RUDE LEGENDS
Hella Micro De Success!
I got my Hella Micro De Installed!
![]() This is a Pic with Hella Only just before sunset. ![]() This is a Pic just before sunset with Hella Fogs and Stock Headlights. ![]() I got instructions written up in my head. Check out this thread. http://www.acura-legend.com/vbulletin/f93/hella-micro-de-fogs-installed-17974/ I like his setup because you can do minor adjustment with enough clearance.(Left to Right adjustment if the Light is mounted far back on the bumper frame lip) I will have a more detail type of pics.(Where to drill and how I ran the Micor De harness) I saw a unused plug taped up to the Bumper light signal harnes (One red striped wire). I tested it with the parking/head lights on and I got no volts from it. So I used the Hella Harnes. My GS OEM Fog switch is not working properly with it. I have to take the switch apart to look at the connectors The problem is the light intermittently works. Picutures to come. The Hella Micro De Harness and switch works great. So Far this is what I can tell you. Tools: Decent variable Drill Flod light Flash light Long drill bit 12 foot long bit that the switch wire can fit through the hole after you drill it. Ratchet set Philips head screw driver that is magitized!. (Long and short) That Bumper Light screw is the worst! Long foot-long skinny flat head screw driver. Extra Tie wraps Print all pictures for good reference. G1 http://www.acura-legend.com/vbulletin/f2/auxillary-fog-driving-lights-install-diy-photos-59885/ G2 http://www.acura-legend.com/vbulletin/f4/oem-fog-switch-help-112218/ Where to by G2 Fog switches We all know where online to look but check out this link http://www.acura-legend.com/vbulletin/f4/fog-switch-119341/ Esitmate time It Depends. Really it does. For starters it will be at least 2 hours. Bumper removal and re-instalation takes a while. The drilling may take 20 minutes. What you have to do. Remove Front bumper (Search for DIY) ![]() Remove lower dash panel (Search for that topic) ![]() Drill a whole in bumper assembly ![]() ![]() ![]() Like the pic in this thread. http://www.acura-legend.com/vbulletin/f93/hella-micro-de-fogs-installed-17974/ Use the Long Flat head and punch a dent in the firewall in preparation for the drilling. Trust me it will make drilling in an angle much easier. ![]() I had to drill a hole through the firewall to run wires from outside to inside. You have to lay on your back and slid under the dash to see for some. Grab your Flashlight. The hole is under that silver wire sourounded by that black rubber and plastic. (Hella Wire not showned)Bad Pic I know. ![]() I drilled the hole 1 inch under the accelarator cable in the firewall. it is a save place. **Easy procedure with a non automatic car ** May be easier on Automatic because you may be able to use the spot the clutch would have been. I cannot confirm that. Tap into the corner light. Read and back wire? you have to use a test light to probe it to make sure it is it. (Used the Mico De blue wire in its wire harness) I do not want to risk me forgeting the light is on and drain my battery so I have to have the parking lights on for the Fog to come on. ![]() Other links Factory Fog HID Retrofit http://www.acura-legend.com/vbulletin/f13/diy-factory-fog-hid-retrofit-84721/ I am Still working on this thread.
12 foot long drill bit?
Plans: Repaint car Granada Black, Custom interior (not that kinda custom), Navi unit, red or glow gauge needles, Hrant floor mats, remote starter Whats done: IS300 wheels, JDM headlights with 6000k HIDs, JDM navi console, LED backlit gauges |
only if optionally equipped
i just reread ur question but if u r referring to the wires running from the dash through the engine bay down to the lights i do not know if they all were prewired or not
i would make the same assumption as well.
RUDE LEGENDS
Updated a few lines.
I have good Pics, I just have to upload them. I will be adding more tonight. I still need to use the OEM fog switch and clean up the engine bay a bit. Can anyone Move this thread into the Acura Legend Generation 2 area please? I made a mistake and posted it in the RL area.
OG Member
The L models were also pre-wired, at least my 94 sedan was, don't know about earlier years.
NEW PAINT PICS ARE UP...WHITE DIAMOND PEARL 1994 Acura Legend L Sedan Phillips HID Kit JDM One-Piece Headlights Trenz Billet Grill OEM Foglights-PIIA ion yellow bulbs Brembos Cross-drilled/slotted rotors Axxis Metalmasters brake pads Red-painted calipers 17X7 Acura TSX OEM Wheels Pics in Gallery |
#14 (permalink) |
damn!
