Old 09-07-07, 06:37 PM   #1 (permalink)
BHG Motorsports
Pinyix's Avatar
Car 1: '92 LS "December"
Car 2: 6MT Canterbury Coupe
HID installation help
Alright. So I mounted the ballasts and drilled out the back coverings for the wires. As far as I can tell, everything is hooked up correctly. The two power wires from the ballast are dummy proof and I put green to red and black to black on the extension wire that goes from the head lamp to the ballast. When I switch the lights on to test, theres nothing from the driver side HID but the passenger side halogen lights up fine. The only thing I could have done wrong was the green to red, but it was only logical since black is always ground. Any tips for what this could be?
.:JDM/EDM Non-Navi DIY:.
.:JDM Navi Console DIY:.
Pinyix is offline
Old 09-07-07, 06:42 PM   #2 (permalink)
Black Type II's Avatar
Car 1: 1995 Blk on Blk LS Coupe
Car 2: 94 Honda Accord-4/S
Car 3: 1986 Buick Regal
is there a yellow wire? from what i remember seen both green and yellow or rather red/green and red/yellow wire...try the highbeam switch and see if u used the highbeam wire....not an expert at all but maybe some oversight hhappened
Plans: Repaint car Granada Black, Custom interior (not that kinda custom), Navi unit, red or glow gauge needles, Hrant floor mats, remote starter
Whats done: IS300 wheels, JDM headlights with 6000k HIDs, JDM navi console, LED backlit gauges
Black Type II is offline
Old 09-07-07, 07:14 PM   #3 (permalink)
AWDriftin yo moms whip
AustinForester's Avatar
Car 1: 2005 Subaru Forester 2.5 XT Turbo!
Send a message via AIM to AustinForester
i had this problem, try flipping the plug around, sometimes they are different, dont ask me why. its a really simple mod, it shouldnt take longer than 30 minutes.
Glad to see your FINALLY getting HIDs! once you experience them at night, you will never wanna go back to Halogen, its like night and day
AustinForester is offline
Old 09-07-07, 09:21 PM   #4 (permalink)
Yeah BABY!
Dinero19's Avatar
Car 1: 92 BLK/BLK LEGEND LS
Car 2: 96 INTEGRA LS
^Word..
05 TL Wheels
OEM TL Hid's 4300k
JDM Eyelids
Clear Corners
OEM? Fogs
KYB GR-2's
Dropped
eBay Intake
V6 emblems
35% / 20% tints
Kenwood Sub
Dinero19 is offline
Old 09-07-07, 10:06 PM   #5 (permalink)
BHG Motorsports
Pinyix's Avatar
Neither of those worked. I don't know what to do. I pulled the bulb out to make sure I didn't mess it up putting it in, its fine. I checked the connections, everything should be perfect. Could the bulb or the ballast be defective? Should I test the passenger side bulb without actually installing it? 30 minutes my ass. I spent two hours earlier today and an other half hour now and I'm no closer to getting these to work. This is so frustrating. I can't even drive it while its night now.
Pinyix is offline
Old 09-07-07, 10:08 PM   #6 (permalink)
Car 1: 1995 Acura Legend GS
Car 2: 1996 Ford EB Bronco
Car 3: 1992 Honda Accord EX
Pinyix - what brand did you end up going with? I'm looking to buy some myself.
dave
my '95 GS
daveCFPrez is offline
Old 09-07-07, 10:28 PM   #7 (permalink)
Yeah BABY!
Dinero19's Avatar
When I installed mine I had a defective bulb. I did swap the bulbs to verify that the bulb was damaged. Bought a new set on eBay and worked like a charm. Yeah, what brand did you get?
05 TL Wheels
OEM TL Hid's 4300k
JDM Eyelids
Clear Corners
OEM? Fogs
KYB GR-2's
Dropped
eBay Intake
V6 emblems
35% / 20% tints
Kenwood Sub
Dinero19 is offline
Old 09-07-07, 11:04 PM   #8 (permalink)
Dont Catch
bl420's Avatar
Car 1: 1991 Sedan
when i had mines the passenger side bulb had extra male spade connectors that connect to the stock harness also.
it turns on the relay powering the passenger side.
of course i just did a direct wire instead.
**Anti Alpine Type-R Thread**
bl420 is offline
Old 09-08-07, 02:17 AM   #9 (permalink)
Artillery129's Avatar
Car 1: 95 Acura Legend
ballast
if you want to see if the ballast is messed up use a voltemeter, if you want to see if you have an issue with the ground just ground it to the frame if you think you have an issue with the cables try hooking em up to your regular headlights without ballast then you can see if maybe wires have issue, also if i were you I would make sure that ballast converts to right voltage that may be an issue, maybe the contacts are a bit corroded on the jdm lights check everything in the circuit
Artillery129 is offline
Old 09-08-07, 06:00 AM   #10 (permalink)
MAD DOG!
dgandul's Avatar
Car 2: 92 LEGEND LS
when i first got mines i tested it directly to the battery to make sure they both worked before hacking into my wires.... maybe its defective... try using the other ballast and bulb... good luck. there should be two grounds, one for the high and one for the low, when i tired using the low ground it didnt work so i just made my own ground....
dgandul is offline
Old 09-08-07, 10:19 AM   #11 (permalink)
BHG Motorsports
Pinyix's Avatar
I took them out and put my halogens back in till I have more time. I'll probably have to tackle this Sunday. I'm going to hook everything up hanging out of the engine bay in different combinations to see if any of the bulbs or ballasts are faulty. I have regular USDM headlights by the way, no confusing JDM issues.
Pinyix is offline
Old 09-08-07, 03:20 PM   #12 (permalink)
chapman89's Avatar
Car 1: 1993 Acura Legend LS
Check your fuses, I had the same issue with mine after installation.
chapman89 is offline
Old 09-08-07, 04:12 PM   #13 (permalink)
T The pimp
truonghthe's Avatar
Car 2: 93 Legend L AT
Car 3: 92Legend L AT R.I.P
hey check your connection between the wire runing into your HID bulb I had the that problem for a while and I thought it was bad Ballast due to my old Legend involve in an accident and the water get into the ballast but finally the problem fix and now every thing work fines. Oh Also I would recomend that you should take the driver side and switch them into passenger side if it light up then everything fine if not you know there are a problem either bulb or ballast defective.
In memory of 92 LS 5spd
"I AM LEGEND"
To This
truonghthe is offline
Old 09-08-07, 07:08 PM   #14 (permalink)
BHG Motorsports
Pinyix's Avatar
The manufacturer is 'TENON' by the way. I'll let you know in a couple days if I endorse them or not.
Pinyix is offline
Old 09-09-07, 09:45 AM   #15 (permalink)
BHG Motorsports
Pinyix's Avatar
Alright. I tried both ballasts and both bulbs in both 9006 power harnesses switching the polarity each test to make sure I didn't have it reversed. The HID didn't light up once. I didn't hear 'clicking' as people suggest I should have and my GE nighthawk halogen low beams still work fine after all the testing.
The only thing I can conclude is that every component I received is defective since nothing has hinted otherwise. Am I overlooking something? The wiring is very simple and straight forward. No splicing is required. Suggestions?
Pinyix is offline
HID installation? drk9ght Second Generation Legend (1991-1995) 13 02-11-06 06:31 PM
HID's installation aznman007 First Generation Legend (1986-1990) 9 10-20-05 03:28 AM
HID Installation. B+O Second Generation Legend (1991-1995) 11 09-30-04 02:41 PM
Hid installation apaches coupe Second Generation Legend (1991-1995) 5 09-12-04 05:50 PM
Please help, need some HID installation advice 92Iloveu Engine & Performance Modifications 3 05-02-02 11:33 AM
