safe to asume the knock snesors are working? What test can I do to them? My manual does not specify any specific resistance range they should be in like how O2 sensors have to be between 10-20 Ohms.
G
208 WHP @ 6250 RPM
MUSTANG Dyno
Old 04-25-03, 11:43 PM   #65 (permalink)
according to the Chilton book, there is a solenoid that controls vacuum to the EGR valve.
That can be tested by disconnecting the wires and applying 12v+ to where the blk/yel attached "A" , and vehicle ground to where the white wire was "B". Book says that the blk/yel goes to No 22 fuse which controls 12V and the white goes to the ECU which provides ground when it wants the solenoid to function.
If this makes the EGR work then the problem is either with the ECU, another sensor or the PCM which Haines says requires special equiptment to test.
The PCM (powertrain control module) compares all the data and determines how far the EGR should be open as well as how other smog items should then operate.
You might try to reset the ECU and other computers by disconnecting the battery for about 10 minutes. Besure to have your radio code as you will need it to get the radio working again when the battery is reconnected.
This is REALLY STUPID but have you checked the fuses? It looks like fuse #5 in the interior fuse box controls the ECU and #20 in the engine fuse box controls ETS. The Chilton book says #22 fuse controls 12V+ to the EGR solenoid The book is unclear which controls the PCM.
Best Wishes
Steve
Merlin the Wrench is offline
Old 07-02-05, 01:13 AM   #66 (permalink)
L E G E N D
FutureX 2001's Avatar
Car 1: '95 Coupe
Car 2: '94 Sedan GS
Car 3: '90 Coupe
What was the conclusion to all this? 2 years later
FutureX 2001 is offline
Old 07-02-05, 12:12 PM   #67 (permalink)
Sr. Member
Car 1: '94 Cashmere LS Sedan
Depends on who you're asking. I was the original poster, and the conclusion was that I fixed my car for less than $10 and it passed smog fine. I'm getting ready to sell it as I've had it for 4 years and I'm bored.....it's time to get something made in this century.
Sean in Norcal
'05 Infiniti G35 Coupe
'94 Mustang Cobra
'94 Legend LS Sedan (SOLD)
'97 Lex LS400 Coach Edition
http://www.mustangmods.com/data/4358/legendsig2.jpg
Sean L is offline
Old 07-02-05, 04:28 PM   #68 (permalink)
"the Don"
CONCLUSION: Bad O2 Sensors.
A bad O2 sensor will not always put out a "check engine" light. So long as it's operating within the proper voltage range, the ECU thinks it's fine. However in my case, if the A/F mixture was supposed to produce a voltage of 0.4V let's say, the O2 sensor would be putting out something differnt like 0.6V or 0.2V (both within range of proper working O2). So the engine would go on the wrong A/F mixture values to control fuel, etc.. and thus produce a lean condition (my case was my O2 sensors were showing richer conditions than reality) which would cause high NOX values.
My emissions were perfectly fine even with the 1 cat only which shows that we do not need the 2 pre-cats on the Type II motors.
208 WHP @ 6250 RPM
MUSTANG Dyno
