Originally Posted by Bwillis
Hmm I'll def hav to check those. I'll be happy if that's all it is.. The labor of doin new springs after I jus had em out for the koni install would suck..
You realize that you will have to pull everything apart to change bump stops right? Exactly the same amount of work to change the springs. Bumpstops are the cushion looking things that sit on the strut rod under the dust caps. How did they look when u swapped them over from the oem struts?
If i were you id just stiffen up the konis. Unless you overlooked putting the bumpstops on them.
