Old 10-24-02, 04:47 PM   #1 (permalink)
Swollen Member
stevieray's Avatar
Car 1: '95 LS Coupe
Car 2: '91 LS Coupe
Car 3: '97 NSX-T
Heating ? - DaveC, BigDad, LPB, PSA---anybody!
Lately, have noticed that at idle (like warming up in the AM), my heater blows semi-cool air. This also is the case when I pull up to a stop light or am in traffic. However, when I get over about 1K RPMs the heater blows all of the hot air you would ever want. A Acura tech whose opinions I respect is stumped---he says it appears I have some type of circulation problem but can't figure out where. Has anybody run across this before? I have no radiator leaks (pressure tested last week), HG is OK (hydrocarbon test last week, too) and a brand new thermostat. Any suggestions?
"King of Kleen"
stevieray is offline
Old 10-24-02, 06:48 PM   #2 (permalink)
*r**h *eller
Car 1: 92 L sedan and 88 LS sedan (wifes)
Classic example of air in the cooling system. Time to bleed her Steve (and look for leaks).
Started rebuilding IC engines in 1968 at the US Merchant Marine Academy. Don't think you know more than me about auto/IC/control systems unless you can document your education.
Dave C ver2.0 is offline
Old 10-24-02, 09:13 PM   #3 (permalink)
Car 1: 1993 LS Coupe, 6 Speed
Yup..... that was the last straw for me to do the HG repair on my 91 sedan. It happened in February when the temperatures were like -30C, and when I was in traffic, my heat would disappear and turn into AC.... It is air in the system..... the only way to fix it is to bleed it out, but then find out where it was coming back in.... that sux Steve.... not another one
Mckenzie93 is offline
Old 10-25-02, 07:09 AM   #4 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
After you bleed the system if the problem continues I would check the air mix control system and linkage.
LPB is offline
Old 10-25-02, 11:10 AM   #5 (permalink)
yup, sounds like air in the system...when you bleed it make sure the heater is on full blast and the car is at operating temp.....sounds like the heater core gets airlocked until the water pump forces enought water around to circulate properly....if there is air, there is likely a leak (or it was never completely removed when theromstat etc. was done)....sometimes the bleeding has to be done a couple of times....be patient
bigdad is offline
