» Sponsors
» Sponsors
Old 10-10-09, 12:06 AM   #1 (permalink)
Car 1: 1995 Acura Legend coupe LS
Frustrating Idling please read!
Hello everything, need some serious help, bought a 95 legend coupe LS, and I've been repairing the engine, the problem is that when the engine starts cold, it rev at 2000rpm, I heard this is normal, after the engine is warm the RPM drops and starts with the UP and Down rev, like if someone is pressing the gas pedal and releasing it, I already replace the PCV valve and the idle control sensor/valve, has a recent tune up and in conjunction with the idling the TCS light is on, but not the engine light, so I replace the TCS computer and the TCS sensor, and still the same issue, also the engine release a lot of gray smoke, I dont know if it is bc the car was sitting for a long time, or other but is not a lot, and is only after the rev up and down deal starts, if anyone has a suggestion I will take it, thanks
wingzeroac195 is offline
Old 10-10-09, 04:59 AM   #2 (permalink)
LegeNd-SX car2n's dream
car2n's Avatar
Car 1: 1988 acura legend
Car 2: Legend+NSX=LegeNd-Sx
Car 3: Comptech SC
Start by checking all the vacuum hoses and possible vacuum leak spots, if this does not help then need to check the EACV and the fast idle.
http://www.acura-legend.com/vbulleti...end-sx-124851/
In memory of my son Isai "car2n"
car2n is offline
Old 10-10-09, 10:40 AM   #3 (permalink)
ON DAT WAVE
Team LR's Avatar
Car 1: 92 Acura Legend LuxuryPerformanceSedan
Car 2: 97 BMW 528I
Car 3: 99 Montero Sport
check coolant levels too
Team LR is offline
Old 10-10-09, 12:24 PM   #4 (permalink)
Thank you for the response, I hear a hissing sound coming from the left rear of the engine, I checked all the hoses, and the sound still the same, I was hoping by moving the hoses the sound will change but no luck, the coolant level is good, I'm thinking of replacing the Temperature/fan sensor any more suggestions???
Old 10-10-09, 12:25 PM   #5 (permalink)
also I already replaced the fast idle and the EACV
Old 10-10-09, 08:54 PM   #6 (permalink)
Car 1: 93 Legend...195K
That would indicated a broken vaccum line. Not too bad man, just a heck of a lot of investigative work for that.
You know you're addicted when your girlfriend sees you online at 2AM...and you're on A-L.com
JayP is offline
Old 10-10-09, 09:04 PM   #7 (permalink)
thanks jayp, I will investigate
Old 10-10-09, 09:29 PM   #8 (permalink)
On the fast idle valve there is some adjustment you could do. Start the engine cold the n the top cover take one screw off and loosen the other one. then with a flat head turn the valve inside until the rpms get to normal. One valve must be higher or lower than the other....thats causing the rpms to go up and dowm.
nightstalker is offline
Old 10-11-09, 04:55 PM   #9 (permalink)
so just adjust the fast idle valve, nightstaker?
Old 10-11-09, 05:16 PM   #10 (permalink)
First bleed the coolant system and fill it up to normal if that does not help adjust the fast idle valve, there is no adjustment on the iac valve.
Old 10-11-09, 05:18 PM   #11 (permalink)
Will try that and let u know
Old 10-17-09, 12:51 PM   #12 (permalink)
RLbuddy96's Avatar
Car 1: 1992 Rosewood Legend
Car 2: 1996 White RL
Send a message via AIM to RLbuddy96
Check the headgasket
RLbuddy96 is offline
Old 10-17-09, 01:29 PM   #13 (permalink)
I will
Old 10-18-09, 11:52 PM   #14 (permalink)
any other suggestions? Thank u for those who took their time to help me out
Old 11-21-09, 11:50 PM   #15 (permalink)
Ok just found out I have a gas leak from one of the fuel lines, and looks like the hissing noise is coming from the fuel line connecting to the engine, u guys think this is the issue?
