Hey Old School, did you install a camber kit as well? I'm going to have a set of HR springs and Koni's installed soon and I've heard differing opinions on the camber kit.
Car 2: 92 Alpha/ AlphaT KA8
Car 3: 91L,93LS,94LS KA7's
iTrader Score: 39 reviews
i have koni reds and eibach on the gs i just picked up and it gef needs a camber kit so im going to have them installed after i get 2 new tires and the tires are worn in the middle and not on the edges so after that ill get a alingnment
Originally Posted by Blackend
Car 1: Kat - '95 KA8 T2 LS
Car 2: Jade - '95 KA7 T2 GS
Car 3: '87 KA3 LS - Donated
iTrader Score: 4 reviews
No I did not install a camber kit. I just bought new tires and got the car align so in a month or so I will check my tires and see if I will need one. It is lowered so it might effect the negative camber measurement. If it does than I will have to buy a kit and install it to compensate for the uneven wear of the tire.
But if your gonna lower the car kyb's will not work.
Car 1: 1991 Acura Legend
Car 2: 1999 Sebring Convert
Car 3: 1988 Mazda Rx7
We put KYB's on all corners of my 91 Legend sedan about 6mos ago. Very controlled and somewhat firm ride. I am very satisfied with how it handles. Working with a rented (free..at Checker) spring compressor is not the easiest job. Be sure to replace the top bushings. All that work you may as well replace all. Be careful or get someone to do the compression. Don
I got the same springs and struts but my bump stop rubber is totally trashed, should I go with a replacement from the dealership or is there a better aftermarket option??
[QUOTE=L3GDKANG/JDMKANG;1551835]But if your gonna lower the car kyb's will not work.[/QUO
I havent got the KYB Vogtland set yet, but the springs say they are a 1.2 drop all around, are you saying that the combo set wont even work ?
Kyb's aren't a lowering strut. So if you put a lowering spring on it the strut stays compressed and can't travel so it will end up blowing. Also after I put the new tires on the gs and got it aligned I didn't have to get camber kit! But I did replace inner and outer tie rods!
Originally Posted by logic
Hi!!
thx!!!
Either option will work
I wonder why they would sell them with the vogtland lowered springs then, im glad i havent bought them yet. what struts to you recommend to get just a 1 inch drop ? (or 1.2)
Koni reds or Koni yellowes they are the same just painted diff colors. They are adjustable and if you check out my fut project you will see how low mine is.
