First gear issues please help - The Acura Legend & Acura RL Forum
Old 01-26-13, 11:06 PM   #1 (permalink)
Car 1: 1991 ACURA LEGEND
I have a 91 acura legend and my car just started acting crazy. When I crank the car and put it in D4 it seems like its stuck in neutral no matter how hard you push the gas then after a couple seconds it goes in drive. The car only does it after you cut it off. If you stop at a light it shifts fine. I have no D4 light blinking or anything.I changed my transmission fluid and differential fluid within the past month. The transmission was recondition about 90k ago. I don't drive the car hard it my daily driver to work. Any suggestion what this might be hope the tranny is going out
bballsfinest21 is offline   Reply With Quote
Old 01-27-13, 12:09 PM   #2 (permalink)
ActionJackson's Avatar
Car 1: 1979 MGB
Car 2: 1991 Sedan LS
Car 3: 1993 Coupe LS 6MT
iTrader Score: 7 reviews
Originally Posted by bballsfinest21 View Post
.I changed my transmission fluid and differential fluid within the past month. :
Did you check/replace the tranny screen (filter)?
Asheville NALM 2013 Aug. 22-26
ActionJackson is offline   Reply With Quote
Old 01-27-13, 12:22 PM   #3 (permalink)
No I didn't replace it or check it. Can this cause it?
Old 01-27-13, 12:24 PM   #4 (permalink)
Car 1: 1979 MGB
Absolutely.
Old 01-27-13, 12:28 PM   #5 (permalink)
How hard is it to access? It just makes no since if first gear was going out it would do it all the time I would think not just upon start up
Old 01-27-13, 01:39 PM   #6 (permalink)
Car 1: 1979 MGB
It's easy to access when you drop the pan. Check the FSM for details. It does it upon start-up because the fluid is cold and thick and will not go through the screen/filter.
Old 01-27-13, 03:40 PM   #7 (permalink)
Thanks Action Jackson I going to drive my other car this week and I will work on it this weekend I will keep you posted
