Headlights intermittently go out - The Acura Legend & Acura RL Forum
Old 08-29-07, 04:37 PM   #1 (permalink)
Car 1: 93 Acura Legend
I have searched for similar problems, and the suggested solutions are to change the headlight (lighting?) relay or to change the headlight bulbs. I just wanted to confirm this before I either buy parts or get a diagnostic done.
The problem is that if I turn on my headlights for a period of time (usually 10 minutes), the low beams and high beams go out. The blue high beam marker on the gauge cluster doesn't even show up when the headlights go out. Turn signals, hazards, horn, reverse lights, and tail lights are fully operational...so the headlights are just the problem.
The next day I can usually repeat this process (turn on the lights, wait 10 to 15 minutes, headlights go out). If there are any other suggestions or if I am leaving any information out...please let me know!
simmigrant is offline   Reply With Quote
Old 08-29-07, 06:37 PM   #2 (permalink)
Thumbs up
Start when your headlights go out, arm yourself with a volt-meter.
Start at the bulb and work backwards measuring voltage at every stage.
Once you see 12 volts and not 0V, you'll know where the problem is.
Armed with a service manual, this should not take you more than 30 minutes.
Starting to replace random parts without diagnosis is a bad move.
legendvr is offline   Reply With Quote
Old 09-29-08, 08:01 PM   #3 (permalink)
Car 1: 1993 Green 4dr LS
Send a message via AIM to specialk79
headlight issue
Did you ever figure out what the issue is? Im having this problem now
specialk79 is offline   Reply With Quote
Old 09-15-09, 04:23 AM   #4 (permalink)
shahavchik's Avatar
Car 1: 1994 Granada Black Acura Legend GS Sedan
Car 2: 2007 Subaru Forester
Send a message via MSN to shahavchik
I am having very similar issue. Please post here if you found a solution.
shahavchik is offline   Reply With Quote
Old 01-24-11, 12:04 PM   #5 (permalink)
Car 1: 1993 Legend CP
Car 2: 1966 Corvette
Car 3: 2001 Lightning 11.4
Same issue. Any ideas
Mine will just turn off for a second and come back on.
No aftermarket anything in the car.
Gonna try a new relay first I guess
http://www.auctioncreations.com/nlocav.gif
Numbers matching 1966 Corvette
2001 Lightning with all the go fast stuff video below
http://www.hyperfiberbbq.com/uploads/jason-11oh.wmv
1993 Legend LS Coupe
2006 Mariner
FlaHP is offline   Reply With Quote
AC cooling intermittently noikz29 Second Generation Legend (1991-1995) 25 10-31-07 09:02 AM
TRADE USDM headlights for JDM headlights? lostalegend OEM Parts 4 01-02-07 04:46 PM
Help! - Simulatneous CEL and flashing S3...now starting intermittently shmltn First Generation Legend (1986-1990) 17 04-23-06 12:28 AM
Alarm Goes Off Intermittently 91boz Second Generation Legend (1991-1995) 5 01-01-05 08:31 AM
Engine Temp rises intermittently 1992AcuraLegendL Second Generation Legend (1991-1995) 14 09-13-02 08:55 PM
