Old 03-23-07, 01:13 PM   #1 (permalink)
i live like that ofa star
northcakalaky's Avatar
Car 1: 2000 Lincoln LS V8 Sport
Car 2: 1995 Acura Legend GS
Send a message via AIM to northcakalaky
harsh shift(s)
my boy has an 1995 acura legend GS with 124,000 miles on it. me and him both have noticed, it the either 1st to 2nd gear or 2nd to 3rd gear shift is very firm and hard. whenever girls ride in it, they sometimes comment on it. its shifted like this ever since hes can remember and hes had it for 3-4 years. soo i have 2 questions. does the acura legend start out from dead stop in 1st or 2nd gear? and the main question...is this firm/harsh shifting of gears normal for the legend?
thanks in advance. i know this acura community will be able to answer this question.
btw, i know this is my first post but i've been watching the acura forums off and on for the past month, although i own a lincoln ls.
2000 Lincoln LS V8 Sport Light Parchment Gold
northcakalaky is offline
Old 03-23-07, 01:25 PM   #2 (permalink)
bizanned
shtewps's Avatar
Car 1: Pearl White '91 LS
dude ur ride kicks ass.. i love the ls's
JDM C32A Swap - Weapon R Dragon - 5 Wire 4AWG Custom Ground - Sunroof Tilt - Billet Grille - Remus Universal Rev.3
Telion ECU - '04 TL Wheels - Shaved Antenna - Clear Corners - Kenwood KVT-717DVD - x2 JBL GTO927 6x9
JBL GTO75.2II - x2 Rockford P2 12" - Iggee Covers /w Controls
Got rust? CLICK HERE
shtewps is offline
Old 03-23-07, 01:37 PM   #3 (permalink)
Spiral descent
telafonic's Avatar
Car 2: KA7_8 SWP 6-speed
Car 3: 1996 A6
Yeah, it's quite normal, but if it's been over a year or so since he's changed the tranny fluid, he should probably do that. Just a drain and refill, not a flush. And use Honda ATF only.
Also by this time his tranny mount is probably shot.
telafonic is offline
Old 03-23-07, 01:55 PM   #4 (permalink)
bizanned
shtewps's Avatar
f'n gold
shtewps is offline
Old 03-23-07, 03:04 PM   #5 (permalink)
Car 1: 94 GS Black / Black - Sold
Flush the tranny with Honda ATF at least 4 times, and rear tranny mount. It works for me! Don't push the gas too much on the first gear. Go easy...
Keep up on Engine oil change, and spark plugs. After I changed my spark plug, I noticed smoothness.
Legend tranny is a little bit hard on 1 to 2 shift.
Nor Cal Summer Meet(Monterey Bay)
http://www.acura-legend.com/vbulleti...d.php?t=101319
http://shopro4u.com/west_coast_acura...d_meet_200.htm
NorCal Legend Owners, please sign up...
http://groups.yahoo.com/group/Norcal_Legend_crew
1994 Legend GS Blk / Blk - Sold
Ting is offline
Old 03-23-07, 03:34 PM   #6 (permalink)
NOTaMango's Avatar
Car 1: 1993/95 Acura Legend Coupe L On the way to LS
if I do a hard acceleration it will most definitely chirp and spin the tires between 1st and 2nd. I don't recall it ever being smooth between 1st and 2nd. I've also seen people commenting around the board that when these cars get on in years, like they pretty much all are, the auto-trans equipped of them shift hard.
http://moirails.com:16080/nates/pix/Legend.jpg
NOTaMango is offline
Old 03-24-07, 10:09 AM   #7 (permalink)
hey ting man, my friends car looks exactly like yours, same rims same everything, is you're like dark foreset green also?
Old 03-24-07, 02:43 PM   #8 (permalink)
Spiral descent
telafonic's Avatar
Car 3: 1996 A6
Oh, and to answer your other question, from a dead stop, it starts out in 1st gear. You can force the car to start out in 2nd gear by putting it in '2'. Of course this also holds it in 2nd gear, so you'd have to manually upshift. And manually shifting these autos usually isn't recommended.
Old 03-24-07, 11:11 PM   #9 (permalink)
acura crazy's Avatar
Car 1: 1998 acura rl
Car 2: 1992 acura lengend
Car 3: 1999 gmc sierra
I am on my 2nd 92 legend and first rl and all of them sift hard and from 1st to 2nd when i am on the deck the tires chirp so i would say no worrys
acura crazy is offline
Old 03-24-07, 11:31 PM   #10 (permalink)
not so newbie
mordezmoncou's Avatar
Car 1: 94 Legend LS Coupe
Car 2: Magic Carpet Ride
Send a message via AIM to mordezmoncou Send a message via Yahoo to mordezmoncou
if its shifting hard from 1st to second its the rear tranny mount, they are weak as hell. also they legend natrually has a hard 1st-2nd shift. add some lucas transmission fluid.
Not Your Average Ebayer
mordezmoncou is offline
Old 03-25-07, 02:53 PM   #11 (permalink)
Again, flush the tranny fluid every engine oil for 10K. You should notice the smoothness right away.
Then every 10K miles.
Ting is offline
Old 03-28-07, 04:57 AM   #12 (permalink)
Car 1: acura legend
Car 2: mercury villiger
well i dont know -- but we i change gears like P R AND D4 it like jumps wow mad hard can it be that my idle is to high cuz i think it is i dont know .. sumone help ... is it okay to put OIL and TARNSMISTION treat ment fluids ! ??
kako is offline
Old 03-28-07, 05:20 AM   #13 (permalink)
Car 1: 1992 LS Sedan - 3.5
Try giving it a little more gas than normal to get the it above ~1800 or so, then easing up on the pedal a little to make it shift. I think its the really low rpm shifts that give the most severe jerks.
FallenAngel is offline
Old 03-28-07, 11:05 AM   #14 (permalink)
Car 1: 1995 Legend LS Coupe
If you search this forum, you'll find that a harsh 1 - 2 shift is VERY common. I don't know that there is an effective fix. I changed my trans fluid and replaced the rear transmission mount. It made no difference.
oldacura is offline
Old 03-28-07, 10:10 PM   #15 (permalink)
i just noticed you're car is black on black ting - anyways my friend probably wont get the harsh shift looked at. his car is clicks when shifting from park. he'll prob replace the rear tranny mount throughout the summer. anyone know a rough estimate price of complete rear tranny mount job done by a stealership
harsh transmission andre334 Second Generation Legend (1991-1995) 12 02-22-07 05:50 AM
Transmission Electronics? Early shifts? Sterling 825 First Generation Legend (1986-1990) 2 01-09-07 02:47 PM
Transmission shifts violently oderaro Second Generation Legend (1991-1995) 5 07-10-06 10:28 PM
A/T: how many shifts do you get? qutaybaa Second Generation Legend (1991-1995) 14 10-07-04 09:41 AM
hard chokes in between shifts??? acurablist4 Second Generation Legend (1991-1995) 0 05-28-02 01:45 AM
