Old 08-31-04, 07:20 AM   #1 (permalink)
KTD
Car 1: Type II coupe
Send a message via AIM to KTD
Ground Control Spring Rates
I have set of ground controls with koni struts on 18" rims and wanted to know if I could get a lower spring rate. I believe they are 450lb/in for the fronts and 315 lb/in for the rears. I spoken to speed merchant and was told that I could get different springs rates. I just called ground control and a representative told me that they won't sell a lower spring rate for this car. I've read that other suspension companies made springs rate close to stock for their coil overs. What other other springs option could I use w/ my ground control?
kevin
KTD is offline
Old 09-12-04, 09:53 PM   #2 (permalink)
(^_^)
Car 1: 1993 sedan
hello to answer your question concerning other springs you could use with your gc/koni setup, you can use any spring with a 2.5" inner diameter designed for a coil sleeve application. off the top of my head, available is of course eibach, carrera, hypercoil and some others. as you mentioned, the springs that are by default choice for a legend are (front) 8"/2.5"/450lb = height/I.D./rate (rear) 9"/2.5"/315 but honestly im sure there is a reason as to why gc would not sell with a lower rate. however if you do still decide to get something softer, consider getting a taller spring or other alternative to ensure safe resistance of bound travel. of course this may compremise the amount of height adjustability.
http://www.pitstopusa.com/shocks_springs.htm quick place you can check to see what is out there as an option for you. hope this helps
legend107 is offline
Ground control, eibach, or H&R RangerJoe Engine & Performance Modifications 21 09-29-03 04:22 PM
My New Ground Control Talrude Engine & Performance Modifications 4 07-19-03 01:13 PM
Ground Control, Koni Red Adjustable, and GC Koni kit peiqinglong Second Generation Legend (1991-1995) 2 06-12-03 03:53 PM
Ground Control & Struts? Who has the deals Gold Engine & Performance Modifications 2 10-04-02 10:27 AM
Ground Control Coilovers SammyD Engine & Performance Modifications 6 03-13-02 03:24 AM
