#16 (permalink) |
im was just like you...didnt know if i could do it and i was scared of the timing issue.
So when i took everything off the front of the engine(this is the most time consuming thing) including the plastic covers over the TB, i marked both of my cams where they were. I would mark the cam wiht a scribe and then mark the block behind it....so when i replaced the tb, i made sure that both cams were at the scribed lines...worked for me... You will not damage your engine with bad timing...it will either not start...very sluggish performance...or idle rough....but at that point if you cant get it right you can always pay a mechanic to time it for you....that was my plan and i did not have to use a mechanic.... By the way i replaced everything(thermostat, TB, wP, tensioner...and all the belts at the front of the engine) Another thing I did while the car was not up and running, I took the injecotrs out and sent them to get cleaned and mached, it cost 100 but it was the best $100 I spent on my legend. I also changed the plugs and engine fluids. Another thing if you do it yourself save all your receipts and make sure you take pictures of you doing the work so you have the maintenence documented in case you sell the car. |
#18 (permalink) |
BHG... you can only deny for so long....
“I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day.” - Frank Sinatra “Oh, you hate your job? Why didn't you say so? There's a support group for that. It's called EVERYBODY, and they meet at the bar.” - Drew Carey 94 Gold Acura Legend L Mods - 6 1/2 Infinity Kappa perfects,6x9 Infinity Kappa perfects, Alpine 4 channel V12 amp, Alpine CDA-9883 HU, Alpine pdx 1.1000 amp, Eclipse SW6210 subs, Quantum Cap, 12,000k HID's |
#21 (permalink) |
Matthew is THE USER!
i would just change your head gasket .. lol
dont waste time "beating around the bush" lol ahha . hg job > spending 1000$ of dollars how much is a hg job anyways? never really researched that even if mine is fine.. id still wanna change it.. so i dont think about it anymore
KA7 & Inspire |
#22 (permalink) |
Type 2ed
Car 1: Green 1992 Acura Legend LS Coupe 5 speed MT type II swapped Car 2: 2002 Honda CR-V EX iTrader: (2)
you might be in the early stages of a BHG where the headgaskit is "seeping" The car will drive fine and not smoke BUT...... your temp will occationaly fulctuate, you will keep getting air into your cooling system, you might find a little oil in your coolent, the hose inside your overflow tank might be bloated, if you floor the car for an extended period of time coolent might overflow out of your overflow tank, and you occationaly have to fill your radiator with a little coolent once and a while. These are some of the symptoms of a seeping headgaskit.
Mods: sr5guy stage 3 chipped, BOMZ intake, light weight harmonic balancer, Type II heads, Type II cams, Type II ecu, 5000k HID kit, iggy seat cover mod, OEM spoiler added, 12" Kicker sub, 1300 watt MTX amp, Pioneer headunit, infinity 6x9's. |
#27 (permalink) | |
+1 on what he said |
