#16 (permalink) | |
#18 (permalink) | |
My opinion is that until we DO know, it is cheaper to use Honda products than it is to replace a head gasket. There are differences between honda coolant and most of the others. Apparently Honda engineers took a new look at antifreeze in aluminum engines, and decided to produce a different product, rather than add anti corrosion chemicals to existing antifreeze.
92 LS Coupe 83,000 Miles & Counting Stock except -GS RIMS -Clear Bumpers |
#19 (permalink) | |
WHAAAAAH!
It tells you why Honda coolant is different and non-corrosive like other coolants. I just replaced the radiator in my sedan yesterday. After a year of the coolant being in the system, it looked just like the day I put it in. I am a firm believer that the Honda coolant can do a lot for keeping your head gaskets intact. Other Antifreezes have silicates and borates that can damage the seals on your water pump as well as eat away at the gaskets.
#21 (permalink) | |
WHAAAAAH!
#22 (permalink) |
I'm still in this thread, now with a new observation. I just did a coolant change on my coupe. 92 LS, 68000 miles, and new rad in March of 2002. That rad was the Acura plastic aluminum job. I actually think this is the best rad, because it does not introduce any more metals into the cooling system, such as copper or brass.
However, I took a really close look at mine, and it is possible that it is starting to seep at the top tank crimp area, right near the rad cap. Since I just changed coolant, I am going to wash it carefully, then dry it thoroughly, and keep a real close eye on it. For what it cost, it ought to last at least 8 or 10 years! If it is in fact leaking, I'm going to insist that the dealer replace it, and if he refuses, I'm going to push it up to the zone office of Honda Canada. I still have the dated receipt. But, back on the main topic, I believe that the cost of the rad is peanuts compared to the cost of fixing overheating damage.
#23 (permalink) |
WHAAAAAH!
the thing to do about the plastic topped radiator, is to remove the bracket that holds the throttle and cruise cable from the relay box. Also, you can go around the radiator with a pair of pliers and reclamp the top. That's where mine started leaking at, and I clamped the new one before it does it again.
#24 (permalink) | |
legendinmyownmind
jk... I have pieced together a hybrid motor, and friends w/ turbo setups.. and i have learned that head bolts are an AWESOME investment in stock or modified application.. yeah they are high but if logevity is your goal.. you need em!.. Like spoon sports.. for their endurance cars.. many of their mods pertain to keeping the motor supported and protected.. from the stress of endurance.. ![]() |
#25 (permalink) | |
legendinmyownmind
alli babbah: says: Joo need to buy jourself one.. before i hit you w/ de camel spit! |
#27 (permalink) | |
aka desired_speeds
#28 (permalink) | ||
Pedobear is watching you
#29 (permalink) |
RALPHS HANDS ARE CLEAN!
Car 1: 91 LS Black window trim EDM/Hids Remus 2 1/2 cat back Headers stage 3 ecu Car 2: ,Red tails, Type 2 Car 3: 6 speed, EDM spoiler iTrader: (35)
I didn't read all the posts, so if I repost, forgive me.
I can say from experience that one Big, big. big, issue will cause a BHG. And I can say it with ONE word.........AIR! If you don't get all of it out in the first place it will own you. If you get a hole in a hose, or air enters your cooling system, and goes unoticed for some time, it will own you. I honestly believe we can overheat our cars, by, lets say a cooling fan not working, and it will be just fine. BUT, add air in the system and overheat, and your focked. I say this after blowing a oil cooler line and driving quite a long ways not even knowing it was hot because it sucked so much air that the gauge didn't even have any water to show a hot condition. Untill I stopped at a stop sign and turned a corner, then enough water must have hit the sensor to make it jump to H. So as I said AIR will own you. Make sure your hoses are solid! |
#30 (permalink) | |
Faster than yo Legend son
And you're right about not all of them having BHG problems, incorreclty diagnosed. how and the heck do I always write to old post
black on black 4 door LS rareessence.com mad races and stupid stuff allhiphop.com I endorse: when I endorse its like ceritified gold! Nanowax - bring out the luster in your paint. Duralube fuel injector cleaner - one of the best for under $20 |
