Old 12-18-04, 02:52 PM   #1 (permalink)
Car 1: 91 Sedan L / 94 LS Sedan/ 94 Milano Red Coupe
Send a message via AIM to DJPolak
heater core causing air in cooling system.
resently i had weard idle every morning when i started the car. the idel will jump from 1k to like 0 up and down.I found some threas that's there is an air in the system, and it was. so i bleed the air and few days later again . i keeped bleeding the air over and over , at least 5 times so far. The air will coume out all the time wile beeleding when the heat is on full. but while the heat is off the air stop coming out., and clear cooland will come . so my problem is when running heat got air. is it possible that the heather core will hold so much air ? . is it anythign i can check , ( no overherting, no leaks inside of the car.)
http://home.comcast.net/~nosferatu2xlc/94LS.jpg
Sarasota FL
91 Gold Sedan L sold
94 Green Sedan LS sold
94 Milano Red Coupe LS sold
WTB G2 6spd LS coupe
DJPolak is offline
Old 12-18-04, 05:01 PM   #2 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
*heater*
Hotstartup is offline
Old 12-19-04, 12:16 AM   #3 (permalink)
sounds like the heater core is leaking somewhere and allowing air in....
bigdad is offline
Old 12-19-04, 07:05 AM   #4 (permalink)
Car 1: 1992 Coupe LS
Hope you don't have a bad heater core, it's tough to replace.
Questions:
1. Whem u bleed ur system, are you making sure your heat is on full?
2. Have u chewcked for leaks in other pklaces? Like the rad top tank, the heater hoses and valve between the engine and the firewall, and around your coolant hoses in front of the engine?
92 LS Coupe
83,000 Miles & Counting
Stock except
-GS RIMS
-Clear Bumpers
Tinkindling is offline
Old 12-19-04, 07:12 AM   #5 (permalink)
the air is coming when i have the heat on full . once i turn off the airt stop coming out. so it have to be something pass the valve . The heater hoses look ok and o don't see any leaks
Sarasota FL
DJPolak is offline
Old 12-19-04, 10:02 AM   #6 (permalink)
Swollen Member
stevieray's Avatar
Car 1: '95 LS Coupe
Car 2: '91 LS Coupe
Car 3: '97 NSX-T
Antifreeze in the passenger side footwell is indicative of an leaky heater core. Do you smell antifreeze in the interior and is there a film on the windows? If so, the entire dash has to come out to replace it. Not a job for the HELM-less or faint of heart.
You obviously have a leak somewhere. Have you checked ALL of the hoses and radiator? Has the car EVER overheated? Sounds suspiciously like death by BHG to me.
"King of Kleen"
stevieray is offline
Old 12-19-04, 04:12 PM   #7 (permalink)
i got new radiator about 7 mouths back, all the hoses look good no leaks, never overheated, no smell inside or out, new rad cup, im gettin air only when im running heat during bleeding , when i turn heat off the air stop coming out. thats weard, maybe i schould keep bleeding air for like 30 min, or so .Its weard bc the return hose from the heater core is connected to the rest of the cooling system ,so is matter of cooland floowing tru the heater core causing air . Also the way i bleed is with rad. cup off and bleed bolt off i start the engine and let all the air come out tru the bleeder bolt and adding cooland to the radiator, is that the right way to do ?
Sarasota FL
DJPolak is offline
Old 12-19-04, 04:23 PM   #8 (permalink)
VIP alllll the way
Cole Austin's Avatar
Car 1: 92 L Rosewood Brown Sedan
Send a message via AIM to Cole Austin
My heater core is blown.... I get coolant steam strait out of my vents......
Looks like a good holiday project.
http://www.directimagehost.com/is.ph...ial-mod-si.jpg
Throttle Body Coolant Bypass
General F.A.Q.
2nd Generation F.A.Q.
People I trust to buy items from:
bboarder711 | legendarysleeper | Chauffeur First | SmartJay28
Cole Austin is offline
Old 12-20-04, 03:44 AM   #9 (permalink)
Swollen Member
stevieray's Avatar
Car 1: '95 LS Coupe
Car 2: '91 LS Coupe
Car 3: '97 NSX-T
Bet Jordan loves that. Have fun with that project.
"King of Kleen"
Old 12-20-04, 03:53 AM   #10 (permalink)
VIP alllll the way
HAHAHAHAH it was pretty funny... she was all "AHHHH it smells bad"
Thanks... I think I got a few days of work ahead of me.
General F.A.Q.
Old 12-20-04, 03:57 AM   #11 (permalink)
Swollen Member
stevieray's Avatar
Car 1: '95 LS Coupe
Car 2: '91 LS Coupe
Car 3: '97 NSX-T
It's not really too bad. You should be able to get the dash out in 5-6 hours. Just make sure to mark the location of every bolt and screw because there's a gazillion of them. I used a giant piece of cardboard for that. Do you have a new heater core already?
"King of Kleen"
Leak in cooling system? Dwight Second Generation Legend (1991-1995) 8 09-03-03 12:25 AM
Big problem with cooling system legend88ls First Generation Legend (1986-1990) 4 08-18-02 03:35 PM
Air in cooling system NickD Engine & Performance Modifications 2 03-18-02 02:29 PM
Bleeding the cooling system NYLegend Second Generation Legend (1991-1995) 2 02-10-02 08:15 PM
Roar Considering Offering a Real Cold Air Induction System for Legends 2x6spds Second Generation Legend (1991-1995) 9 01-30-02 05:06 AM
