Old 03-17-08, 06:50 PM   #16 (permalink)
Obsessive Enthusiast
antik's Avatar
Car 1: 98.5 BMW M3 Coupe 5MT
Car 2: 95 L Sedan
Car 3: 95 6MT Coupe (Dad's)
Originally Posted by LA Legend View Post
Do this in the following order and you should be good.
1.Run gas treatment cleaner in gas tank and seafoam through brake line, then dive long trip.
2.change fuel filter
3.Change Oil (5w 30), remember to warm up the engine then change the oil
4.change pcv valve
5.Charge spark plugs (copper)
6.Install cold air intake w/ K&N
7.Unplug battery for 20 min to reset ECU
8.Over inflate tires a little
I disagree with some of these points, but the basics are certainly there. The simple solutions to bad gas mileage are clean fluids, clean filters, good plugs and a little extra tire pressure (and of course, not laying into the accelerator with a 50lb shoe off every light).
Copper vs. platinum spark plugs is a long-standing debate. I personally do not advocate copper plugs given my long standing luck with platinum and consistantly high mileage on platinum plugs (even into 60k miles of use). However, fresh plugs will certainly get better mileage than old ones so if you're not getting good mileage, replacing the plugs is certainly worth a try.
A fresh air filter is a must. Installing a CAI will bring extra noise and may hurt your fuel economy if you enjoy that sort of thing, so be sure to keep that in mind. I did not notice any difference between a clean OEM paper filter and my Legend specific K&N either... it was just easier to deal with the K&N than buying new paper elements as regularly.
PCV and fuel filter services are a must - I'm not sure when the last time I replaced my Legend's fuel filter is but it did make a difference on my BMW so I certainly advocate it.
And the biggy here that I think is often overlooked is the little extra air in the tires... again my most noticable experience here was on my BMW but +2psi on all 4 corners earned me 2mpg on that car. I've seen similar results on the Legend (though never quite a solid 2mpg).
As far as actually modifying the engine goes? My intake helped a little and I've seen suggestion that chipped ECUs make a bit of a difference but I'm not aware of anything beyond that (maybe exhaust? I don't know though...) that helps fuel economy. Perhaps I haven't been watching carefully enough
~Ben
antik is online now
Old 03-17-08, 08:10 PM   #17 (permalink)
Black Type II's Avatar
Car 1: 1995 Blk on Blk LS Coupe
Car 2: 94 Honda Accord-4/S
Car 3: 1986 Buick Regal
the dictator part had me laffing a bit only places in the east i know of is sunoco, bp and hess....but ive been recommended by the forum that shell is the best gas or returns the best mpg for our cars...which i can support. its better than BP even... i think mobil also was almost as equal as shell to me but theyre both up there...
so since where linked between a dictator that hates americans and middle easterners that hate americans what choice do we really have?
Plans: Repaint car Granada Black, Custom interior (not that kinda custom), Navi unit, red or glow gauge needles, Hrant floor mats, remote starter
Whats done: IS300 wheels, JDM headlights with 6000k HIDs, JDM navi console, LED backlit gauges
Black Type II is offline
Old 03-17-08, 09:09 PM   #18 (permalink)
JDM 4 life
superstreet4life's Avatar
Car 1: '93 Legend L Sedan 5 Spd w/ Cloth Inteior
yeah e15 or e85 ethanol will give you less mpg but burns cleaner thats all and the cai will give you more than a 1 mpg increase it should give you about a 5 mpg jump.
http://i258.photobucket.com/albums/hh275/93KA7/acura%20legend/mangecar2.png
superstreet4life is offline
Old 03-17-08, 09:34 PM   #19 (permalink)
Car 1: 1994 Acura Legend GS Black/Black 6-speed
Send a message via ICQ to mweber88 Send a message via AIM to mweber88 Send a message via Yahoo to mweber88
I went from an auto to a six-speed in my GS. Mileage went from about 24 to 30 (got this to and from DC).
Yeah, I know that it's not a readily-available mod, but it certainly does help. Alex, was this part of the reason for your mileage jump?
Anyway, yes... clean fluids, filters, plugs, and tire inflation are the best things that can be done. Also, if your alignment (specifically, toe-in) is off, that can cause premature tire wear and in order to prematurely wear tires, you need to cause more friction, and more fuel is needed to overcome the friction!
Good luck!
Mike
Still hunting for the boost prevention routine in the ECU. PM me if you have any thoughts.
mweber88 is offline
Old 03-18-08, 03:41 AM   #20 (permalink)
IAmLegend's Avatar
Car 1: 93 LS Sedan
Car 2: 90 Camry DX
what are u smoking? a CAI will not give you a 5 mpg increase. i dont think theres any 1 thing that can give an already properly running engine a 5 mpg increase.
5 hp maybe but not 5 mpg
Roll that seven duece Cutlass, can't touch this
Vogues smoke like dope when I say fuck this
Roll my windows down, still smoke tinted
Shot gun mag glocks all up in it
I have an ECU, Sedan type F door panels, Gauge clusters, Digital climate control, Type 1 Intake manifold, Injectors, Coil packs, and a tail light for sale
http://www.acura-legend.com/vbulleti...iendly-127973/
IAmLegend is offline
Old 03-18-08, 04:00 AM   #21 (permalink)
VIRGIN
murderotica's Avatar
Aside from proper maintainence of your car... a cold air intake may help slightly; consider weight reduction; improved aerodynamics might do something for you (most resistance is at the front bumper, consider air-cooled brakes like minez); drive like a grandma!
Originally Posted by some randy View Post
I got this email, a little long, but some info I'd never heard of. I don't know who wrote it
This has me skeptical from the get-go... Random e-mails from unknown senders? I'm internet-savvy, thanks.
I don't know what you guys are paying for gasoline.... but here in California we are also paying higher, up to $3.50 per gallon.
Only $3.50? I paid $3.69 the other day... and that's at the $0.10/gallon cash discount rate.
Only buy or fill up your car or truck in the early morning...
When you're filling up do not squeeze the trigger of the nozzle to a fast mode....
Though these two points sound logical, I'd like to see some concrete science to back them up. Logic is often incorrect when it comes to scientific fact. (eg. two spheres of different weights fall at the same rate when released in mid-air at the same height; et. al.)
One of the most important tips is to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this is, the more gas you have in your tank the less air occupying its empty space.
The gas tanks on automobiles are close to vacuum sealed, are they not? Not only does the cap provide a seal, but there's a valve in the filler-neck that acts as a back-up seal.
Another reminder, if there is a gasoline truck pumping into the storage tanks...
This is legitimate.
DO SHARE THESE TIPS WITH OTHERS!
Gas rationing in the 80's worked even though we grumbled about it. It might even be good for us! The Saudis are boycotting American goods. We should return the favor. An interesting thought is to boycott their GAS...
Of course the rationing was effective... IT CUTS DOWN ON OIL USE, DOY. Let's keep the politics out of this though.
Nothing is more frustrating than the feeling that every time I fill-up the tank, I am sending my money to people who are trying to kill me, my family, and my friends.
These companies import Middle Eastern oil:
Shell........................... 205,742,000 barrels
Here are some large companies that do not import Middle Eastern oil:
ARC0....................0 barrels
Coincidentally, Shell has the cleanest and all-around best gas out there (that's both my opinion and fact supported by unbiased testing)... and Arco is notorious for having the dirtiest gas ever. Hmmmm...
Originally Posted by Emo236 View Post
sadly, last time I was at a Shell I noticed the horrible ethanol sign. At least the Shell by my house has started using E15 as well, sad day.
Whaaaaat? That's depressing... none of those signs around here!
+5 mpg? Is that a fact?
While yes, a [true, keep in mind you need to be feeding cold air to your engine] CAI will yield a slight increase in MPG it won't be anywhere near 5 mpg.
murderotica is offline
Old 03-18-08, 06:36 AM   #22 (permalink)
91LSplendid's Avatar
Car 1: 1991 Legend LS Sedan
Car 2: 2008 Grand Caravan
Subj: TIPS ON PUMPING GAS
Did not want to repost all of that tips post, but I searched it in Snoops.com they say...
It's not completely false in that one or more of the tips might actually result in some savings (however modest), but it can't fairly be classified as true either, as the practical utility of all of these tips is disputed, and the economic gains to be had from following them is highly questionable. For the full explanation...Urban Legends Reference Pages: Tips on Pumping Gas
The bottom line is that there are much easier and better ways of improving the efficiency of your car (and thus of saving you money at the pump) than the tips outlined above.
  • Particularly important is proper maintenance, including engine tune-ups, wheel alignments, tire pressure checks, and filter replacement.
  • Mileage can also be improved by removing from the car little-used equipment that adds weight or increases drag (e.g., sporting gear, tools, roof racks/carriers).
  • Driving habits are especially important: jackrabbit stops and starts eat up extra fuel, as does driving at higher speeds.
  • All in all, the simple habit of engaging in planning and combining multiple trips into one excursion will likely save the average motorist far more money (and time) than all four of the above tips combined.
John aka: Splendid
'91 LS - Golden Glow Pearl Clearcoat w/ Ivory Leather 94K miles
Gallery Pictures Link
DIY's
1) How to Install Iggee Front Seat Covers
91LSplendid is offline
Old 03-18-08, 07:28 AM   #23 (permalink)
VIRGIN
Exactly like I said ^_^ but that last one is super important.
Old 03-18-08, 01:04 PM   #24 (permalink)
Making Legends Rare.....
Car 1: 1995 Legend GS
In regards to the tips post, I questioned a lot of it, but the "Time to Pump" is actually fact. There has been debate by Idaho legislature on forcing gas stations to edit pump prices between summer & Winter due to the change in Volume. So, if it is 20 degrees cooler in the morning the Volume of gas you pump would be higher.
Overall though some good tips here. I have heard, by more than one person, that exhaust systems can be fundamental in improving fuel mileage.
1995 Legend GS: Acquired 6/22/06
1965 Plymouth Belvedere - Bought new and past to 4th Generation now
2005 Dodge Grand Caravan SXT - Wife won't let me get rid of it for an MDX.
gsdreams is offline
Old 03-18-08, 01:20 PM   #25 (permalink)
antik's Avatar
Car 2: 95 L Sedan
Originally Posted by gsdreams View Post
What he forgot to list here is which companies, such as Sinclair, who use E15 Gas. I was shown by my mechanic just what E15 can do to the inside of a Throttle Body and a Fuel Filter. Also, from personal experience, it lowers MPG. Most of the companies this person listed that don't use Middle East oil sell E15.
This is different depending on where you live... here in DC, everyone sells E15.
Good luck!
Mike
I overlooked this one but it's a fanstatic point: the manuals get SIGNIFICANTLY better mileage than the autos. The 6mpg difference you've suggested is just about indicative of the difference between my auto sedan and my dad's manual coupe (though, I think we're closer to 4mpg difference on our best days)
~Ben
antik is online now
Old 03-18-08, 01:44 PM   #26 (permalink)
Sherwood on Type F
samblaze's Avatar
HHO Kit: Brown's Gas (from water) for fuel combustion efficiency. Any good?
Anyone have any input on this technology? I'm skeptical until I learn more....
86 Saab 900S Coupe 5MT
94 Acura Legend GS 6MT
04 Subaru Forester XS 4EAT
Sig by Double Glow
samblaze is online now
Old 03-18-08, 03:33 PM   #27 (permalink)
I've heard that about the East Coast, have you ever checked a Flying J? I don't know if there is one near you, but they are a company that refines there own fuel.
Here in Idaho Shell, Texaco, Chevron, and Maverik all run non-E15 fuel. I believe Albertson's Fuel Stations and I know Stinker, both run E15 fuel.
gsdreams is offline
Old 03-18-08, 04:04 PM   #28 (permalink)
antik's Avatar
Car 2: 95 L Sedan
I've seen Flying J trucks in the SW part of the state but that's 250mi from here and I have no idea where there are any stations.
I could drop in on my local Texaco and maybe see if I could find a Chevron too but those stations are few and far between in my area: primaries are Shell (which I generally run), Sunoco (my 2nd), BP (which I'll use when I can find it), Exxon (which I own stock in but refuse to run through my car) and the occasional Texaco, Hess, or Amoco.
~Ben
antik is online now
Old 03-19-08, 06:40 AM   #29 (permalink)
Welcome to Flying J Travel Plazas Website! Wi-Fi Hotspot Truck Stops to find there fuel stations.
The really funny part about E-15 is if you research the refining process it takes 2 gallons or so of "Fossil Fuels" (i.e. Diesel, gas, oil, etc...) to make "1" gallon of Ethanol.
gsdreams is offline
Old 03-19-08, 08:15 AM   #30 (permalink)
antik's Avatar
Car 2: 95 L Sedan
I'd hardly call it funny.
I don't remember seeing anything to that effect when reading about ethanol but it was clear that ethanol is nowhere near as efficient at yeilding useful fuel supply as fosil fuel in ideal production conditions which are rarely possible. There are advancements in development to improve this (to get it reliably beyond the 1 output for one unit input) but they are in development so we're not expected to see them for some time.
Even less exciting are the changes it's creating elsewhere throughout the agriculture industry. I find it a little painful to read about...
And for what? I hardly consider something a viable "fuel" when the addition of a 15% ethanol mix to my fuel decreased my fuel economy by more than 10%. All it does is effectively bring me back to the pump more often to purchase even more expensive fuel. Meanwhile, oil companies are reporting record profits year after year while my fuel price is at a record high and my fuel economy is a record low...
I must say though, the stock in Exxon that I own has always done quiet well...
