6 Gears
headlights won't turn on
I can't see
well after installing the HID's I went to hit the high beam switch and when I did the headlights turned off. So looking at fuses none blown. my only thoughts could be that the headlight relay is blown. The HID's are fused before they get power that fuse is fine as well as both 20 amp fuses in the engine bay. Is there others I should be looking at? Any more tips? where it could be and does anyone have a working relay?
Just another boosted legend Parts For Sale: Fiberglassed dash, Complete T1 & RL heads, Sedan Front seats (F), Center Console (F), T1&RL intake Manifold, Complete running engines, body parts, Sedan Headlights, Clear corner lights, RL engine parts. ANYTHING YOU NEED. I have "UNLIMITED" RL and Legend Parts PM me to discuss. NO COUPE PARTS, please stop asking For quickest reply please email me at 95LegendGS@gmail.com Thanks! |
6 Gears
Well changed the HID harness and headlight relay in the engine bay. Still nothing. Whats my options here? Is there more fuses then the 2 20 amp ones in the engine bay? Another relay? Could have the wiring fried? I need all opinions here for things to check because I can't drive with no lights on. I'm at wits end and about to junk this damn car over it.
6 Gears
I haev a bixenon hid installed in my jdms (hi and low beam in the one spot), I figured out what happened now I need to figure out how to correct it. The one wire was red/yellow (positive for hi and low beam) and the other was a red/blue wire ( i didnt know at the time that it was a ground) so i had the red/yel and red/blue attached and when I flicked the high beam they shut off. My thinking is it caused a short which would pop a fuse correct? If so where.
6 Gears
bump someone has to know this
6 Gears
bump.... I'm thinking ballasts MIGHT be bad.But they said its almost impossible to blow them
