ignition switch replacement - The Acura Legend & Acura RL Forum
Old 03-21-07, 01:42 PM   #1 (permalink)
Car 1: 94 LS Coupe
Send a message via AIM to mr_cox Send a message via MSN to mr_cox
question guys.. when you change the ignition switch do you change the ignition(key hole part)?
my ignition switch went..
ohh yeah and i found something on ebay
it says 94 acura legend L but it should work with an LS right? same thing huh?
http://cgi.ebay.com/ebaymotors/1994-...spagenameZWD1V
thats it.. is that the right thing?
Thank you guys.
2003 Acura CL Type S with Nav 6 speed
mr_cox is offline   Reply With Quote
Old 03-21-07, 02:24 PM   #2 (permalink)
That's the right part. No you don't change "key" part of it. I'd buy new though because it's a pain to squeeze under the dash to get that bad boy out. Do it right the first time I say.
AckLeg92 is offline   Reply With Quote
Old 03-21-07, 07:50 PM   #3 (permalink)
Nightshift's Avatar
Car 1: '94 LS 6-Speed Coupe
Car 2: '94 GS 6-Speed
Car 3: '94 GS Automatic
iTrader Score: 9 reviews
When you say ignition switch, what part are you referring too?
Apparently the tumbler itself can be changed. I talked to a locksmith today who had a machine that can recreate a 'new' key from a worn out original. He showed me how they come apart, not hard at all.
He said if the key didn't work out he can change the tumbler (guts of the switch) and key it to the original key. This is for the 'UK' Legend, the new key works fine.
About $30 if I carry the switch in to him.
I thought you had to buy the whole switch.
WW
'08 Chevrolet Avalanche LT3,
'02 LexusSC430,
'94 6-speed LS Coupe
'94 6-speed GS (formally 4cruizn),
'94 GS automatic (formally ptan1968),
'72 Buick Skylark Custom convert., frame-off resto.
Nightshift is offline   Reply With Quote
Old 03-22-07, 12:34 AM   #4 (permalink)
Car 1: 1991 Gray Sedan
i swapped out the switch on mine about 2 years ago, no big problem. it was a slight pain getting a screw driver in there, but not to hard to do at all. no you don't need to replace the 'key' mechanism
itimebomb is offline   Reply With Quote
Old 03-22-07, 06:35 AM   #5 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
Typically, it is the electrical portion of the switch which fails. The assy is installed using one-time tamper proof bolts whose heads are designed to shear off when tightened. This leaves only a collar and small portion of remaining bolt. In order to remove an assy you need to grind a slot into the remaining portion of the bolt and/or collar or destroy the assy. You then purchase a new assy and have a locksmith rekey it to the old key or remove the locks from doors trunk and glove box and them rekeyed to the new ignition key. Acura also used to sell a rekeyed set which included ignition, doors, trunk and glove box lock cylinders.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
Old 03-23-07, 05:09 PM   #6 (permalink)
joelcade's Avatar
Car 1: 1994 Legend L Coupe
That's a lot of work. My dealer is charging $230 in labor, but everything would match. Is that worth it?
joelcade is offline   Reply With Quote
Old 03-23-07, 05:28 PM   #7 (permalink)
legendtype2's Avatar
Car 1: 2011 MB ML350 4matic
Car 2: 1993 300zx TT
Car 3: 91+93 KA8 **gone**
Guys just take the switch apart and clean the contacts by sanding then wipe clean with rubbing alcohol. It's been 4 months for me w/o a problem. Save that $$ for some remus
I'll post some pics soon
legendtype2 is offline   Reply With Quote
Old 03-23-07, 05:35 PM   #8 (permalink)
used metal dishwashing sponge and ethanol(alcohol)
before cleaning
After cleaning
I didn't even disconnect the harness. Just disconnected the battery. Then dive under the dash and unscrew the switch. Becareful with tabs though I broke one but still good.
Old 03-24-07, 10:09 AM   #9 (permalink)
Car 1: 94 LS Coupe
i am 100% lost now.. i'm trying to get an ignition switch for my car.. and now u guys talking about key holes.. am i suppose to just get that $50 dollar switch change it and good to go.. or what?
Old 03-24-07, 06:15 PM   #10 (permalink)
switch is different from key hole. Switch itself freely rotates. If you change the keyhole you're gonna have two sets of keys... one for ignition and one more for doors/trunk.. you dont want that... so just remove the dash cover under steering wheel and lay on your back and go under. There are 3 screws I think
Old 03-24-07, 11:54 PM   #11 (permalink)
Car 1: 94 LS Coupe
yeah i figured thanx king :-)
Old 03-25-07, 11:08 AM   #12 (permalink)
Car 1: 94 LS Coupe
do you guys have any pics of what to remove to get to the ingition switch.. it would be helpful thank you :-D
Old 03-25-07, 12:47 PM   #13 (permalink)
Car 1: 94 LS Coupe
i finally got it out.. it was hell.. had to do some cutting too.. alot of wires were spliced to it!!
ps: i should have just tried that cleaning thing legendtype2 did
Old 03-25-07, 01:06 PM   #14 (permalink)
93lsz's Avatar
Car 1: 93 Legend Sedan
What did you cut?
Did mine and didn't cut anything. And while you are at it, take the main relay out and resolder the joints.
93lsz is offline   Reply With Quote
Old 03-25-07, 01:06 PM   #15 (permalink)
One Meeelion HP
sr5guy's Avatar
Car 1: 95 BMW 740I
Car 2: (860) 585-7200
Car 3: 91 LS Cpe 3.5 *sold*
iTrader Score: 44 reviews
Theres quite a bit of current running through that switch, I wouldn't recommend cleaning it if you plan on keeping the car long.
-Matt
sr5guy is offline   Reply With Quote
Ignition switch DIY and pictures 92legend3.2l Second Generation Legend (1991-1995) 3 03-21-07 02:38 PM
Please help me find ignition switch part #. frantinez63 Second Generation Legend (1991-1995) 17 11-13-06 08:34 PM
Trouble starting legend girl Second Generation Legend (1991-1995) 24 08-31-06 07:48 AM
Bad Main relay or bad ignition switch?? digger89L First Generation Legend (1986-1990) 3 08-01-06 09:01 PM
Ignition Switch, How much? Hard to install? toicy4ya Second Generation Legend (1991-1995) 10 10-18-03 04:23 PM
