Old 12-25-03, 05:27 PM   #1 (permalink)
KA7 Member
Car 1: 95 LS Sedan
Horrible Brake Clicking Noise
Ever since I have owned my car, I have had a slight clicking noise coming from the front brake calipers when making a turn with the brakes applied. It didn't bother me too much until last week when it got much worse. Now when I apply the brakes, the calipers make a loud clicking/thumping noise that I can feel from inside. It only does it when I apply the brakes lightly and then goes away when I brake hard. They also make very loud clicking noises when I turn the wheels with my brakes applied. Any ideas???
Thanks in advance!
n6xr2000 is offline
Old 12-25-03, 09:11 PM   #2 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
A "clicking" type of noise is typically associated with a bearing or CV-joint. This should be evidenced under load when turning. A brake caliper which is failing to fully retract produces more of an intermittent "hum". To rule out the brake caliper, drive for about 5 minutes. Stop and carefully place your hand near each wheel. If one is warm or hot, you have a caliper failing to retract. You could also have some debris caught between the disk and splash shield or even a bent splash shield.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
LPB is offline
Old 12-26-03, 03:16 AM   #3 (permalink)
Avarice's Avatar
Car 1: 2001 VW Jetta 1.8T WE
Car 2: 2002 Honda S2000
I think I had a similiiarissue with you, all I did was take out my front calipers and took the brake shims out and applied some brake disc quiet spray on each side of the shim. After that there were no more noises....
[img]
My 1991 Legend (SOLD)
Sedan Type-F floor mats
Driver Side seat (free)
OE + Denso Filters for cheap
Throttle Body
TL Engine Cover
Avarice is offline
Old 12-26-03, 03:54 AM   #4 (permalink)
KA7 Member
Car 1: 95 LS Sedan
Thanks for the replies. I have 2 new CV axles in the front so I don't think thats what is causing the problem. I agree with you avarice I will remove the wheels and apply some brake quiet and see of that helps.
Thanks
n6xr2000 is offline
Old 12-26-03, 07:24 AM   #5 (permalink)
are the wheels stock? If not, look inside to be sure the calipers aren't hitting the wheels
Best Wishes
Steve
Merlin the Wrench is offline
Old 12-28-03, 04:20 AM   #6 (permalink)
colinc's Avatar
Car 1: 88 Legend Coupe
Car 2: 93 Infiniti J30
I have same problem coming from rear. When I brake quickly while turning I hear a clicking/snapping noise, like something is moving around back there.
'88 Phoenix Red L Coupe (auto)
Previous Legends:
1989 L Coupe (1999-2002)
1994 GS Sdn. (2002-2004)
My Legend Website
http://www.geocities.com/colincliff2
Currently sitting on two sets of '90 Coupe Tails. Let me know if you want them!
colinc is offline
