Help: ABS Light, No Climate Control & Heated Seats - The Acura Legend & Acura RL Forum
Old 11-10-12, 09:59 PM   #1 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
Question Help: ABS Light, No Climate Control & Heated Seats
Hey guys! When I start my coupe the ABS light illuminates immediately on the dash. While illuminated, the climate control & heated seats don't work (LS model).
It used to eventually turn off after some minutes and everything would come to life. Recently it stays off and nothing works.
Is my ignition switch faulty? Also, I suspect the radiator fans aren't always working.
K
The performance handling machine... is in long-term storage.
Old 11-10-12, 10:10 PM   #2 (permalink)
Fut RIP
L3GDKANG/JDMKANG's Avatar
Car 2: 92 Alpha/ AlphaT KA8
Car 3: 91L,93LS,94LS KA7's
iTrader Score: 39 reviews
If abs light is on pull code and it will tell you the problem. If your coupe been setting up I'd try checking fueses 1st.
Originally Posted by Blackend
Old 11-10-12, 11:31 PM   #3 (permalink)
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
That's the thing; there's no code. I shorted the black & white service connector on the top-right of the ECU housing and even used the 3-button memory seats to pull a code. Both times nothing flashed on the dash and the memory seats flash once "all-green", showing there's no a code. Thoughts?
When the ABS light is on, the rear defroster LED doesn't illuminate either.
K
Old 11-11-12, 08:32 AM   #4 (permalink)
Fut RIP
Try to disconnect the battery and that should rest everything then you may have to see if there a code after that. But this seem as if theres some bad connection or build up on plugs.
