Old 03-09-04, 08:05 AM   #1 (permalink)
Car 1: 1991 blue legend
ground control + koni setup bottoming out anyone else have the same problem?
just checking to see if all of you who lowered your car bottoms out after hitting a huge freaking pot hole or not. mine does. my conclusion is that the spring is not strong enough. any thoughts on this matter. i hope i am not the only one here. by the way the front springs are set on the highest setting and still bottoms out but the rear doesnt even on the lowest.
acurablister is offline
Old 03-09-04, 08:07 AM   #2 (permalink)
Car 1: 1991 Cobalt Blue KA8
Car 2: 1998 Kouki (sold)
Send a message via AIM to Gerald
It shouldn't be bottoming out at all. Who installed tha setup?
http://img.photobucket.com/albums/v502/acura_lover_85/Best-Night-Pic23again.jpg
Help Me Find White/Black KA8
Gerald is offline
Old 03-09-04, 09:39 AM   #3 (permalink)
Car 1: 94 ls 6-speed black on tan
mine "bangs" sometimes if i hit like a pothole or something.....but oh well
jigga622 is offline
Old 03-09-04, 01:03 PM   #4 (permalink)
Legend no more
ScotcH's Avatar
Car 1: BMW M3
Did you cut your bump stops?
'93 Legend Coupe LS - 6-speed (fast, pimp) SOLD
'96 BMW M3 (faster, but less pimp)
'95 BMW M3 (fastest, not pimp, track car)
'88 Nissan 200sx - 5-speed (ice race, winter beater)
'06 Subaru Impreza - 5-speed (grocery getter, winter fun)
http://www.macrocosm.on.ca/images/m3_sig.jpg
ScotcH is offline
Old 03-09-04, 03:32 PM   #5 (permalink)
Car 1: 1992 Legend LS
remember that most of the weight is in the front...and big freakin potholes will make anything bottom out sometimes
1992 legend ls, black on black leather
: KMS strut bar, alpine s620 changer, shaved "acura" badge, MORE TO COME
oneblackac is offline
Old 03-09-04, 04:08 PM   #6 (permalink)
First, I am sorry that your car is bottoming out. However you changed your spring rate and things like this are to be expected. Your choices are rather limited. If you want factory clearance, which is minimal compared to most cars, go back to stock springs and shocks. There are some sophticated ways to raise your ride height without changing spring rates however it would require re-engineering the Legend suspension. It isn't a formula one. It also is a quite heavy car for its suspension and brakes. I love mine but realized early on that it was never going to be a race car. Just too heavy, too many accessories and too much metal.
Best Wishes
Steve
Merlin the Wrench is offline
Old 03-10-04, 12:55 AM   #7 (permalink)
i had two different guys worked on it. i guess the first guy screw it up. then i went to another place which they know what they were doing. whats so funny was that the first guy who did the installation put the rear spring in the front and when he went and figured it out he called me and said i some how switch the springs in the boxes. really studpid thing to do and he wanted 350 for the labor cause of his own mistake. but we agreed on 300. the second guy put in the konis for the front and back. he said the first guy install it wrong or something. after putting on the konis everything seems to work fine except sometimes i get really nervous going bumps at high speeds. dont get me wrong it was worse without the konis alot worse. well you can feel that the spring has reach its full length on a big pot hole, and you hear a boom, bang or whatever (which is i think is inevitable on a lower car). i am pretty sure the installation is done correctly now. could the adjustable konis be the problem here? i am just not sure. or is it normal to bottom out like that.
Old 03-10-04, 01:17 AM   #8 (permalink)
GS Hog
LegendGS's Avatar
Car 1: 1994 Legend GS-Auto
Car 2: 1994 Legend GS-6 spd
Car 3: 1993 NSX-6 spd
Same question as above. Did you have your bumpstops cut? Without cutting your bumpstops, your shocks have very little play. Also, did you have a camber kit installed? If so, did you have the upper control arms ground down to clear your inner fender?
LegendGS is offline
Old 03-10-04, 03:24 AM   #9 (permalink)
Car 1: Gynomobile
Going over bumps or potholes with banging is not spring rate related. It's shock related. Either your shocks are way too soft for a lowered car so it compresses way too fast over a bump or potholes. The only way to keep your car from bottoming out is to stiffen your shocks depending how low you are.
The banging you hear is the upper control arm hitting your inner fender. If you raise your car, and look under, you will see where the upper A-arm engraved it's mark up there.
RIMTUCK.com - Wheel fitment database
Volk Racing is offline
Old 03-10-04, 04:25 AM   #10 (permalink)
Legend no more
ScotcH's Avatar
Car 1: BMW M3
Ummm ... no, it's not shock related. The konis are only REBOUND adjustable, not compression. If you put on a 100# vs a 500# spring you're saying I won't bottom out the suspension any easier?
The shock (or damper) is only used to control the osilations in the spring. The spring will determine how far the travel is (spring rate is lbs per inch ... in other words, how many pounds to compress the spring 1")
I do agree that the banging might be related to the A-arm hitting the fender, however.
ScotcH is offline
Old 03-10-04, 08:22 AM   #11 (permalink)
i did all of the above. and i dont think the upper c arm is hitting the fender. i thought it had something to do with the adjustable konis too. is it possible to adjust the shocks without having to remove it? i tried to turn the shock where its sticking out in the engine bay but i dont think thats gonna work. its not as bad right now since i had my half shaft replaced. i only bottom out once in a while now. difinately not a city driver though. i live in nh so i am ok.
Old 03-10-04, 09:46 AM   #12 (permalink)
Wha*ever ** *akes
Car 1: 2006 Nissan Titan
Send a message via AIM to 95legend
how do you know you are bottoming out?? what kind of noise is it?? if its a loud bang, or something of the sort, its your control arm slamming into your inner fender wall, mine does it every once in a while, but when it was lower, it would do it almost over every bump, so much so, it did this...drivers side
and passenger side...so i doubt your car is bottoming out, unless you can see marks or damage to your bumper or undercarriage. btw, how much did you lower your car??
edit: on the drivers side, there are two holes, the one with the metal sticking up is from the control arm slamming into the fenderwall so much...on the passenger side, it didnt go through, but it was well on its way as you can see the bulge it created.
95legend is offline
Old 03-10-04, 10:00 AM   #13 (permalink)
Oh my!!!!!
Why is it doing that????? I'm getting scared now. I wanted to get custom gc's but I'm a little bit on tha sketchy side now.
Gerald is offline
Old 03-10-04, 10:57 AM   #14 (permalink)
dude, youre sure banging alot more than i do lol. mine doest hit on the control arm at all. it did but a friend help cut off part of the control arm to make room. i dont see any evidence of metal hitting metal like yours. i definately seek help asap if mine car did that. btw i used to set it so that there are no finger gaps between the tire and fender but the ride is not as smooth and the ball joints seem to go more quickly if i do that for the front so i just set it at the highest setting in front and the lowest for the back. i like the front high low back look.
Old 03-10-04, 02:10 PM   #15 (permalink)
Car 1: Gynomobile
My Prelude use to do that A-arm smashing deal, but not to that extent. Mine did that because I had soft shocks. My Skunk coilover springs were 450lbs, but that's nothing if you don't have the right shocks for it.
Shocks is what it's name is. It asorbs sudden shocks. High spring rates keep a car more lateral during turns, braking and taking off. Stiffer shocks help keep the car from bottoming out from sudden speedbumps/potholes. Too bad Koni Specials only adjust oneway.
I think if you are truely in the game of having slammed cars, you need to know how to drive one. Keyword: "DETOURS". My Prelude was lowered 3.5" with a body kit, and I always avoid uneven roads, speedbumps and potholes. If you can't do that, then you shouldn't lower your car. My car never goes places if I never been there before.
