How to disconnect the Beeping noise when door is open? - The Acura Legend & Acura RL Forum
Old 04-20-05, 05:44 PM   #1 (permalink)
Car 1: 95 acura legend LS
Lightbulb How to disconnect the Beeping noise when door is open?
I need help disconecting the annoying cicuit sound that is activated when opening the driver door. this happens when inserting the key in the ignition switch.
yeras is offline   Reply With Quote
Old 04-20-05, 10:19 PM   #2 (permalink)
OJP
Car 1: 91 legend
ahhhh yea i hate that soo much... how do u turn that off???
Don't look here
OJP is offline   Reply With Quote
Old 04-21-05, 01:52 AM   #3 (permalink)
Car 1: 94 Sherwood Green L Coupe
How come you guys bump to this issue? open the door, then pull out the key? - I don't do this very often
Thought that it's a nice feature that prevent you from forgetting the key in the car.
Anyway, I dont have the answer but any dealer guy may, if you give them a call.
94 G-78P L KA8
ndhduong is offline   Reply With Quote
Old 04-21-05, 03:41 AM   #4 (permalink)
Car 1: .
You can either take the key out or disconnect the speaker. I would not disconnect the speaker unless it is a last result, but it will get rid of the noise.
Later!
Lee
Old 04-21-05, 05:47 PM   #5 (permalink)
Car 1: '91 Dark Gray Metallic Legend L Sedan
On the underside of the ignition, you will find the indicator that the key is in the ignition. It is a small electric plug. Hence, if you unscrew it from the ignition assembly, it will no longer cause the beeping when your key is in the ignition and the door is open.
First, you will have to remove the lower dash to expose the ignition assembly. If my memory serves me correctly, you will see a small black wire and plug secured by a phillips screw to the underside of the assembly. Simply unscrew the plug and leave it hanging. That's it.
jdubsLegend is offline   Reply With Quote
Old 04-21-05, 07:20 PM   #6 (permalink)
Cole Austin
Guest
Posts: n/a
The buzzer is in the ICU. its built into the "lights on" circut in the ICU. You would have to go into the ICU and physically remove the buzzer from the circiut.
the wires coming off the ignition are as follows:
White - (battery)
White/Red - (ACC)
Black/Yellow - (Ground1)
Yellow - (ground2)
Black/White - (starter)
There is not just one wire you can remove from the ignition to kill the buzzing.
The Black/white wire connects to the under dash fuse box and the starter relay... from there it runs to things like the shift position sensor and the starter solenoid, and most importantly, the ICU.
The ICU (integrated controll unit) is located behind the under dash fuse box and that is where the buzzer is located. The ICU controls alot of stuff in the car, from the interior and exterior lights to the wiper speed, to the door switches and windows.
the ICU is very hard to get to and its not worth the troubles to stop the door open chime.
The buzzer is in the ICU. its built into the "lights on" circut in the ICU. You would have to go into the ICU and physically remove the buzzer from the circiut. Not worth the troubles.
beeping noise J Witherspoon Second Generation Legend (1991-1995) 6 10-25-04 01:20 PM
key in igntion, driver door open noise Atticus First Generation Legend (1986-1990) 4 09-25-03 11:10 PM
Noise from rear of car - your opinion, please mcjeez First Generation Legend (1986-1990) 4 07-31-03 09:44 AM
beeping when door open Harrison First Generation Legend (1986-1990) 1 05-28-03 04:58 PM
Mystery of the Clunking noise from the Legend mocca Second Generation Legend (1991-1995) 3 02-04-03 06:39 AM
