Type II King
Help me out guys..
I smogged my car today and failed due to high HC levels, everything else passed with flying colors. I changed my headers back to stock as well as my ecu and intake. Can anyone give me an idea of what may be causing this problem?? I had a high flow cat installed, maybe its not enough to do the job? everything was stock on the car except the exhaust and cams.
mods- 2.5" mandrel exhaust, deleted cat, cold air intake, web cam regrinds, comp cam valve springs, port & polish heads and manifold, tb bypass, egr block, five speed clutch/flywheel, 80a polyurethane mounts all around, type 1 pulley, headers,re-fabed y-pipe, SR5guy Custom Chip, 6speed swap, safc II, strut bar, F/R sway bars, FL tie bars, ksports,tune 243.3 hp 197.7 ftlb N/A dynapack before manual swap 232.8 hp 204.0 ftlb N/A dynojet 10/19/07 13.737 1/4 mile @ 100.207 mph & 2.012 60' NA Last edited by Forevralegend : 03-28-07 at 05:38 PM. Reason: add more info |
I'd guess the hi-flo cat may be to blame, cams probably don't help though. Have any of you CA guys tried that CRC Guaranteed to Pass fuel additive? I have no idea if it works or not but it might be worth a try if it saves you the trouble of swapping everything back to stock.
Type II King
yea im going to try to swap in a stock cat, hopefully that does the trick.
mods- 2.5" mandrel exhaust, deleted cat, cold air intake, web cam regrinds, comp cam valve springs, port & polish heads and manifold, tb bypass, egr block, five speed clutch/flywheel, 80a polyurethane mounts all around, type 1 pulley, headers,re-fabed y-pipe, SR5guy Custom Chip, 6speed swap, safc II, strut bar, F/R sway bars, FL tie bars, ksports,tune 243.3 hp 197.7 ftlb N/A dynapack before manual swap 232.8 hp 204.0 ftlb N/A dynojet 10/19/07 13.737 1/4 mile @ 100.207 mph & 2.012 60' NA |
#4 (permalink) | |
Gimme a cookie.
update? this is important for us in Cali! XD
| TRANNY sorry for all the ''?'s'' guys | pfd2299dpr84 | First Generation Legend (1986-1990) | 6 | 03-10-07 12:42 PM |
| HEY GUYS...NEED HELP!! | NYzFINEST1 | Second Generation Legend (1991-1995) | 15 | 01-13-07 12:32 AM |
| why U guys choose Acura Legend. | Bushido95Legend | Second Generation Legend (1991-1995) | 145 | 11-09-06 04:43 PM |
| Project: Legend Reborn (Need your guys' help!) | _deleted | First Generation Legend (1986-1990) | 31 | 06-28-06 03:32 AM |
| for any of you classic car guys of mopar guys | legenddriver2004 | Other | 0 | 11-09-05 01:47 AM |
