Old 12-06-06, 03:11 PM   #1 (permalink)
Chefosaurus
GFs_a_LEGEND's Avatar
Car 1: 01 jeep cherokee 2dr
Car 2: 92 acura legend
Car 3: 05 rsx type-s
Got a weird problem....
okay. car takes regular time to warm up. when normal low speed driving...no heat. get it up over 50 mph OR rev in park over 3000 rpm for 3 minutes...heat works great!! when revs go down so does heat.... also just for kicks... temp will sometimes spike to H ( real hot) for like 1.5 seconds when car is almost warm... then go to normal temp. any comments would be appreciated. or forum direction to solution.
geesh i got the hood up now and gooing to check fluid levels first, then hoses. maybe bleed air from system??? somebody help the newbie. rookies need love too
GFs_a_LEGEND is offline
Old 12-06-06, 03:21 PM   #2 (permalink)
Chefosaurus
right section?
didn't want to put it in the over heating section cuz it doesn't over heat or anything.... hope that was okay.
also can't seem to find my way around the coolant/overheat section.....
Old 12-06-06, 03:58 PM   #3 (permalink)
bizanned
shtewps's Avatar
Car 1: Pearl White '91 LS
I would take care of the overheating issue ASAP. My diagnosis is a sticking thermostat. When you buy new, make sure you go OEM for this part. (I am having the exact same issue right now) I still (regretfully) havent changed my thermostat and eventually one of my hoses busted and coolant spilled everywhere along with clouds of smoke from the engine. Hose was cheap and car works fine now but dont let it get that far.
Now for the heat.. does the blower motor turn on ? Because if the blower motor isnt running, heat will push through the vents while the car is moving at a relatively fast pace (provided the vent setting is non-circulating). And when the car isnt moving, nothing will blow through. If thats the case, my diagnosis for that is a bad blower motor. Very easy to replace, runs about $230 CAD. Another thing thats happening to me right now also.. or you can also rebuild it if you know a thing or two about electical motors, which is fairly easy also. Let us know..
JDM C32A Swap - Weapon R Dragon - 5 Wire 4AWG Custom Ground - Sunroof Tilt - Billet Grille - Remus Universal Rev.3
Telion ECU - '04 TL Wheels - Shaved Antenna - Clear Corners - Kenwood KVT-717DVD - x2 JBL GTO927 6x9
JBL GTO75.2II - x2 Rockford P2 12" - Iggee Covers /w Controls
Got rust? CLICK HERE
shtewps is offline
Old 12-06-06, 04:16 PM   #4 (permalink)
Chefosaurus
not really a heat prob
this problem is not really an over heating problem. i just( as in just now) took the radiator cap off and the rad seemed to take a gasp. (pressure sound) well i drove it for a minute to go to the auto store and now the heat works fine.... weird. i am going out now to bleed the coolant system too see if it works better, i will have to keep and eye on the temp spike but that does not happen often also the reservoir was almost empty.....
Old 12-06-06, 06:38 PM   #5 (permalink)
Chefosaurus
Cool working good so far
bled the system. refilled coolant level to normal and all is well with the heater and temp guage. gonna change the rad cap just for kicks.
I LOVE THIS SITE!!!!!
thanks for all the previous posts on this prob to set up my trouble guide and for the guys today for letting me figure it out LOL
{knocking on wood}
Old 12-06-06, 09:27 PM   #6 (permalink)
MAD DOG!
dgandul's Avatar
Car 2: 92 LEGEND LS
pressure test that bad boy... either therm. or BHG.... but hey you joined the right forum. we should rename this acuraswithBHG.com
dgandul is offline
Old 12-07-06, 06:38 PM   #7 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
You did not post any history. The major question is why was there air in the cooling system? If you did not have your coolant drained/refilled lately, you need to check for hairline cracks in the radiator top tank. You should have no trouble performing this inspection as Acura green coolant dries to a very light green and is readily visible. If you cannot find any seepage, you need to inspect hoses and especially the heater hoses and inlet nipple affixed to the block. If these are o.k., you need to rule out a failing head-gasket.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
LPB is offline
Old 12-07-06, 06:41 PM   #8 (permalink)
Admit the obsession
SuperLegend91 V2.0's Avatar
Car 1: 91 LS Coupe
Car 2: 89 Jeep Cherokee
Send a message via Yahoo to SuperLegend91 V2.0
check your upper radiator hose, my coupe did the same thing when i first got it. the hose was a little soft so i replaced it and never had the problem again.
SuperLegend91 V2.0 is offline
Old 12-07-06, 07:50 PM   #9 (permalink)
Chefosaurus
had the timing belt/ water pump changed recently.... dont know if that did it. just bought the car in september. w/105k on it. was changed at 93k so i guess the guy neverhad to have the heat on since it was done....aka never noticed it.
Old 12-08-06, 07:28 AM   #10 (permalink)
LPB
O.k. With this additional info, it would appear that the system was not fully bled of air during the water pump replacement. Thank your lucky star.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Clear Corner Lens
Clear Bumper Lens
Gold Pkg
LPB is offline
Old 12-08-06, 09:23 AM   #11 (permalink)
Chefosaurus
Cool
no thank acura=legend.com!! this site has been going strong for so long, the more i search the forums the more answers i comeup with. who knew it would be this in depth. nice community too
Very weird problem and need some help ASAP!! rxmd19 First Generation Legend (1986-1990) 21 03-06-05 02:33 PM
Electrical problem or weird coincidence? lawr_rawr Second Generation Legend (1991-1995) 1 01-19-05 11:37 PM
AC electric fan problem.... BhamPearlCpe Second Generation Legend (1991-1995) 2 12-21-03 06:53 AM
Weird Problem drinkdontdrive Second Generation Legend (1991-1995) 3 11-21-03 09:56 AM
Weird radio problem... Sh0ck3d Second Generation Legend (1991-1995) 0 01-24-03 02:02 AM
