wTn XtReMe LeGeNd
help!! throttle body
the throttle body cable on my car keeps gettin stuck when im on long trips back home from college. does anyone know whats wrong with it? and how i can fix it? it gets stuck and stays there and my car has the gas constantly on while i try to brake. it was so hard to stop the car the first time it happend. let me know if you have any idea on what it is. thanks
Jiggawin http://www.imagestation.com/picture/...3/fb92a930.jpg http://www.generyx.de/anime.gif |
E*koden
try adjusting the slack on the cable...and apply some sort of lubricant to prevent it from getting "stuck." Also...a dirty throttle body can cause sticking too. Try cleaning that out with some intake cleaner
http://img.photobucket.com/albums/v3...8/oaktree3.jpg 95 M3<>3.46LSD<> 00 SUZUKI GSX-R 750<>TOO MUCH TO LIST<> |
WHAAAAAH!
you should probably replace the whole throttle cable. It runs from the pedal, through the firewall, then connects to the side of the throttle body. You're gonna have to disconnect it at both ends and pull it through the firewall to replace it. Sticky throttle cables can cause serious accidents, the $40-50 part is worth buying.
Make sure it's not the linkage on the side of the throttle body that's sticking.
wTn XtReMe LeGeNd
its not really the cable thats get stick its the cylinder thing that gets stuck. the thing the pulls it forwards
#6 (permalink) | |
Later! Lee |
wTn XtReMe LeGeNd
yo i cant do it this weekend but my vin number started with jh4 or whatever so i think it falls in that range i am gonna see if they will replace it in valdosta because i have to go back to school. but for the door sills how much is shipping? i can send you money or what not. but ya just pm me back
WHAAAAAH!
Every G2 Legend starts with JH4, but I know that if you have problems with the throttle body sticking, that's the reason for the recall, sorry, I forgot about that. Get it done before you hurt your car.
#9 (permalink) | |
Later! Lee |
Here is what I have found so far:
NHTSA Recall History 1991: Transmission-shift-cable bracket can be damaged and shift lever may not correctly indicate gear position. 1991-92: A transistor in the speaker amplifier could overheat, resulting in smoke or the possibility of a fire. 1992: Passenger-side airbag assembly in small number of cars was produced without igniter material, which would cause nondeployment or slow deployment in case of collision. Pretty interesting, but I still can't find the one on the TB. Later! Lee Added: Acura reports that all airbags were replaced. This is interesting because the passenger side one in my coupe did not go off, but the driver did. Arent they suppose to go off together? Mabey I need to talk to Acura ![]() |
Here you go!
Product Update: Legend Throttle Body Year 1991 Model Legend VIN Application See Vehicles Affected Bulletin No. 93-025 -------------------------------------------------------------------------------- December 1993 Dear Legend Owner: Honda has determinded that your Legend may sometimes experience an erratic idle condition. Your dealer now has the parts needed to correct this condition. Please call your Acura dealer and schedule an appointment to have them installed. This update will be done free of charge. Please plan to leave your car at the dealership for at least a half a day to allow them scheduleing flexibility. Vehicles Affected Only vehicles within the following VIN ranges are affected: 2-door thru VIN JH4KA8...MC006531 4-door thru VIN JH4KA7...MC029711 I too thought the recall was for sticking throttles, but it wasn't. You still might be elegible for a new one. Check your vin. Later! Lee |
wTn XtReMe LeGeNd
the last of the vin is mc 002458 so i guess i fall in that range but can someone post of the site that has the information on it so i can print it out. im gonna be leavin my car here this weekend and my dad is gonna take me back to valdosta. i need the print out so they can fix the car. also any other recalls they have. im gonna get them to do it all at once.
#14 (permalink) |
Here is where I found it:
http://www.acuraofmissionviejo.com/s...tes/93-025.asp I hope this helps. Remember that most of the cars were fixed, so most likely you will not fall in this catagory. Later! Lee Added: Here are all the recals for a 1991 Legend: http://www.alldata.com/TSB/01/91010812.html Here is more: http://www.alldata.com/TSB/01/91010712.html |
#15 (permalink) |
wTn XtReMe LeGeNd
thanks car is goin in the shop on monday
