Old 06-06-07, 11:19 PM   #1 (permalink)
contact148's Avatar
Car 1: 1993 legend
Car 2: 1995 neon
Car 3: 1946 willys CJ2A
Just finished my BHG!! ,some questions guys
Ok my BHG is done!!! turned the key and it started right away went well no major problems might have a small leak on my valve covers (used eristic gasket set off ebay but FACTORY HG's) if they are leaking any tips??
Now before the BHG my 93 4 door the D4 light on the dash worked now it does NOT light up car drives fine (it did stall twice durning the 1st cruise around my block) but ive put 1 hour on it and no problems since when it did stall the check engine light came on, the car started right away and once shut off the check engine light went away
could I have caused the d4 light to not work?? burnt out bulb? if bulb how do i change it?
fule injector electrical conectors the stupid little horse shoe shaped metal pain in the ass to remove things anyone have a source my dealer says not available anyone have a part ##
contact148 is offline
Old 06-06-07, 11:27 PM   #2 (permalink)
aclegend
oMaiR's Avatar
Car 1: 92 LS
Car 2: 95 Legend LS
if d3 and other lights lite up then its the bulb...I also did my HG this year...didn't have any problems since...to fix the leak u will need to replace the valve cover gasket, dealer has the single gasket for 14$...are u in toronto by any chance?
oMaiR is offline
Old 06-06-07, 11:33 PM   #3 (permalink)
contact148's Avatar
Car 1: 1993 legend
Car 2: 1995 neon
Im in durham region east of T.O id did put the eristic valve cover gaskets on they were new maybe they just suck....
all other bulbs work fine park all the way down except d4
so how do i change it??
Old 06-06-07, 11:36 PM   #4 (permalink)
aclegend
oMaiR's Avatar
Car 1: 92 LS
Car 2: 95 Legend LS
its very simple...lemme chk the DIY section
oMaiR is offline
Old 06-06-07, 11:38 PM   #5 (permalink)
Car 1: 92 Legend LS BLK/GRY
Car 2: 00 Honda Civic EX
Car 3: 06 Sonata GS
im in durham too whitby we should meet up
LegendFanInCanada is offline
Old 06-06-07, 11:38 PM   #6 (permalink)
aclegend
oMaiR's Avatar
Car 1: 92 LS
Car 2: 95 Legend LS
Indiglo DIY - (Pics/detailed instructions)
oMaiR is offline
Old 06-06-07, 11:40 PM   #7 (permalink)
aclegend
oMaiR's Avatar
Car 1: 92 LS
Car 2: 95 Legend LS
did u use liquid gasket on the valve gasket before putting the rubber gasket
oMaiR is offline
Old 06-06-07, 11:44 PM   #8 (permalink)
aclegend
oMaiR's Avatar
Car 1: 92 LS
Car 2: 95 Legend LS
http://www.arnach.net/service/index....&z=2690&r=0074
step 29 tells u where to apply the liquid gasket.
oMaiR is offline
Old 06-07-07, 09:19 PM   #9 (permalink)
contact148's Avatar
Car 1: 1993 legend
Car 2: 1995 neon
yup i used silicone where noted
its leaking at the head to cover seal under the hold down bolt closest to the front (bolt is not leaking)
as i driveit it seems to be getting less and less
Old 06-07-07, 09:46 PM   #10 (permalink)
TonyTheBullet's Avatar
Car 1: 1992 Legend LS Sedan
Car 2: 1993 Legend LS Coupe
You might as well upgrade the bulbs in your cluster to LEDs as well while you're at it.
____________________________________________
PM me if you got 'em!
TonyTheBullet is offline
Old 06-08-07, 08:09 AM   #11 (permalink)
contact148's Avatar
Car 1: 1993 legend
Car 2: 1995 neon
and where do i get leds part #????
4 Questions, Thanks Guys divinchi Second Generation Legend (1991-1995) 4 12-06-06 05:11 PM
Im buyin Leons car, and it has a BHG.. NEED To talk to Oregon and Washington guys Chauffeur First The Lounge 21 09-09-04 03:47 PM
Im buyin Leons car, and it has a BHG.. NEED To talk to Oregon and Washington guys Chauffeur First Second Generation Legend (1991-1995) 27 08-30-04 11:14 PM
i have a few performance questions...i need help guys! naztylegend93 Engine & Performance Modifications 1 11-13-02 10:03 PM
