Frozen steering in cold weather???? - The Acura Legend & Acura RL Forum
Old 01-12-04, 12:19 PM   #1 (permalink)
Say wha*???
Car 1: Seattle Silver 1992 LS Sedan
Send a message via AIM to Tim92LS
Lately it has been cold for us down in the south (20s, not cold for most, but about as cold as it gets down there.) When I start my car in the morning I have no steering. It is impossible for me to turn the wheel at all. then, I can turn it slightly and it is like having no power steering at all. Then as it gets warmer after about 5min of driving and moving the wheel back and forth it warms up and gets back to normal. I did a search and found one other occurance of this and noone gave a solution. I also found out that the fluid shouldn't freeze up untill about 40below 0.
I cant figure it out. Maybe some moisture has built up in my power steering fluid? Anyone have any ideas? Is anything wrong with my car. I need to get this problem cleared up. If it is moisture in the fluid how i would I go about flushing my system? Any help/expirience/reccomendations would be thankful. Thanks again, Tim
Tim92LS is offline   Reply With Quote
Old 01-12-04, 01:43 PM   #2 (permalink)
P*mp!
Car 1: 91' Vineyard Grey Metallic Sedan
Send a message via AIM to WicKeD LeGEnD
Ive got the same problem,.....
refer to this link....
my post
no help yet....I think it has something to do with water getting into the system somewhere....
http://www.imagestation.com/picture/...5/f8a94485.jpg
Mods:
OEM 4300K HID's (Philips)
GS Rims/ Wrapped in Toyo Proxes Tires
Custom Red Tinted Tails
2 Rockford Fosgate HE2 10's (1 Blown, Looking for Replacement, got one?, shoot me a PM)
1 Rockford Fosgate Amp (4 x 150W)
Alpine IVA-C801 Indash Multimedia Station
Alpine ERA-G320 Sound Processor
Alpine V-Power MRP-F240 4 Channel AMP
Pioneer Speakers All Around
Blaupunkt DVD-ME3 DVD/MP3/TV Tuner
WicKeD LeGEnD is offline   Reply With Quote
Old 01-12-04, 02:00 PM   #3 (permalink)
Car 1: 93 Legend LS 4 DR Auto Geneva Green Metalic
Send a message via MSN to smth_hckr
Did you try changing out your power steering fluid with new stuff? How is the PS fluid level? Have any leaks?
Old 01-12-04, 02:51 PM   #4 (permalink)
S K / L L Z
Car 1: 91 LS coupe (boost coming soon! (or not))
Send a message via AIM to LeoLegendATL
dont worry man, its normal for an old car, mine does the same, it just takes a while for the fluid to circulate in the cold.
LeoLegendATL is offline   Reply With Quote
Old 01-12-04, 03:00 PM   #5 (permalink)
Car 1: 94 ls 6-speed black on tan
yeah mine did the same....just warm up your car and you'll be fine
jigga622 is offline   Reply With Quote
Old 01-12-04, 03:56 PM   #6 (permalink)
Stock Is Best
7up Pinball Champion, Grid Game Champion
Mastervtec's Avatar
Car 1: Bastard People
Send a message via AIM to Mastervtec
Mine was doing that last week. I changed out the fluid with new Honda fluid and it has been a little better, but it still happens.
-BDE
"I like your cane." <<< >>> LMAO. You had to be there.
CLICK!!>>> Newbie FAQ...Read It!! <<< CLICK!!
My Coupe - Sold
My New Coupe
Mastervtec is offline   Reply With Quote
Old 01-12-04, 09:13 PM   #7 (permalink)
Car 1: 94 LS Dark Grey sedan
Take it to one of those places that has that circulating machine that will flush out the whole power steering system. I had a Grand Am that was doing the same thing as it got older. If you checked the fluid it was literally frozen. Only costs like $60-$70 to have done, which is a lot cheaper than burning out a power steering pump.
Agent Smith is offline   Reply With Quote
Old 01-13-04, 12:55 AM   #8 (permalink)
Car 1: 1992 Tan Sedan
Send a message via AIM to SHoTTa35 Send a message via Yahoo to SHoTTa35
yeah, i'm in CT now and yeah, it's FREAKING COLD!! Good thing i have a remote starter so i just start that car up before i even get out there.. but couple times lately i went out and had to rock the steering back and forth to warm it up before it got fully loose.. i was gonna ask but i guess i know why...
SHoTTa35 is offline   Reply With Quote
Old 01-13-04, 05:52 AM   #9 (permalink)
Say wha*???
This is the second question I have asked where people have tried to tell me "Oh that is normal" This really irritates me. Its not right and I want to know what to do to go about correcting it. A car shouldn't do this, even if only one, or if 50 of htem do it, its not "normal" I think I am going to try and flush the fluid and replace with fresh stuff, and I will call my local shop and see what they have to say.
Thanks for the help from everyone. Any more ideas on what will fix it or how to flush the steering fluid the best? -Tim
Old 01-13-04, 05:58 AM   #10 (permalink)
well the fluid wont warm up instantly and even tho it's not frozen that doesn't mean it'll run just like it was not cold.. when it's cold it maybe a lil thicker cuz of the extra moisture. And cuz this car is say 12yrs old and running that good i don't think it's that big of a problem since you are spose to wait till the engine warms up anyways.. and by then the steering is free...
Old 01-13-04, 06:39 AM   #11 (permalink)
Tim92LS,
You are correct - it is NOT normal for the power steering to do this, even if it is 10 years old; but it does happen, for these reasons:
1. failing power steering pump
2. clogged power steering pipes (pressure pipe/hose and the return pipe/hose).
3. clogged and sticky steering gear box/rack.
4. moisture in the PS fluid and/or viscosity breakdown.
Your PS fluid is probably original - Acura does not mention changing it in their normal maintenance schedule. I'm sure that it has deteriorated over these years. Try putting new fluid in it, then bleed all the air out. Is it leaking anywhere where moisture can enter the system?
If you've checked all of the above, the actual problem may lie within the steering rack. The valves and/or o-ring seals are probably getting stuck. It is more common on older cars when it is cold, but the only known cure would be to replace the rack if all else fails.
Old 01-13-04, 09:04 AM   #12 (permalink)
Stock Is Best
Mastervtec's Avatar
LOOK 2 posts up from yours....AGENTSMITH ANSWERED YOUR QUESTION. People that always want more irritate me.
-BDE
My Coupe - Sold
My New Coupe
