Old 05-13-08, 10:21 AM   #1 (permalink)
Car 1: 94 GS Black on Black Sedan Stock
Hood wont open
Anyone ever have this problem??
Let me know what exactly was your problem and how you solved it.
It is a 93L coupe 6MT type 2.
I just bought it and need to get in there, the guy i bought it from says it opens regularly but so far i have tried to yank on the cable hard, and i even yanked on it with pliers----not a good idea cos it puts bends in the cable
Help, i just want to do minor maintenence and cant even do that!!!
gsridah is offline
Old 05-13-08, 12:59 PM   #2 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
Is the pull handle broken? If it is then a pair of vice grips works best as you really have to give the metal part a good pull.
ari_one is offline
Old 05-13-08, 01:45 PM   #3 (permalink)
MarcD's Avatar
Car 1: 1995 Acura Legend LS 6MT
Car 2: 1994 Acura Legend LS
Car 3: 2005 GMC Yukon
I had the same thing happen on my Mother-in-laws accord. The cable go tight in the outer sheath form corrosion. Just be careful not to break the cable or you will be replacing it altogether. I had to break the grille out to get to the latch and manually disengage it. Then I was able to get some WD40 into the cable and get it freed up. Then get a used grille...
MarcD is offline
Old 05-13-08, 02:20 PM   #4 (permalink)
IAmLegend's Avatar
Car 1: 91 Acura Legend LS
Car 2: 94 Dodge Spirit
i had it happen where the hood cable broke away from the latching mechanism so when you pulled the cable you got nothing. once i got the hood opened all it took was a zip tie to fix it and 6 months later its still working.
Mods:
Lighted passenger window switches || Iggee seat covers || Telion chip || Blackend engine damper || Custom CAI || Remus specific || Pioneer DEH-P7800 head unit || 2 Infinity 12.1 Perfect subs || Polk 5.25" components front || JBL 3-ways rear || Kenwood KAC-9125D Mono amp || Kenwood KAC-7202 2 channel amp || Yellow top battery || Ground wire kit
Coming soon:
Type II intake manifold swap
Xbox install w/ monitors
IAmLegend is offline
Old 05-13-08, 11:36 PM   #5 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
My '91L hood would not open. A search found similar reports. I removed the
lower front bumper to allow access to the hood release mechanism and
was able to release the latch. Once I opened the hood, I lubricated the
mechanism with a silicone spray. No problems since. You may have a cable
problem; I had a latch lubricant problem and an access problem. The repair
took 45 minutes; but, was a hunch until the results confirmed the diagnosis:
stuck hood latch. Fortunately, I have two coupes and could check one while
working blindly on the problem vehicle.
Here is the lower bumper link. The hood latch is 20-69 on the online manual
Acura Legend Online Service Manual (Page: 0821)
Here is the hood latch page; I used a coat hanger to engage the latch.
Acura Legend Online Service Manual (Page: 0824)
My original problem:
Hood latch Fixed; thanks to search
Boru is offline
Old 05-14-08, 12:14 AM   #6 (permalink)
It's good to be the King!
robriguez's Avatar
Car 1: 95 Legend 5-spd
Car 2: 06 Envoy Denali
Car 3: 07 Yamaha Warrior
I "Just" had the same problem. My mechanism at the front behind the grill was seized. SOme wd40 and its semi working. I have to take it apart, clean it, and relube it and it shoule be fine again. Now that I can get it open I have to manually push the clasp for it to close properly.
95 Acura Legend L, 5-spd, custom Type F interior.
robriguez is offline
