Old 12-04-03, 05:51 AM   #1 (permalink)
Legend Newb*e :)
Car 1: 92 coupe
Send a message via AIM to jedinyte120
fuel injectors
i did a search but couldnt find an answer.
if i send out my injectors to get professionally cleaned will that be ok?
should i replace the seals to?
seals and O-rings are the same thing?
how many seals do i need to get and price on these seals?
anyone have pics on where the injectors are located and how hard is it to do?
thanks
rog
http://www.imagestation.com/picture/...c/fa317368.jpg
pics of my coupe
JDM headlights
CL Type-S wheels
Remus Exhaust
HIDs
jedinyte120 is offline
Old 12-04-03, 05:59 AM   #2 (permalink)
Car 1: 1991 Acura Legend
Fuel injectors are generally pretty time consuming to replace due to the multiple steps it requires. Here are the O-rings you will need for your injectors... as far as the seals are concerned, you might as well get them replaced while you have the injectors out.
http://www.carparts.com/parts/sample...rtnum=NONE&dc=
BTW, what is the flow rate on G2 Legend fuel injectors?
Thanks
Mort
ON ORDER
Ranger Joe CAI
Stromung Exhaust
Bayou Stage II Chip
6000k HIDs
18" Racing Harts
Pioneer 9815 HU
And more to come...
"Yeah actually I get paranoid ~ the stock Legend front looks so good I'm afraid someone will rip it off my car and put it on their Integra or something "
mortsayyed is offline
Old 12-04-03, 08:38 AM   #3 (permalink)
Car 1: hmm.......lets see how big this box is. does it end here? nope, guess not, here? damn. this is r
Send a message via AIM to Lost1
FUel system info
there is another post but i cant find it. states on a bench test our injectors flowed 250 cc/min
you might have as much luck with a rock in your intake - me
http://www.alterahosting.com/~bloody...tpostcount.jpg
Lost1 is offline
Old 12-04-03, 09:19 AM   #4 (permalink)
EDM Honda Legend
MikeD's Avatar
Rog,
to replace or to install, you should ALWAYS replace new cushion rings on each injector. Install new O-rings on each injector and coat the O-rings with a light coat of clean, thin oil.
Yep, the same things in their meaning and function, but different in her construction (see 1st pic). If you need the complete "How To..." then gimme a call. Hope this helps. -Mike
MikeD is offline
Old 12-04-03, 09:53 AM   #5 (permalink)
legendary!
Car 1: 1993 acura legend coupe metallic green
Send a message via AIM to legendcoupe93
how much do those o-rings and cushions usualy go for? im buying some used ones off ebay
http://www.imagestation.com/picture/...c/f98053bf.jpg
Proudly serving in your military
you only live once, live it up!
Vehicle & Vehicular Equipment Mechanic Apprentance
legendcoupe93@yahoo.com
15% black tint
koni/Ground Control
SPC ball joint
Enkei LM1 18"
x-drilled slotted rotors
kenwood 7inch touch flip
alpine type R 10" sub
no name amp 300w
mcCulloch 5000K H.I.D.
bayou chip
new type II
type S door speakers
pioneer 4 way 6x9
Im broke!
legendcoupe93 is offline
Old 12-04-03, 01:34 PM   #6 (permalink)
legendary!
^ lol im board
15% black tint
koni/Ground Control
SPC ball joint
Enkei LM1 18"
no name amp 300w
bayou chip
new type II
pioneer 4 way 6x9
Im broke!
Old 12-04-03, 01:39 PM   #7 (permalink)
Legend Newb*e :)
Car 1: 92 coupe
mikeD
so i need to buy 6 of each:
O-ring
cushion ring
seals
injector insulator?
or do i just get the Orings and seals from the dealer.what do you think prices are for each piece?
thanks mikeD
you never got back to me on the lenses.
roger
pics of my coupe
JDM headlights
CL Type-S wheels
Remus Exhaust
HIDs
Old 12-04-03, 09:44 PM   #8 (permalink)
DON'T BUY USED. They are cheap and you are A LOT better-off knowing that they are new than old. These seal-in your fuel, don't take any risks.
Mort
ON ORDER
Ranger Joe CAI
Stromung Exhaust
Bayou Stage II Chip
6000k HIDs
18" Racing Harts
Pioneer 9815 HU
And more to come...
Old 12-05-03, 02:12 AM   #9 (permalink)
legendary!
thanks alot mort. my friend that wrecked his legend were gonna take the fuel injectors off his engine and try them on mine and see if it makes a code, problem is, it is an ittermittent(sp) prob so who knows how long till i hvae to deal with it
peace
drew
15% black tint
koni/Ground Control
SPC ball joint
Enkei LM1 18"
no name amp 300w
bayou chip
new type II
pioneer 4 way 6x9
Im broke!
Old 12-05-03, 08:41 AM   #10 (permalink)
EDM Honda Legend
MikeD's Avatar
Originally posted by jedinyte120
mikeD
O-ring
cushion ring
seals
injector insulator?
thanks mikeD
roger
Hi Rog,
yes. It would be better to buy a complete kit incl. all seals and O-rings. Please donīt use USED parts, esp the seals. Ok? The prices? I cannot tell you the prices, because German prices are too expensive. US parts are more cheaper, esp Acura of Augusta, you know?
The Side Marker Lamps! Sorry Rog, but I have in this moment some probs about my work. Will post it later in the Off Topic. Then you can understand me. Is it possible to cancel the order? -Mike
MikeD is offline
Old 12-05-03, 09:16 AM   #11 (permalink)
Symply Legendary
Car 1: 1994 LS Coupe (Modded)
I believe RC Engineering will blueprint and clean the stock injectors for a reasonable charge. The NSX boys use them.
- Remus Exhaust
- DV8 Y-Pipe and Cat
- WR CAB and Ram Intake
- Bayou II Chip
- Ported and Polished Heads
- Zex Dry Nitrous Kit "60" Shot
- Grounding Kit (Smoked)
- Eibachs & Rear Konis
- MLS Strut Tower Bar
- Brembo Cross Drilled \ Slotted & EBC Greenstuff
- 18" RacingHart GT5
- 225\40\18 Yokohama Parada Spec II
- Two-Tone Leather (Black on Tan)
- Kenwood MP3
- Phoenix Gold 2500 & 4600 & X-Over
- .5 Ferad Cap
- MB Quart & Infinity Interiors
- Custom Tweeters In Domelight
- 2 JL 12W6's in Custom Box
LegendC is offline
Old 12-05-03, 02:12 PM   #12 (permalink)
Car 1: 93 Legend LS 4 DR Auto Geneva Green Metalic
Send a message via MSN to smth_hckr
Once you have the fuel rail off, can you just clean the injectors yourself? Is there a procedure or method to do this? Or is this not recommended?
Thanks,
smth_hckr is offline
Old 12-05-03, 02:55 PM   #13 (permalink)
legendary!
Im intrested in that as well anybody got an idea?
Thanks,
15% black tint
koni/Ground Control
SPC ball joint
Enkei LM1 18"
no name amp 300w
bayou chip
new type II
pioneer 4 way 6x9
Im broke!
Old 12-05-03, 05:11 PM   #14 (permalink)
Blk/BlkGS6
Car 1: '94 Black/Black Legend GS Sedan 6 Speed
Car 2: '92 Silver LS Coupe
Car 3: '94 Cashmere L Sedan
Send a message via ICQ to legend4life Send a message via AIM to legend4life Send a message via MSN to legend4life Send a message via Yahoo to legend4life
Maybe look into getting new aftermarket high performance fuel injectors. NickD has some, they can give pretty significant gains.
legend4life is offline
Old 12-05-03, 05:44 PM   #15 (permalink)
Car 1: 94 Legend Coupe
get some 350cc injectors for N/A or if planning on some boost then go for some 440cc's
RC is the place.
94LegendCoupe is offline
