95LegendLS12.
The easiest landmark is the oil filter. The VSS is inserted into the differential
near the oil filter. The link below shows the differential, and the VSS location.
To access it you will need to get under the car (safely) with ramps or a lift.
The splash shield will need to be removed. The only specialized tool is the
Tamper proof #20 Torx bit; and, it is available from any hardware store (Lowes,
H.Depot) I will stop here; because there are already a few detailed DIYs on
this site.
Acura Legend Online Service Manual (Page: 0534)
DIY link:
How To Replace The VSS
