Head Gasket Questions - Page 8 - The Acura Legend & Acura RL Forum
Old 11-09-14, 09:21 PM   #106 (permalink)
So if you car fluctuates in idle its a big?
amadeus86 is offline   Reply With Quote
Old 11-09-14, 09:22 PM   #107 (permalink)
Bhg! Lol
Old 11-09-14, 09:27 PM   #108 (permalink)
The reason I ask is I did the water pump timing belt I've change my thermostat twice and when I put it back together I started having overheating problems never had that with the old water pump
Old 03-21-17, 09:24 PM   #109 (permalink)
Car 1: 1993 Acura Legend LS
My apologies for necroing an old thread. I just purchased a 93' LS sedan for about 350$ off of craigslist. When I bought it it wouldn't start, owners said they didnt want to spend money at a shop on it which is why the price was low. They said a friend mechanic said a headgasket issue *it smoked apparently before they parked it*
Well I replaced the battery cables (corrosion) and spark plugs as well as topped off the radiator and it started right up. Some smoking was present, but i attributed that due to it sitting for a few months. Hasn't smoked since. Was wondering if my changes (spark, coolant) could have somehow temporarily fixed a small headgasket leak. Should I still have the HG replaced? 141k miles. Pretty sure it's never been changed before.
It runs and idles great till it gets warmed up, then the idle dips 100-200rpm gently. not enough to cause issues though. (cold idle is upwards of 1800rpm though till warmed up.)
I only had one overheat issue, which I caught immediately. Was caused by an airbubble at the thermostat, I relieved the pressure.. refilled the radiator and haven't had any issues since other than slight coolant smells when warmed up (my assumption is the overflow)
JetLS is offline   Reply With Quote
Old 03-24-17, 04:41 PM   #110 (permalink)
Car 1: 1994 Acura Legend
Car 2: 2014 BMW 328d
Car 3: 2002 Chevy Suburban
A bad head gasket won't stop the car from starting, so you likely fixed whatever that small issue was. In the early stages of head gasket failure on these cars, they can run just fine for a few days at a time until enough exhaust gas escapes into the cooling jacket to cause a spike in the temperature gauge - the probe is on top of the thermostat housing near the cooling system bleed screw. Over time though, the leakage worsens and it starts indicating erratically or hot all the time. By the time the leak is really bad, your cooling system will have enough rapidly accumulating pressure to start stressing any weak links like rotting hoses or a weak radiator, and you end up stranded on the side of the road.
The high idle issue is likely a separate problem.
Sorry for the bad news, but I don't think you're out of the woods yet. :-(
Best,
Dave
Geotrash is offline   Reply With Quote
Old 03-24-17, 04:45 PM   #111 (permalink)
Best,
Dave
I'm sure I'm not. Thanks for the reply. Ill keep eliminating smaller issues around the engine till I absolutelt have to replace the HG
Sent from my LG-H918 using Tapatalk
