Idling Problem and SMOKING after Engine Cleaning?
Sorry for the long post, but I could really use some help guys.
So I finally took the time to clean up my engine the other day since it had been bothering me for a while that it was so dirty. I just had my BHG fixed, so I figured it was time for a good cleaning too. Anyways, so before i got started, I checked my oil. It was a little low, so I put in about a quart of oil for good measure (I checked the oil afterwards, and it was a little more than it should be, but I didnt think it was a problem). While putting oil in, I accidentally spilled some (stupid me, didn't think I needed a funnel). Anyways, this is when i was like whatever, lets wash it. So I got some plastic bags and covered up what I figured would be the most important/expensive part that could get damaged by water; the ABS unit. I coverd it up pretty well, and then whipped out the hose. I hosed down the engine, just to get the bigger dirt and other particles off. Later, after it was dry, I sprayed the engine with some of your standard Advanced Auto engine degreaser, waited 20 minutes, and then sprayed her down. The next day, I started her up and got a big cloud of blue smoke. Wtf? Then, i got some whiteish smoke (not as milky as BHG smoke, but still) so I decided to take her on a test drive. The car smoked for a good bit down the road, but then I got on the highway and went about 20 miles and got the car up to about 90mph and the smoke died down and sort of went away. Got back home and the car seemed to be okay but was still smoking a little bit. I turned the car off and when i tried to turn it back on, it wouldn't turn on when i turned the key. I turned the key twice, then pulled it out and put it back in and it worked. Drove to my buddy's house, and on the way, every time I would stop, the RPMs would go to between 2-400 and the car started to shake. Once it even turned off on me...(this was yesterday) And it did the "won't turn on when i turn the key" thing again today. Today, I did a little bit of regular driving and i was still having the idling problem, but not any real smoking. I didnt have any problems with the RPMs while the car was actually moving, only when stopped at a red light or something. I must say I've been really disappointed in the legend the last few days. Seems like just one problem after another. I almost miss my 92' Accord ![]() EDIT:::::::: Sorry, i forgot to mention that I accidentally pulled the fuse for the ECM while the car was running. (stupid me) But i reset it today by unplugging the battery for a few minutes and am still having the idling problem.
I'm Parting out TWO Black/Black Sedans. MANY MANY Parts available. PM me. 94' Acura Legend GS -158k Miles, Timing Belt DONE, Head Gasket: DONE, Tail Light Red-Out: DONE, Tint (35%): DONE, Viper Remote Start/Keyless Entry DONE Progress Thread<Update! 6/12/08 Future: 2 8" JL Subs+Amp, Ashtray Ipod Dock/Sunroof Tilt DIY Last edited by quanaman : 05-26-08 at 09:42 PM. |
difficult to kill
check your plugs!
www.myspace.com/thebestbryan BHG free since 2003 95 L coupe 4AT in cashmere silver 60a urethane mounts FL tie bars (newly installed) sr5guy stage III ecu GB Xdrilled/slotted front n rear rebuilt top end (~20k on it so far) weapon r + cold air extension 5wire 4awg ground kit |
could something have happened to the spark plugs just because i cleaned it? like water leakage or something? because i didn't have this problem before..
I'm Parting out TWO Black/Black Sedans. MANY MANY Parts available. PM me. 94' Acura Legend GS -158k Miles, Timing Belt DONE, Head Gasket: DONE, Tail Light Red-Out: DONE, Tint (35%): DONE, Viper Remote Start/Keyless Entry DONE Progress Thread<Update! 6/12/08 Future: 2 8" JL Subs+Amp, Ashtray Ipod Dock/Sunroof Tilt DIY |
#4 (permalink) | ||
Dee
u did clear any parts from gettin wet that were important right? other than the abs
if you read any of the numerous threads about people with idling problems after washing their engines it would seem to be that something getting wet has affected your idle.
most people say water gets trapped in the coil and spark plug hole. pull out all your coils and dry them and blow compressed air in the spark plug hole. your smoke is probably just water that somehow got into the exhaust system. you should be fine if once you get everything dried out |
#6 (permalink) | |
Kia Killa
Smoke will probably clear out if you JUST had your headgaskets done. If not, did you have your valve guide seals replaced with the headgaskets? Sometimes if the heads are sent out and hot tanked, the solutions in the bath can ruin the seals. Idle problem is probably a skip from getting water on the coil packs. Pull the coil packs and blow out the spark plug tubes and coil pack with compressed air.
-Matt
#7 (permalink) | ||
Dee
ye wat he said the water is most likely the colperate(if i spelt that right) i was told to after washing the bay let the plug wires chill for a bit since they aren't covered while washin
#8 (permalink) | ||
I'd shit on you for free.
water in the igniter coils where they touch the spark plugs... if your back firing your definantly missing.
Tha Fuck crawled up his vagina and died?
Its a Legend baby
this happened to me, still have the problem
1991 4 door auto 15.15 @ 91.17: CAI, EGR block plate **************************************** KA8 Vinyled Coupe Taillights http://www.acura-legend.com/vbulleti...3/#post1302298 ************************************************** ********** |
Matthew is THE USER!
idle control valve?
egr clogged?? spark plugs?? the smoke is prolly just from after the head gasket change... burnin off the coolant in ur engine or something.. but the stalling part.. thats wierd
KA7 & Inspire |
